HELP with a fault code
Vehicle: 2000 Tiburon
I went to autozone and they hooked up the OBD and gave me a fault code of p1586, but i cant find it anywhere in HMAservice, the closest one is idle sped control actuator faults codes, that are 1510,1513,1552,1553
Can anybody help me find P1586 ???
EDIT: I found the code, but I dont understand the comments
check it out
http://www.hmaservice.com/webtech/iindex.a...id=12322#_12322
check it out
P1586
Encoding signal circuit not rationale
MT/AT Encoding
Yes
MT/AT Encoding
Yes
Manual Transmission/Auto Transmission Encoding error is what it is mang.
They found a way to get rid of this CEL on HP some time ago.
well the OBD at autozone has a breif description of what the fault means, and it said acceleration sensor, what ever that meant, so i was thinkin maybe the input speed control actuator.
I dont know and the car was idling funny, kind of rough, maybe i need new wires and plugs.
