Gear Ratios
Anyone know of a site where I can see 2001 Tib's gear ratios?
I found a cool little program that will measure your top speed based off of specs. Any help is appreciated, thanks! |
yes, i do. The site isn't technically up yet, but i can still get the ratios. It has them for almost every car. It's a buddy of mine's site.
The tiburon's is: Transmission Type: M Axle Ratio: 3.84 Number of Gears: 5 1st: 3.31 2nd: 1.95 3rd: 1.39 4th: 1.06 5th: 0.84 6th: 0 The Tiburon FX is: Transmission Type: M Axle Ratio: 3.84 Number of Gears: 5 1st: 3.31 2nd: 1.95 3rd: 1.39 4th: 1.06 5th: 0.84 6th: 0 |
There is also lots of other info for the tibby. Just post it if you wanna know. and ill see if he has it.
You have the primary reduction?
what about the 97 elantra
<div class='quotetop'>QUOTE </div><div class='quotemain'>Originally posted by cringe:
You have the primary reduction?</div> What cha mean? |
hey please what is the gear ratios of the 97 elantra
