Compression Test Done Right.
Old Aug 18, 2005 | 07:10 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Well disconnected the coils and fuelpump.
Each cylinder had around 220psi. The first crank each cylinder went to around 215 then around 3 it went to 220.
Old Aug 18, 2005 | 07:17 PM
sure youre not leaking oil? whens the last time you've checked your coolant?
Old Aug 18, 2005 | 07:20 PM
tanc's Avatar
No oil is leaking. Coolant was flushed and changed 2 weeks ago.
Old Aug 18, 2005 | 07:23 PM
the only other thing i can think about is a busted headgasket. the coolant didnt look weird at all, did it?
Old Aug 18, 2005 | 07:27 PM
tanc's Avatar
Just looked like coolant that has never been changed.
I had it done at the dealership because I worked too many hours. They didn't mention anything.
Old Aug 18, 2005 | 07:41 PM
If you are burning oil.. I would look at your valve guides. Worn guides will let oil into the cylinder but it will not affect the compression.
albert's Avatar
If you are loosing excessive oil, chances are your PCV valve is gummed up/gone bad.
Remove it, and try cleaning it with B-12 chemtool or carb/choke cleaner. Or save your pennies and invest $5.99 in a new one.
Old Aug 18, 2005 | 07:43 PM
tanc's Avatar
Where is the PCV valve random? I'm not sure which one your talking about.
Old Aug 18, 2005 | 07:47 PM
back right of the valve cover, connected to the hose further to the left.
Old Aug 18, 2005 | 07:48 PM
tanc's Avatar
You confused me. My spark plugs also have a bit of white at the tip, would this be the cause of running lean right? I have no 2nd sensor install because my cat is not on yet. Would that be my lean problem?
