https://i236.photobucket.com/albums/...100_4125-1.jpg
i was examining the wiring going to my CKP sensor and I broke the wire going into this connector. Luckily I have about 200 of these extra connectors on hand. So, I crimped and soldered it back on, then locked it back into it's housing. I would just like to know what this thing does. Is this oil pressure or what? |
um where on the engine is it? it looks like either the cam or the cranck sensor depending on where it is. honestly tho it looks like cam sensor
It's just to the left and up from the crank sensor. It's on the side of the engine that faces you when you open the hood and it's at the bottom next to the transmission side.
the cmp sensor is on the other side of the engine at the top. |
hence why i asked you where it was. i kno where they both are lol ive changed them out in my neverending quest to troubleshoot my car, i just couldnt tell because of the picture
well, what is it?
I think that is the engine temp sensor...?
Temp sensor
oil pressure or temp sender.. pretty sure its pressure.
Thanks. I was looking on HMAService and I found something similar to it which was labeled as an oil pressure switch, but it was in the wrong place on the engine. the engine was actually a v6 though.
