Checking Injectors
My tib is running too rich, and i wanted to maybe check the injectors to see if one is stuck open. Is there more of a hassle than its worth? Im not really sure where to begin. Also would the o2 sensors have something to do with why it is running rich? Black smoke comes out when i get on it, and sometimes it even seems like i wants to bog down.
I'd bank on the o2 sensor. No CEL's? are you sure its running rich (do you have a wideband?)
If it is,
You should probably try some injector cleaner, possibly seafoam, and reset your ECU.
If it still runs rich maybe a new o2 sensor.
You may just have some carbon build up so seafoam would take care of that.
If it is,
P0442 Evaporative emission (EVAP) system – small leak detected Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve
this is off rixsharks cel codes thing. looks like somethin on the intake piping/vacuum side of things maybe?
