Mid Pipe Exhaust
It's not a good idea the try and make a 2.25" pipe 2.5" your better off replacing it, selling the old mid pipe, also consider the axel back is 2.25" that will be a bottle neck so just redo it all, the only reason you will need to go 2.5" is with force induction, N/A is happy with 2.25"
I'm not gonna use the same pipe eek.gif I saw a polished stainless steel pipe 2.5" with 2mm thickness will it be any good? and how many meters do I need?
Thanks
Coupe
[ February 05, 2002: Message edited by: Coupe ]
Thanks
Coupe
What do you think is the ideal thickness of the pipe(like the MBRP Mid Pipe Exhaust).
The place I went has 3mm but it will weight a bit more and I wasn't sure about the thickness.
Thanks
[ February 08, 2002: Message edited by: Coupe ]
Thanks
Good stainless can actually be 1.5mm thick, but there are different grades of 304 and 409 stainless to thats why you should stick with 2mm or so. If your doing a custom job let a shop do it, don't just by stainless pipe and try and use it or take it to the shop, you'll spend more after they rebend it.
