Everyone That Has Put A Elantra Tranny In Your Tib
Old May 28, 2005 | 12:38 AM
2quick's Avatar
Vehicle: 00 Tiburon
What all elantra transmissions will fit in a 2000 tiburon, if any?
Old May 28, 2005 | 05:32 AM
albert's Avatar
Old May 28, 2005 | 06:06 AM
xxxmonoxidechild's Avatar
are any of the clutch's different between the years and models? i know the flywheel changed in mid 98 or so.
Old May 28, 2005 | 12:38 PM
2quick's Avatar
Vehicle: 00 Tiburon
I know in 99 or so the one of the harness changed, and I can't get any elantras to show up as compatible. It is an auto
Old May 28, 2005 | 02:59 PM
albert's Avatar
The flywheel isn't part of the transmission, so it doesn't matter. Any 97-05+ Elantra tranny will fit ANY beta engined Tiburon.
Use the flywheel you have now, and you have no worries.
Old May 29, 2005 | 08:08 AM
supry's Avatar
Vehicle: 1998 Hyundai Tiburon FX
I just bolted an 01 Elantra Transmission into my 98 tibby, no problems.
86 mph in 3rd gear
110mph in 4th gear
Old May 29, 2005 | 08:35 AM
zhiryst's Avatar
wow, the 97 1.8l tranny goes up to 70 in 3rd, and 100 in 4th, thats a big diffirence.
Old May 29, 2005 | 08:46 AM
bryce804's Avatar
i have an 02 tranny in my 2000.
Old May 29, 2005 | 08:47 AM
yes, that is one of the tricks that most car makers use for making their sporty cars feel faster than the cars they are based on. You close up the ratios in box for faster acceleration. The elantra has a wider spaced gear set, as it is designed for comfortible cruising, rather than sporting intentions.
Personally. If I was going to run turbo, I would drop an elantra box into my tib. The longer ratios allow you to stay in boost longer.
Old May 30, 2005 | 08:39 PM
2quick's Avatar
Vehicle: 00 Tiburon
Where is the best place to get part numbers for tranmissions? I really need to get an auto tranny for my 2000 tib but i am in fear of wasting money, the reason I am afraid is that car-parts.com does not say that it is swapable. ANy one that know without a doubt what all will fit please tell me.
I replaced a tranny on a tib before and I was told that all year elantras will work for a 97 tib but only 99 and down elantra trannies will fit on a 99 and below because of a wire harness beside the dip stick.
