How do you change gear Oil?
Old Aug 18, 2004 | 02:53 PM
Cuervo79's Avatar
Vehicle: 2010 Genesis Turbo
Hey, I now do the motor oil change in my tib, but never thought of doing the gear oil change, how do you do it and at what intervals do you do it is it for automatics or for manuals? I know there is the process in HMA service, but i would like it in simple terms and only use the info In HMA as a reminder....
Old Aug 18, 2004 | 03:19 PM
01roller's Avatar
Default Re: Tweed? Upholstery? HELP!
its real simple ..... just like what HMA says .....
make sure you have the car flat , then on the under the drivers side of the tranny is a bolt, (cant quite remember) i think it is either 19 or 22mm but i could be wrong. take that bolt out and drain (just like motor oil) then plug and unbolt the filler bolt directly in front of the car (standing in front of car facing the cabin) its the bolt on the bottom of that side of the tranny under the battery. fill till it leaks out. done. as for intervals i dunno.... whenver you change the clutch or when its dirty ....
Old Aug 18, 2004 | 05:51 PM
Mister_Sinister's Avatar
Default Re: Went to the track again :)
You should change your gear oil about every 20k miles.
Also, use Redline MT90 gear oil, with 1 pint of Lucas Heavy Duty synthetic oil stabilizer.
Old Aug 18, 2004 | 07:44 PM
a_gut's Avatar
Default Re: Seats
A pump works really well here, btw.
Old Aug 20, 2004 | 07:07 AM
JonGTR's Avatar
Default Re: what kind of subs?
Drain plug:
Filler plug:
Transaxle oil total capacity: 2.15 lit ( 2.27 qt, 1.89 impqt )
Or fill to plug:
Old Aug 20, 2004 | 06:07 PM
Cuervo79's Avatar
Default Re: RotorPros Group Buy - Accepting Payment!
THanx that{s what I was lookin for, now is it change each 20k Kilometer or Miles? thanx again
Old Aug 20, 2004 | 06:34 PM
Dweet's Avatar
Default Re: How do you change gear Oil?
miles more than likely
