Installed My Header
Old Sep 3, 2010 | 10:06 PM
AnotherElantraTuner's Avatar
Vehicle: 01 Hyundai Elantra / 97 Hyundai Tiburon
Default Installed My Header
Well I got around to putting my header on, an Im very pleased, It was not easy tho, so beware when it says direct bolt-up, because it is not even close to a direct bolt on. I had to drill out the holes on the header flange that go's to the Engine's head, then I had to cut my exhaust flex pipe off almost the hole way to the second CAT, Everything is weilded up an so far so good, I have put over a hundred miles on it an still no check engine light. Check out the pic's!!!
Oh I even forgot to hook-up the second 02Sensor an still didnt get a check engine light, I now Have the battery unhooked an the 02 sensor hooked back u. If you look closly you can see the 02 sensor plug end hanging near the exhaust pipe, second pic from the bottom... lol
