Compression
Old May 24, 2005 | 01:16 PM
12SecRD's Avatar
I was wondering if anybody knows what the compression should be with tigerlly 8:5:1 pistons.
I did a check today and got (warm engine) 176 - 180- 177 - 179 (give or take 1 or 2 psi). I have about 3000 kms on the motor since the rebuild.
I thought the injectors were disabled, but it turns out they weren't. (not sure if this would have any effect.)
I needed an oil change anyway
Are these in the normal, ok range?
Currently running 16 psi for the last 1000 kms.
thanks,
Gary
Old May 24, 2005 | 01:20 PM
hamhead's Avatar
Looks very good to me... seem like they are taking boost nicely.
Old May 24, 2005 | 02:49 PM
albert's Avatar
Stock readings are between 199 and 213 PSI for 10.3:1 compression, so I would say you're doing fine.
When you do a compression check, make sure you pin the throttle WIDE OPEN. Have a buddy step on the gas while cranking.
If you can't disable the fuel pump, cheat and pull the injector wiring harness from each injector.
Old May 24, 2005 | 04:46 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
I don't want to hijack but is there a special tool that is needed for a compression check??
16 psi eh? Nice. According to the numbers that faith, and Random have posted recently, all your numbers look good.
Old May 24, 2005 | 05:10 PM
12SecRD's Avatar
QUOTE (Random @ May 24 2005, 06:19 PM)
Yep had the throttle wide open when doing the test. I had the injector disabled on the haltech but they never turnt off..sigh..maybe i never hit the right button. oh well.
thanks for the replies.
Old May 25, 2005 | 07:53 AM
JonGTR's Avatar
QUOTE (silvertibbs @ May 24 2005, 10:46 PM)
It's very easy to do and the tool you can buy from a parts store for around $15.
It's a great tool to have.
Old May 25, 2005 | 08:26 AM
going further offtopic.. found a cheap on on eBay.
Compression tester Kit <--- click me!
Old May 25, 2005 | 10:19 PM
Viper966's Avatar
good way to tell if u have good compression is that they are all close to eachother....
