Hyundai Aftermarket
-   -   Finaly Did A Compression Test. (https://www.hyundaiaftermarket.org/forum/engine-intake-exhaust-11/finaly-did-compression-test-30185/)
tanc Jul 20, 2005 04:05 PM
130 - 140 - 140 - 140
I'm not sure wheather thats good okay or bad, becuase I don't see in the manual the standard number for what you should be at. Anyone care to help me out.
Viper Jul 20, 2005 04:08 PM
I can remember reading someone's post once and it said around 155 if I can remember correctly.
So numbers seem correct, maybe a bit low
tanc Jul 20, 2005 04:13 PM
What would be recommended in order to restore some of the compression.
New rings? New head? Engine cleaner? Coolant flush?
faithofadragon Jul 20, 2005 04:14 PM
ok how did you do your test?
when i did mine i read 180 - 190s and that is low.
factory says around 200 is where it should be
to do the test
disconnect the coil and pull the fuel pump fuse
then crank the car a few times with the tester in the chamber
do one chamber at a time
tanc Jul 20, 2005 04:18 PM
All I did was screw in the tester in the chamber.
Would that alter the results if I didn't disconnect the coil and fuel pump fuse?
faithofadragon Jul 20, 2005 04:19 PM
well it would because its still trying to fire into the chambers plus the head is still pumping gas into it
you want to see how the engine compresses air
Viper Jul 20, 2005 04:22 PM
Ok I thought it was a bit low but apparently it's way low. Considering you have 4 cylinders which are all low it could be that you didn't do the compressio test right.
I'd say use the test setup described here ^^ above and then check the numbers again
faithofadragon Jul 20, 2005 04:23 PM
if its low add a little oil (like a few drops that little no more than a teaspoon)
if the numbers jump you should look into some rings
12SecRD Jul 20, 2005 05:13 PM
do it with the engine warm
Jaws021 Jul 20, 2005 05:39 PM
everyone is right
disconnect the fuel pump, or pull the fuse
the turn on the car and let the car die on its own (so youll know the fuel lines are empty)
Next disconnect the coil pack (the harness is to the right of the coil pack towards the fire wall)
Do one cyl at a time.. keep crankin until the needle stops moving up.
Anything below 190 start checking every 2-4 weeks for changes..
Anything 190-200 not that great
Anything between 200-220 is normal ok
Anything above 220 is kick ass
Faith is right... if you get one way below.. add a bit of oil then check it.. if compression increases you got some bad rings.
If theres no change at all.. it could be a head problem (gasket, valves, seals,..ect)
