Eclipse Injectors???
if your just replace your stock injectors, your going to be running rich as hell, and probably burn-out your cat and cause unknown hell with your engine.
The only way you'd want upgraded injectors is if you were doing SC/Turbo/bigNOS and then you'd have a replacement ECU.
if your running N/A you'll need a S-AFC to lean out your spray so that you won't run rich.
the stock injectors are more then adequete for all N/A needs to N/A+NOS needs.
if i'm correct, the tibby runs pig rich all the time(especially at high-rpm) so running EXTRA fuel at highrpm won't help any. thats why when you tune a s-afc with a fully N/A setup, you have to lean your engine out to gain HP, not increase fuel.
if I plan to finish getting all the bolt ons for a 2001 tibby and plan on re-doing the internals and I am currently running a 55 shot of ZEX, I don't need to replace the injectors for this?.....Wil i see a good change if I get a S/AFC from APEX if it is tuned right?....will that just be to "fine tune" and get it to idle properly or what?...thanks!
They say a lot of things.
