MAP Replacing MAF
Old Mar 13, 2002 | 02:05 AM
Zman's Avatar
Default MAP Replacing MAF
Why has Hyundai gone from MAF to MAP on the Elantra 2001+ while they are keeping the MAF for the 4cil Tiburons 2001+? They used to have the exact same engine and bolt ons.
Is it that MAF is better for tuning purposes and they think Elantras don't get as much attention? Is a MAP sistem way cheaper than a MAF? Or why?
Old Mar 13, 2002 | 02:33 AM
Suprgtrs_man's Avatar
The 2003 Tib 2.0L also is MAP based. They share engines again with the 2001+ Elantra. The 1.6L in the Accent is MAP based also.
Old Mar 13, 2002 | 06:33 AM
Zman's Avatar
Ok, so, there were differences only between the 2002 Elantras and 2002 4cil Tiburons?
It would still be interesting if anybody could explain or speculate about the reason for the change, because as far as I know, MAF would give more acurate readings. Also, is this new generation MAP different from the cars with MAP sold in 99-01 in Europe and Korea?
Old Mar 13, 2002 | 06:55 AM
Red's Avatar
Red
They're just trying to standardize platforms across all continents. As far as I can tell, North America was the only place to get the MAF sensors in Hyundai cars -- everyone else in the world got MAP.
This may have been for OBDII reasons or who knows what else, but that secondary manufacturing line raises Hyundai's assembly and manufacturing costs.
Platform, engine and electronics standardization makes a company a lot more streamlined and profitable -- when possible. It's likely that the ECU's going into the 2001+ Elantras and 2003+ Tiburons will all be almost identical to those in Korea and everywhere else in the world -- at least physically. There may be slightly different programming in the EEPROM for emissions, power, available gasoline and etc.
Old Mar 13, 2002 | 08:03 AM
clownboy's Avatar
does this mean ecu upgrades will be easyer to come by???
Old Mar 13, 2002 | 11:44 AM
clownboy:
If you happen to have one of the MAP based engines...possibly.
