Cruise Control
Old Jun 2, 2005 | 11:04 PM
kennyt_2001's Avatar
I have had my car for like about 4 years and I bought it at around 35 thousand miles and now it is at 105 thousand and during this time my cruise control has never worked, I have checked the fuses and all that but still cannot find whats wrong, please help
Old Jun 2, 2005 | 11:05 PM
What kind of taillights do you have? OEM or aftermarket?
Also, what kind of bulbs are in the BRAKE LIGHT position?
Old Jun 2, 2005 | 11:09 PM
they are the stock tail lights and i have the bulbs that I got with the car
Old Jun 2, 2005 | 11:15 PM
Are you 100% sure? Check and make sure both stages of the bulbs are working.
Old Jun 2, 2005 | 11:16 PM
yeah all the bulbs work as advertise, what would the bulbs have to do with it anyway
Old Jun 2, 2005 | 11:50 PM
Low voltage. I put LED bulbs in my brake lamp section and a few days later noticed my Cruise didn't work anymore. Tried to figure it out for over a year before KayJai saw the same problem at work and tracked it down. I swapped my BRAKE BULBS back for the OEM high draw ones and whammo, cruise worked.
Drop in the chatroom mang.
Anyways, could be a vaccum leak also, or a faulty Cruise module. You check Webtech?
EDIT
CC Schematic
Might wanna check for Vaccum leaks also in the engine bay.
http://www.hmaservice.com/webtech/iindex.a...viewed=1#_12313
http://www.hmaservice.com/webtech/iindex.a...viewed=1#_12656
Very good info here.
http://www.hmaservice.com/webtech/iindex.a...viewed=1#_12657
http://www.hmaservice.com/webtech/iindex.a...viewed=1#_12658
Let me know if any of this helps.
Old Jun 9, 2005 | 07:11 AM
xxxmonoxidechild's Avatar
theres an adjuster on the clutch pedal also, if its out of adjustment, the cruise will not work. it took me about 2 months of poking around to figure that one out on my own car.
Old Jun 13, 2005 | 09:14 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Okay I'm moving this to Engine and Transmission as it is not a DIY
