clutch adjustment
Old Aug 11, 2004 | 08:56 PM
batman's Avatar
Vehicle: 01 Tiburon
Default Re: Iceman Billet Aluminum Throttle Bodies!
can someone tell me how to adjust my clutch....it doesn't grap until almost top of pedal...do i just bleed it or what
Old Aug 11, 2004 | 09:50 PM
alz99's Avatar
Vehicle: FX Coupe
Default Re: 20 WHP from just an intake?!
adjust the nut, underneath the clutch pedal then lock it in by tightning the other nut, you'll see what i mean if you look under the pedal.
Old Aug 12, 2004 | 04:19 PM
batman's Avatar
Vehicle: 01 Tiburon
Default Re: recent developments...
i thought that just adjusted the play in the top of the pedal
Old Aug 12, 2004 | 04:50 PM
col96fx's Avatar
Vehicle: Hyosung GT650
Default Re: what kind of subs?
Try bleading the clutch system 1st (can't hurt).
You can adjust the pedal as ALZ99 said, but I don't think that will fix it.
Old Aug 12, 2004 | 05:38 PM
alz99's Avatar
Vehicle: FX Coupe
Default Re: DIY Mesh Grills
http://www.hmaservice.com/webtech/iindex.a...p?id=6627#_6627
Old Aug 12, 2004 | 06:27 PM
batman's Avatar
Vehicle: 01 Tiburon
Default Re: My Shifter and hand brake handle
thanx guys i'll do that as soon as it stops raining
