Dirty Coolant
not to long ago i did a coolant flush-... i did it just like the bottle told me to "drain coolant, add coolant flush and water combo, drive 3-6 hours (clensing process), drain again, pour in coolant" for coolant i used the pre-mixed 50/50 dexcool, and a bottle of dei radiator relief. i never overheated at any point ever, just trying to mantain the rd2.
but what i'm getting at is, as i was drainging the old coolant (which was a bright green) there was alot of black "dust" in the overflow tank (which i cleaned out). and even whith the new coolant (a bright osha orange similar to a roadside cone) i'm still finding black "dust".
i'm not the best car expert but my guess is oil-... which could be either a gasket or cracked head? or is it completely normal?
all and any responses are appreciated and welcomed, even more appreciation goes to actual useable help! thanks in advance!
although this doesn't answer your question, you shouldn't have used Dex-Cool.... That coolant is specific for GM's only. our cars need Ethyl-Glycol (EG).... it's green
you used the wrong coolant
Actually, the different colors just represent how long they are good for.
Doesn't matter WHICH car you put them in.
http://www.eetcorp.com/antifreeze/an...ze-faq.htm#q28
They developed it SPECIALLY, but it still works fine in anything.
I found several other sites saying that Texaco recommends Dex-Cool for ALL makes and models now.
What do all the different colors of antifreeze mean and what should I be using?
In the past, most antifreezes were green. Now, manufacturers use a variety of colors in their antifreeze product lines. Green generally, but not necessarily, indicates an automotive or light duty formulation. Orange antifreeze generally means extended-life type of antifreeze. It is ethylene glycol-based like most green antifreezes but contains different corrosion inhibitors.
The various manufacturers use colors to identify their products in a bit of marketing gamesmanship; however, there are no hard rules governing the use of these colors. Equipment manufacturers and consumers should have an ability to identify their approved fluid. In addition, color has been used in antifreezes as a safety measure to discourage accidental ingestion.
Since the mid-1990’s, the proliferation of coolant colors has caused considerable confusion. All engine coolants use a glycol base but include different performance additives that inhibit (control) scale/ corrosion. Believe it or not, all of these coolants are clear, water white before dye is added.
The traditional green coolant is based on inorganic additives and is called inorganic additive technology (IAT). It is a tried and proven chemistry that provides a fast acting protective film. The additives deplete, though, and need to be replenished every couple of years.
Fully formulated engine coolants were developed in response to user demands for a simpler, universal, longer life coolant technology. Heavy-duty operators had to use low silicate automotive coolant formulations (high silicate automotive antifreezes could cause “green goo†in diesel engines) that required a separate SCA additive. This often resulted in mixing errors when the SCA was added at initial fill or when topping-off. Unlike automotive antifreeze, fully formulated coolants are pre-charged with SCA’s and contain all of the ingredients necessary to protect diesel, gasoline, and gaseous fuel engines. Pink has become recognized as the color for fully formulated coolant, although they are also commercially available in green (as required by government agencies). These products meet performance requirements for major automotive specifications, allowing mixed-fleet operators to stock one antifreeze formula for all of their vehicles.
A new type of antifreeze, referred to as extended or long life, has emerged. Its unique chemistry differs significantly from that used in traditional antifreezes. Referred to as organic acid technology (OAT), this new chemistry uses organic acids to protect cooling system metals. Extended life antifreezes have been colored red or orange depending on the supplier; however, more colors may be used in the future. While these fluids do not deplete during service, they also do not protect as quickly as IAT coolants. These differences require a significant change in procedures used to maintain the cooling system.
General Motors® has been using this technology (DEX-COOL®) in their cars and trucks since 1996. They use an orange dye for DEX-COOL® product. A Ford Motor Company® study concluded that OAT coolants “do not offer any significant advantages for the consumer…†and “…current coolant corrosion protection can be extended far beyond previous expectationsâ€Â. Cummins Engine Company announced in a memo dated July 16,1999, that OAT coolants are not compatible with their engines. Cummins is reporting that these long life antifreezes cause degradation of silicone seals in their engines after 80,000 to 100,000 miles of service. Cummins, therefore, is not recommending the use of OAT coolants in their engines.
Hybrid organic acid technology (HOAT) uses both inorganic and organic acid additives for long life protection. The objective with HOAT is to provide excellent all around protection and extended drain intervals. HOAT coolants generally can replace or are compatible with green IAT in older vehicles. Chrysler used conventional green IAT coolant until 2001, when they adopted G-05®, a hybrid coolant. Ford followed suit in 2002, dropping the green IAT for G-05® factory fill and extending the drain interval. Variations of HOAT coolants have been around for more than 50 years.
what makes this even a bigger pain in the ass is that there are Green "long life" coolants now. Honda has been using it for the past few years. the only way to know is that underneath the hood, there is a sticker saying that the coolant is longlife.
one of the things i do at sears is try to sell coolant exchanges. we have to know which is long life and which is not. all these "hybrids" out there makes it hard, but now having a long life green coolant makes it a bigger pain in the ass...
the Ford "long life" coolant is G05. more often than not, it's Yellow. VW likes using orange. just like Dex-Cool (but its not dexcool). Toyota has red coolant. and, like i said, Honda has green long life, not to be confused with regular green coolant. haha.
waaaaaay too confusing if you work in the car service industry
How much do those FULL EXCHANGES cost? I've seen places where they do that, and replace like 99.9% of your coolant or oil. Is it that big of a difference?
$59.99 at my store. pretty sure its the same price everywhere.
what Sears does is an exchange. not a flush. with a flush, you can run a chance of doing major damage, such as a cracked head gasket (happened to my mom)
i've never performed one, but they do good business. lol.
As long as it's not rust, I wouldn't worry about it. Could be any of LOTS of stuff. The vaccum created when running could suck in some dust/dirt and it gets in there.
As long as it's clean, that's what counts.
