Went searching for an answer to my problem.
Cruise control not working, same as posted a while ago someone lost their cruise control. Changed taillights to LED's so was wondering what I need to do, what kind of resistance or what needed to get my cruise control working. |
All I remember is you need to add resistors to get it to work. It was Redz that had the problem, should help your search.
Yeah, I figured I needed a resistor but to what wire? BTW thanks mwood.
I thought there were pics?
I can go back and take some if you want. It is a resistor pack wired to the positive and negative if I remember right. And yes, it gets warm. Let me know if you need me to chedk. |
I'm running all led and have one of those relays that gets rid of the "ricer flash". I was curious if the resistor set works with it. Oh, and yeah, no, there are no pics on that thread.
Thanks Redz. |
Relay works with mine my man.
Did you get the same relay I did? I'm doing a bunch right now, but if you want I can do pics. DTN is the one that helped me fix it, told me what to do. |
