Flywheel Resurfacing.
Guest
Posts: n/a
Hey guys who have installed clutches, or swapped trans, etc. I need to know the specs for resurfacing the flywheel. i need to get mine machined tomm. morning and i need to know what the 'step' .. not sure if thats term, needs to be set at.. if you guys have done this before youll know what i mean. I would really appreciate the help.. Thanks alot.
Nate
Nate
you just need to get the surface skimmed, i took mine in to the machining shop and asked for a surface skim it removed all heat spots etc, i cant remember exactly how much the took off. sorry
im sure its in the manual or webtech.. let me check
*Mod Edit - Alz99 no need to quote the above post*
