i know it's an old topic, but anyway - does any intake manifold from another car fit the beta 1 engine? the reason I'm asking - i'm putting on a supercharger, and need a bigger manifold, aswell as bigger TB. i heard somewhere that Prelude's intake manifold would fit? pleazz some info!
Igor |
A preludes will fit huh? I can see 1 difference right off... The throttle body is on the wrong side!!!! if your using a roots style, your not going to be using any part of your stock manifold, and for a centrifical... your not going to NEED to get them... Just pray for an airram man. 500 bucks all over.
CUSTOM 68mm bbtb, matched to AIRRAM
<div class='quotetop'>QUOTE (REDZMAN @ Jun 13 2005, 09:38 AM) <{POST_SNAPBACK}></div><div class='quotemain'>61MM RSide Adjustable w/cruise.</div>
I thought you had a 65mm BBTB with your airram? |
This topic is old... that post by Redz was June 16. He was still running the RSide then, he didn't install the 65mm until recently I think once he got the Air-Ram and headers back from ceramic coating.
I was first to install the 65mm on a N/A car I believe back around May, I think we bought around the same time but I put mine on right away. lmao.gif I can't stand having parts uninstalled. |
If only folks would read the reports in the Moderator Report center.
If only the folks posting would read the dates and see they are over a year old. |
<div class='quotetop'>QUOTE (REDZMAN @ Nov 15 2006, 04:32 AM) <{POST_SNAPBACK}></div><div class='quotemain'>If only folks would read the reports in the Moderator Report center.
If only the folks posting would read the dates and see they are over a year old.</div> <div class='quotetop'>QUOTE </div><div class='quotemain'>i know it's an old topic, but anyway</div> okay?! and besides that, I'm using a roots SC, with the IC, so I'm keeping the stock I - manifold. I only seek for a bigger one, as the beta1 one is very restrictive. and also with bigger intake manifold there is easir to put on a larger TB.(e.g. if i COULD put on a prelude's IM, i could use a prelude's TB, right? i don't mind it's right sided!!) so? does anybody know sometnhing about compatibility? greetz, Kennman |
Nothing like a Prelude or anything is compatible. The stock manifold doesn't flow that bad.
Either make your own or wait around for an Air-Ram to pop up. Or just port and polish the stock IM. |
were supposed to be having intake manifold made for us by a shop. hopefully well see an update soon. i have a bbtb, its 65 i think and im going to be selling it soon i think
