Crescent Seals Under Valve Cover
I pulled the Valve Cover off my "Parts Tiburon" (I know, Im lucky) since my current valve cover is cracked and leaking oil into the timing belt area...
Ive got the new Valve cover gasket, and new spark plug seals on but where do these Crescent-shaped seals go? Maybe Im blind but I dont see where they go... lmao.gif I feel stupid...
Look near the ends of the camshafts and you will see them. If you've already put the valve cover gasket on then you have covered up the tops of them.
Well found em already, just wasnt looking for the right thing.... they lay flat when put in so it looked like a normal part and not a seal. I figured it out once I saw the new seals I bought...
Do these half-moon seals need gasket sealant on them? when I took the old ones off there was white stuff on them... need quick response please Im trying to get this done right now... THNX
