My car is hesitating below 3000 rpm's and every once in awhile cyl. 2 will misfire. i've searched this and found that i have a dea sung tps, and plan on replacing it but would that cause a misfire?
i checked my plugs, and they all seem fine. Any help would be appreciated |
check your wires... I had this happen to me a while ago and i just got a set of NGK plugs and PRD wires... problem solved.
Yeah plugs and wires are almost always the cause of a misfire. Check the wires and plus again just to be sure
Ok i'll change my plugs and wires tonight or tomorrow, i think its about time to change them anyway.
I'll let you know what happens. Thanks |
Not much else simple that you could check other then plugs and wires. If it comes down to it, it may be that your fuel injectors are fouled. Lets hope not.
https://i4.photobucket.com/albums/y1...go/dtc0301.gif
Except look at #2 cylinder ... too lazy to grab the other image laugh.gif Pick up a car scanner to verify your code as well! Here is one: Link |
