K&N Filter Recharge Kit
Who has used this before? Any Tips?
umm, clean the filter, and then re-oil it. Not much to it.
Don't put the filter in if it's dripping oil, wait for it to finish soaking in and let the excess drip off beforehand. Don't want you engine sucking that stuff in. |
Brush off the filter with an old paint brush. If you have a compressed air source, blow out the filter from the inside out with LOW PRESSURE air. Don't use high pressure air or you may damage the filter.
Wash the filter with the cleaning agent. Let the cleaning agent soak in for 20 mintues. Then rinse the filter. Let the filter air dry for at least one hour, over night if you can manage it. Then coat the filter with the oil. Let the oil soak in for 15 minutes. Then recoat any areas that appear ligher in color. Let sit another 15 mintues after recoat...then install filter. |
| All times are GMT -6. The time now is 05:13 AM. |
