Clutch Replacement
Old Jan 30, 2006 | 11:12 PM
Mad_john's Avatar
Old Jan 31, 2006 | 05:41 AM
IJSTBRNDU's Avatar
Thanks for the help guys. I dont need to take the flywheel off, right? Thats only if you are getting it resurfaced? I have a fidanza and all i need to do is take out the friction insert and bolt a new one in, right?
IJSTBRNDU's Avatar
Old Jan 31, 2006 | 06:32 AM
MK3Design's Avatar
I resurfaced my Flywheel while it was on the car. Just sand it down.
MK3Design's Avatar
Old Feb 1, 2006 | 03:59 PM
IJSTBRNDU's Avatar
Ok i have a couple more ?'s because hmaservice is being gay and i dont have my owners manual to refer to.
What grade gear oil do i need for thew transmission, i know its 75-90 but im not sure if its dot 3 or whatever number.
What fluid/grade should i use for the clutch system?
Do i need to buy any new gaskets/seals/retainers/clip/etc... for the install?
IJSTBRNDU's Avatar
Old Feb 1, 2006 | 05:33 PM
a_gut's Avatar
Use a GL-4 spec fluid. Most GL-5's will eat your synchronizers.
a_gut's Avatar
