Finaly Did A Compression Test.
130 - 140 - 140 - 140
I'm not sure wheather thats good okay or bad, becuase I don't see in the manual the standard number for what you should be at. Anyone care to help me out.
ok how did you do your test?
when i did mine i read 180 - 190s and that is low.
factory says around 200 is where it should be
to do the test
disconnect the coil and pull the fuel pump fuse
then crank the car a few times with the tester in the chamber
do one chamber at a time
to do the test
Ok I thought it was a bit low but apparently it's way low. Considering you have 4 cylinders which are all low it could be that you didn't do the compressio test right.
I'd say use the test setup described here ^^ above and then check the numbers again
everyone is right
disconnect the fuel pump, or pull the fuse
the turn on the car and let the car die on its own (so youll know the fuel lines are empty)
Next disconnect the coil pack (the harness is to the right of the coil pack towards the fire wall)
Do one cyl at a time.. keep crankin until the needle stops moving up.
Anything below 190 start checking every 2-4 weeks for changes..
Anything 190-200 not that great
Anything between 200-220 is normal ok
Anything above 220 is kick ass
Faith is right... if you get one way below.. add a bit of oil then check it.. if compression increases you got some bad rings.
If theres no change at all.. it could be a head problem (gasket, valves, seals,..ect)
