Engine is lean... how to check?
Old Jun 24, 2002 | 02:44 PM
Jed118's Avatar
Vehicle: Hyundai Pony
Default Engine is lean... how to check?
I believe my engine is runing lean. It gets INCREDIBLY hot and requires the pedal to be pressed down quite a bit. This all happened after I changed my fuel pump from one that leaks to one that does not. Ever since, I've had to press the pedal down further to get the car moving. It is a carbureted car, if that helps. HOW can I check (not via spark plugs) if my engine is running lean?
Old Jun 24, 2002 | 03:12 PM
Fast.Type-S's Avatar
A/F meter. Autometer
Old Jun 25, 2002 | 01:51 AM
ol skool dubber's Avatar
Eh, block head, whazzup?
Use can use an exhaust gas temp sensor or (I know you don't like electronics on cars) a Oxygen sensor, but just hooked up to a LED box since it wont mean anything to a carbed engine.
P.S
Block head when are you gonna get your spare cylinder head cleaned?
Old Jun 26, 2002 | 03:00 PM
Jed118's Avatar
WTF are you doing here volkswagen?
Isn't there an easier way?!!?
