Engine knock??
Vehicle: 2001/hyundai/tiburon
I have a 2001 Hyundai Tiburon and it has started making a knocking noise while accelerating. It's not like it stays constant. It seems to have more to do with engine load than rpm. So I can be at 3k and get some noise then it stops...push the pedal down a little more and it comes back. The best way to try and hear it is to rev up and down while accelerating. I took 1 quart of oil out tonight and replaced it with lucas engine treatment and a little seafoam. I notice the oil was kinda metallic...that sounds like a bad thing! Could it be a rod bearing? If so, couldn't I just change it through the bottom of the engine?
Videos showing the symptoms:
Oil glitter (big "particles" are air bubbles. Actual metal was so fine my paint strainger wouldn't filter it out!):
https://photos.app.goo.gl/XVft2PIoCL5yGAYJ2
Parked with hood open (obvious!!):
https://photos.app.goo.gl/GsKOxv4YoUhs1K8k1
Driving (not as noticable):
https://photos.app.goo.gl/e6BV2FJrafo5qvWk2
sounds like big end (rod bearings as you call them) to me, might have damaged the crank aswell. You won't really know until you drop them off and have a look for other damage
buy a motor from the junkyard. they are cheap enough.
dont waste your time rebuilding this one.
