Headder Wrap adding 15hp??? Ya right!
Old Jul 21, 2002 | 12:09 PM
Cottonmouth's Avatar
Default Headder Wrap adding 15hp??? Ya right!
p.s. Why would you wrap your turbo??? I don't know about you guys but I would rather my turbo stay as cool as possible.
Old Jul 21, 2002 | 01:52 PM
Turbos are ceramic coated or wrapped for many reasons.
#1. To keep the heat out of the engine bay.
#2. To keep the heat in the turbo.
The hotter the turbo is, the hotter your EGT's are, or I should say, the hotter they STAY. Hot gas takes up more space than cold gas. (Gas contracts as it cools). By keeping your exhaust gas as hot as possible, you keep it moving as fast as possible. Same reason you heat wrap headers (or ceramic coat them)
#3. To keep the hot side hot and the cool side cool (think Mc DLT here.) By wraping the exhaust and intake side seperately, you are seperating the two as much as possible thermally.
Ceramic coated/heat wrapped turbos spool faster, and yes, can produce more power at a given level of boost due to the turbine staying hot, and not working as hard, and the intake side staying cooler, thus a more dense air charge.
It is perfectly possible that a properly heat wraped turbo assembly would produce more HP than one that was not heat wrapped.
[edit] I just read the whole thread. Sorry, I agree 15 HP for just heat wrapping the stock headers or even aftermarket units is BS. Also, heat wrap will void the warranty of most aftermarket headers, and certianly the stock exhaust manifold. 15 HP on a turbo I could see, no way 15 HP on N/A headers or Stock Exhaust Manifold.
Old Jul 22, 2002 | 11:45 AM
I always thought you should be aware of overheating your turbo. frown
Old Jul 22, 2002 | 01:17 PM
AfterShocK's Avatar
Random, I thought heat wrapping aftermarket headers would make them more likely to crack?
Old Jul 22, 2002 | 02:23 PM
Solo-Baric's Avatar
no they won't crack. but corrosion hell yes. I'm gonna heat wrap my header when i install mine. then the intake tube. I'm probally gonna wrap everything except the flex pipe on the header till it's past the eng bay.
Old Jul 23, 2002 | 12:42 AM
Cottonmouth:
With a proper cooling system and oiling system, you should have nothing to worry about. Yes, the turbo will retain more heat from high boost operation, making the use of a turbo timer nearly compulsory, but it should not *overheat* the turbo.
AfterShocK:
Yes, it is possible to do damage to poorly made aftermarket headers with heat wrap. That is why I mentioned about it voiding the warranty on aftermarket headers. This is also one of the many reasons ceramic coating is prefered to heat wrap.
Old Jul 23, 2002 | 02:27 AM
JAWS 021's Avatar
ceramic coating also looks a lot better
Old Jul 23, 2002 | 09:40 AM
4CyLofFuRy's Avatar
how would the heat wrap make the headers crack or corrode?¿
Old Jul 23, 2002 | 11:44 AM
Hootie's Avatar
4CyLofFuRy:
Wrapped headers = no heat dissipation(sp). All that heat with no where to go will weaken the metal.
Old Jul 23, 2002 | 01:30 PM
Veniston's Avatar
Also applicable for turbos--heat wrapping or coating helps to lower the temperature gradient across the housing, which alleviates internal stresses in the metal. You can keep it cooler overall using proper cooling & oiling, insulating minimizes the stresses due to uneven heating.
