Engine knock??
Old 11-27-2017, 09:35 PM
guitarman's Avatar
Vehicle: 2001/hyundai/tiburon
Default Engine knock??
I have a 2001 Hyundai Tiburon and it has started making a knocking noise while accelerating. It's not like it stays constant. It seems to have more to do with engine load than rpm. So I can be at 3k and get some noise then it stops...push the pedal down a little more and it comes back. The best way to try and hear it is to rev up and down while accelerating. I took 1 quart of oil out tonight and replaced it with lucas engine treatment and a little seafoam. I notice the oil was kinda metallic...that sounds like a bad thing! Could it be a rod bearing? If so, couldn't I just change it through the bottom of the engine?
Videos showing the symptoms:
Oil glitter (big "particles" are air bubbles. Actual metal was so fine my paint strainger wouldn't filter it out!):
https://photos.app.goo.gl/XVft2PIoCL5yGAYJ2
Parked with hood open (obvious!!):
https://photos.app.goo.gl/GsKOxv4YoUhs1K8k1
Driving (not as noticable):
https://photos.app.goo.gl/e6BV2FJrafo5qvWk2
Old 11-28-2017, 11:05 AM
I have really bad speakers here at work, but sounds a bit like a stretched cam chain?
Old 11-28-2017, 11:25 AM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
Do you have a CEL?
Have you ever replace the Knock Sensor?
Old 11-29-2017, 12:42 AM
guitarman's Avatar
Originally Posted by Juanra
Do you have a CEL?
No CEL. Have never changed the knock sensor.
Old 11-29-2017, 09:50 AM
rob40's Avatar
Vehicle: 2000/Hyundai/Coupe F2 Evo
sounds like big end (rod bearings as you call them) to me, might have damaged the crank aswell. You won't really know until you drop them off and have a look for other damage
Old 11-29-2017, 10:54 AM
buy a motor from the junkyard. they are cheap enough.
dont waste your time rebuilding this one.
Old 12-14-2017, 06:19 AM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
You may be able to get by with just replacing the rod and crank bearings with the engine in the car provided the crank isn't damaged.
