Hyundai Aftermarket
-   -   Fidanza Guys! Come And Help (https://www.hyundaiaftermarket.org/forum/engine-intake-exhaust-11/fidanza-guys-come-help-42558/)
nate704 Apr 20, 2007 07:27 PM
I got a Fidanza flywheel and south bend clutch set installed.
Do you guys have some scratchy metal rubbing and sharp noise when you start up the car?
I'm having that scratchy rubbing noise when I start up the car.
my mechanic said that it is because there's little gap between the starter and flywheel tooth. Is that true?
Hyundaidb883 Apr 22, 2007 05:24 PM
doubt it, i have the exact same setup, and i installed it myself. no problems, no noise. sounds like he may have forgotten to tighten something down so you're hearing a noise. you may want to get under there yourself and take a quick peak.
rollwitstyle Apr 22, 2007 08:25 PM
i have the fidanza also, and no noise
xxxmonoxidechild Apr 22, 2007 09:45 PM
im also ona southbend and fidanza set up. no issues. love the set up. you sure its not just chatter from it breaking in?
