Hyundai Aftermarket
-   -   Check Engine Light - Codes (https://www.hyundaiaftermarket.org/forum/engine-intake-exhaust-11/check-engine-light-codes-44913/)
Rixshark Sep 19, 2007 09:00 AM
CEL codes
Standard OBD-II codes starting with "P"
P0000 No fault found â€â€
P0001 Fuel volume regulator control â€â€œ circuit open Wiring, regulator control solenoid
P0002 Fuel volume regulator control â€â€œ circuit range/performance Wiring, regulator control solenoid
P0003 Fuel volume regulator control â€â€œ circuit low Wiring short to ground, regulator control solenoid
P0004 Fuel volume regulator control â€â€œ circuit high Wiring open circuit/short to positive, regulator control solenoid
P0005 Fuel shut-off valve control â€â€œ circuit open Wiring open circuit, fuel shut-off valve
P0006 Fuel shut-off valve control â€â€œ circuit low Wiring short to ground, fuel shut-off valve
P0007 Fuel shut-off valve control â€â€œ circuit high Wiring short to positive, fuel shut-off valve
P0008 Engine position system, bank 1 â€â€œ performance Mechanical fault
P0009 Engine position system, bank 2 â€â€œ performance Mechanical fault
P0010 Camshaft position (CMP) actuator, intake/left/front, bank 1 â€â€œ circuit malfunction Wiring, CMP actuator, ECM
P0011 Camshaft position (CMP), intake/left/front, bank 1 â€â€œ timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator
P0012 Camshaft position (CMP), intake/left/front, bank 1 â€â€œ timing over-retarded Valve timing, engine mechanical fault, CMP actuator
P0013 Camshaft position (CMP) actuator, intake/left/front, bank 1 â€â€œ circuit malfunction Wiring, CMP actuator, ECM
P0014 Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 â€â€œ timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator
P0015 Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 â€â€œ timing over-retarded Valve timing, engine mechanical fault, CMP actuator
P0016 Crankshaft position/camshaft position, bank 1 sensor A â€â€œ correlation Wiring, CKP sensor, CMP sensor, mechanical fault
P0017 Crankshaft position/camshaft position, bank 1 sensor B â€â€œ correlation Wiring, CKP sensor, CMP sensor, mechanical fault
P0018 Crankshaft position/camshaft position, bank 2 sensor A â€â€œ correlation Wiring, CKP sensor, CMP sensor, mechanical fault
P0019 Crankshaft position/camshaft position, bank 2 sensor B â€â€œ correlation Wiring, CKP sensor, CMP sensor, mechanical fault
P0020 Camshaft position (CMP) actuator, intake/left/front, bank 2 â€â€œ circuit malfunction Wiring, CMP actuator, ECM
P0021 Camshaft position (CMP), intake/left/front, bank 2 â€â€œ timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator
P0022 Camshaft position (CMP), intake/left/front, bank 2 â€â€œ timing over-retarded Valve timing, engine mechanical fault, CMP actuator
P0023 Camshaft position (CMP) actuator, exhaust/right/rear, bank 2 â€â€œ circuit malfunction Wiring, CMP actuator, ECM
P0024 Camshaft position (CMP), exhaust/right/rear, bank 2 â€â€œ timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator
P0025 Camshaft position (CMP), exhaust/right/rear, bank 2 â€â€œ timing over-retarded Valve timing, engine mechanical fault, CMP actuator
P0026 Intake valve control solenoid circuit, bank 1 â€â€œ range/performance Wiring, intake valve control solenoid
P0027 Exhaust valve control solenoid circuit, bank 1 â€â€œ range/performance Wiring, exhaust valve control solenoid
P0028 Intake valve control solenoid circuit, bank 2 â€â€œ range/performance Wiring, intake valve control solenoid
P0029 Exhaust valve control solenoid circuit, bank 2 â€â€œ range/performance Wiring, exhaust valve control solenoid
P0030 Heated oxygen sensor (HO2S) 1, bank 1, heater control â€â€œ circuit malfunction Wiring, HO2S, ECM
P0031 Heated oxygen sensor (HO2S) 1, bank 1, heater control â€â€œ circuit low Wiring short to ground, HO2S, ECM
P0032 Heated oxygen sensor (HO2S) 1, bank 1, heater control â€â€œ circuit high Wiring short to positive, HO2S, ECM
P0033 Turbocharger (TC) wastegate regulating valve â€â€œ circuit malfunction Wiring, TC wastegate regulating valve, ECM
P0034 Turbocharger (TC) wastegate regulating valve â€â€œ circuit low Wiring short to ground, TC wastegate regulating valve, ECM
P0035 Turbocharger (TC) wastegate regulating valve â€â€œ circuit high Wiring short to positive, TC wastegate regulating valve, ECM
P0036 Heated oxygen sensor (HO2S) 2, bank 1, heater control â€â€œ circuit malfunction Wiring, HO2S, ECM
P0037 Heated oxygen sensor (HO2S) 2, bank 1, heater control â€â€œ circuit low Wiring short to ground, HO2S, ECM
P0038 Heated oxygen sensor (HO2S) 2, bank 1, heater control â€â€œ circuit high Wiring short to positive, HO2S, ECM
P0039 Turbo/super charger bypass valve, control circuitâ€â€œ range/performance Wiring, bypass valve
P0040 Oxygen sensor signals swapped, bank 1 sensor 1/bank 2 sensor 1 Wiring
P0041 Oxygen sensor signals swapped, bank 1 sensor 2/bank 2 sensor 2 Wiring
P0042 Heated oxygen sensor (HO2S) 3, bank 1, heater control â€â€œ circuit malfunction Wiring, HO2S, ECM
P0043 Heated oxygen sensor (HO2S) 3, bank 1, heater control â€â€œ circuit low Wiring short to ground, HO2S, ECM
P0044 Heated oxygen sensor (HO2S) 3, bank 1, heater control â€â€œ circuit high Wiring short to positive, HO2S, ECM
P0045 Turbo/super charger boost control solenoid â€â€œ circuit open Wiring, boost control solenoid
P0046 Turbo/super charger boost control solenoid â€â€œ circuit range/performance Wiring, boost control solenoid, mechanical fault
P0047 Turbo/super charger boost control solenoid â€â€œ circuit low Wiring short to ground, boost control solenoid
P0048 Turbo/super charger boost control solenoid â€â€œ circuit high Wiring short to positive, boost control solenoid
P0049 Turbo/super charger turbine â€â€œ over-speed Mechanical fault
P0050 Heated oxygen sensor (HO2S) 1, bank 2, heater control â€â€œ circuit malfunction Wiring, HO2S, ECM
P0051 Heated oxygen sensor (HO2S) 1, bank 2, heater control â€â€œ circuit low Wiring short to ground, HO2S, ECM
P0052 Heated oxygen sensor (HO2S) 1, bank 2, heater control â€â€œ circuit high Wiring short to positive, HO2S, ECM
P0053 Heated oxygen sensor (HO2S), bank 1, sensor 1 â€â€œ heater resistance Wiring, HO2S
P0054 Heated oxygen sensor (HO2S), bank 1, sensor 2 â€â€œ heater resistance Wiring, HO2S
P0055 Heated oxygen sensor (HO2S), bank 1, sensor 3 â€â€œ heater resistance Wiring, HO2S
P0056 Heated oxygen sensor (HO2S) 2, bank 2, heater control â€â€œ circuit malfunction Wiring, HO2S, ECM
P0057 Heated oxygen sensor (HO2S) 2, bank 2, heater control â€â€œ heater circuit low Wiring short to ground, HO2S, ECM
P0058 Heated oxygen sensor (HO2S) 2, bank 2, heater control â€â€œ circuit high Wiring short to positive, HO2S, ECM
P0059 Heated oxygen sensor (HO2S), bank 2, sensor 1 â€â€œ heater resistance Wiring, HO2S
P0060 Heated oxygen sensor (HO2S), bank 2, sensor 2 â€â€œ heater resistance Wiring, HO2S
P0061 Heated oxygen sensor (HO2S), bank 2, sensor 3 â€â€œ heater resistance Wiring, HO2S
P0062 Heated oxygen sensor (HO2S) 3, bank 2, heater control â€â€œ circuit malfunction Wiring, HO2S, ECM
P0063 Heated oxygen sensor (HO2S) 3, bank 2, heater control â€â€œ circuit low Wiring short to ground, HO2S, ECM
P0064 Heated oxygen sensor (HO2S) 3, bank 2, heater control â€â€œ circuit high Wiring short to positive, HO2S, ECM
P0065 Air assisted injector â€â€œ range/performance problem Air assisted injector
P0066 Air assisted injector â€â€œ circuit malfunction/circuit low Wiring short to ground, air assisted injector, ECM
P0067 Air assisted injector â€â€œ circuit high Wiring short to positive, air assisted injector, ECM
P0068 Manifold pressure (MAP) sensor/Mass air flow (MAF) sensor â€â€œ throttle position correlation Wiring, MAP sensor, MAF sensor, mechanical fault
P0069 Manifold pressure (MAP) sensor â€â€œ barometric pressure correlation MAF sensor, mechanical fault
P0070 Outside air temperature sensor â€â€œ circuit malfunction Wiring, outside air temperature sensor, ECM
P0071 Outside air temperature sensor â€â€œ range/performance problem Outside air temperature sensor
P0072 Outside air temperature sensor â€â€œ low input Wiring, short to ground, outside air temperature sensor, ECM
P0073 Outside air temperature sensor â€â€œ high input Wiring, short to positive, outside air temperature sensor, ECM
P0074 Outside air temperature sensor â€â€œ circuit intermittent Wiring, poor connection, outside air temperature sensor, ECM
P0075 Intake valve control solenoid, bank 1 â€â€œ circuit malfunction Wiring, intake valve control solenoid, ECM
P0076 Intake valve control solenoid, bank 1 â€â€œ circuit low Wiring short to ground, intake valve control solenoid, ECM
P0077 Intake valve control solenoid, bank 1 â€â€œ circuit high Wiring short to positive, intake valve control solenoid, ECM
P0078 Exhaust valve control solenoid, bank 1 â€â€œ circuit malfunction Wiring, exhaust valve control solenoid, ECM
P0079 Exhaust valve control solenoid, bank 1 â€â€œ circuit low Wiring short to ground, exhaust valve control solenoid, ECM
P0080 Exhaust valve control solenoid, bank 1 â€â€œ circuit high Wiring short to positive, exhaust valve control solenoid, ECM
P0081 Intake valve control solenoid, bank 2 â€â€œ circuit malfunction Wiring, intake valve control solenoid, ECM
P0082 Intake valve control solenoid, bank 2 â€â€œ circuit low Wiring short to ground, intake valve control solenoid, ECM
P0083 Intake valve control solenoid, bank 2 â€â€œ circuit high Wiring short to positive, intake valve control solenoid, ECM
P0084 Exhaust valve control solenoid, bank 2 â€â€œ circuit malfunction Wiring, exhaust valve control solenoid, ECM
P0085 Exhaust valve control solenoid, bank 2 â€â€œ circuit low Wiring short to ground, exhaust valve control solenoid, ECM
P0086 Exhaust valve control solenoid, bank 2 â€â€œ circuit high Wiring short to positive, exhaust valve control solenoid, ECM
P0087 Fuel rail/system pressure â€â€œ too low Fuel pump, fuel pressure regulator, fuel supply pipe blockage, mechanical fault
P0088 Fuel rail/system pressure â€â€œ too high Fuel pump, fuel pressure regulator, fuel return pipe blockage, mechanical fault
P0089 Fuel pressure regulator â€â€œ performance problem Fuel pressure regulator, mechanical fault
P0090 Fuel metering solenoid â€â€œ open circuit Wiring open circuit, fuel metering solenoid, ECM
P0091 Fuel metering solenoid â€â€œ short to ground Wiring short to ground, fuel metering solenoid, ECM
P0092 Fuel metering solenoid â€â€œ short to positive Wiring short to positive, fuel metering solenoid, ECM
P0093 Fuel system leak detected â€â€œ large leak Wiring, fuel pressure sensor, mechanical fault
P0094 Fuel system leak detected â€â€œ small leak Wiring, fuel pressure sensor, mechanical fault
P0095 Intake air temperature (IAT) sensor 2 â€â€œ circuit malfunction Wiring, poor connection, IAT sensor, ECM
P0096 Intake air temperature (IAT) sensor 2 â€â€œ circuit range/performance Wiring, poor connection, IAT sensor, ECM 37
P0097 Intake air temperature (IAT) sensor 2 â€â€œ circuit low input Wiring short to ground, IAT sensor, ECM
P0098 Intake air temperature (IAT) sensor 2 â€â€œ circuit high input Wiring short to positive, IAT sensor, ECM
P0099 Intake air temperature (IAT) sensor 2 â€â€œ circuit intermittent/erratic Wiring, poor connection, IAT sensor, ECM
P0100 Mass air flow (MAF) sensor/volume air flow (VAF) sensor â€â€œ circuit malfunction Wiring, MAF/VAF sensor, ECM
P0101 Mass air flow (MAF) sensor/volume air flow (VAF) sensor â€â€œ range/performance problem Intake leak/blockage, MAF/VAF sensor
P0102 Mass air flow (MAF) sensor/volume air flow (VAF) sensor â€â€œ low input Wiring short to ground, MAF/VAF sensor, ECM
P0103 Mass air flow (MAF) sensor/volume air flow (VAF) sensor â€â€œ high input Wiring short to positive, MAF/VAF sensor, ECM
P0104 Mass air flow (MAF) sensor/volume air flow (VAF) sensor â€â€œ circuit intermittent Wiring, poor connection, MAF/VAF sensor, ECM
P0105 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor â€â€œ circuit malfunction Wiring, MAP sensor, BARO sensor, ECM
P0106 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor â€â€œ range/performance problem Intake/exhaust leak, wiring, MAP sensor, BARO sensor
P0107 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor â€â€œ low input Wiring short to ground, MAP sensor, BARO sensor, ECM
P0108 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor â€â€œ high input Wiring short to positive, MAP sensor, BARO sensor, ECM
P0109 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor â€â€œ circuit intermittent Wiring, poor connection, MAP sensor, BARO sensor, ECM
P0110 Intake air temperature (IAT) sensor â€â€œ circuit malfunction Wiring, IAT sensor, ECM
P0111 Intake air temperature (IAT) sensor â€â€œ range/performance problem IAT sensor
P0112 Intake air temperature (IAT) sensor â€â€œ low input Wiring short to ground, IAT sensor, ECM
P0113 Intake air temperature (IAT) sensor â€â€œ high input Wiring open circuit/short to positive, ground wire defective,IAT sensor, ECM
P0114 Intake air temperature (IAT) sensor â€â€œ circuit intermittent Wiring, poor connection, IAT sensor, ECM
P0115 Engine coolant temperature (ECT) sensor â€â€œ circuit malfunction Wiring, ECT sensor, ECM
P0116 Engine coolant temperature (ECT) sensor â€â€œ range/performance problem Coolant thermostat, poor connection, wiring, ECT sensor
P0117 Engine coolant temperature (ECT) sensor â€â€œ low input Coolant thermostat, wiring short to ground, ECT sensor
P0118 Engine coolant temperature (ECT) sensor â€â€œ high input Coolant thermostat, wiring open circuit/short to positive, ground wire defective, ECT sensor
P0119 Engine coolant temperature (ECT) sensor â€â€œ circuit intermittent Wiring, poor connection, ECT sensor, ECM
P0120 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A â€â€œ circuit malfunction Wiring,TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A â€â€œ circuit malfunction Wiring,TP/APP switch, ECM
P0121 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A â€â€œ range/performance problem Accelerator cable adjustment, TP/APP sensor Throttle position (TP) switch A/accelerator pedal position (APP) switch A â€â€œ range/performance problem Accelerator cable adjustment, TP/APP switch
P0122 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A â€â€œ low input Wiring short to ground,TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A â€â€œ low input Wiring short to ground,TP/APP switch, ECM
P0123 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A â€â€œ high input Wiring short to positive,TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A â€â€œ high input Wiring short to positive,TP/APP switch, ECM
P0124 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A â€â€œ circuit intermittent Wiring, poor connection, TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A â€â€œ circuit intermittent Wiring, poor connection, TP/APP switch, ECM
P0125 Insufficient coolant temperature for closed loop fuel control Wiring, cooling system, coolant thermostat, ECT sensor
P0126 Insufficient coolant temperature for stable operation Wiring, cooling system, coolant thermostat, ECT sensor
P0127 Intake air temperature â€â€œ too high Wiring short to ground, IAT sensor 2, mechanical fault, ECM
P0128 Coolant thermostat â€â€œ coolant temp below thermostat regulating temperature Mechanical fault
P0129 Barometric pressure â€â€œ too low Wiring, BARO sensor, mechanical fault
P0130 Heated oxygen sensor (HO2S) 1, bank 1 â€â€œ circuit malfunction Heating inoperative, poor connection, wiring, HO2S Oxygen sensor (O2S) 1, bank 1 â€â€œ circuit malfunction Wiring, O2S, ECM
P0131 Heated oxygen sensor (HO2S) 1, bank 1 â€â€œ low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 1, bank 1 â€â€œ low voltage Exhaust leak,wiring short to ground, O2S, ECM
P0132 Heated oxygen sensor (HO2S) 1, bank 1 â€â€œ high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 1, bank 1 â€â€œ high voltage Wiring short to positive, O2S, ECM
P0133 Heated oxygen sensor (HO2S) 1, bank 1 â€â€œ slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 1, bank 1 â€â€œ slow response Wiring, O2S
P0134 Heated oxygen sensor (HO2S) 1, bank 1 â€â€œ no acitivty detected Wiring open circuit, heating inoperative, HO2S Oxygen sensor (O2S) 1, bank 1 â€â€œ no activity detected Wiring, O2S
P0135 Heated oxygen sensor (HO2S) 1, bank 1, heater control â€â€œ circuit malfunction Fuse, wiring, HO2S, ECM
P0136 Heated oxygen sensor (HO2S) 2, bank 1 â€â€œ circuit malfunction Heating inoperative, wiring, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 â€â€œ circuit malfunction Wiring, O2S, ECM
P0137 Heated oxygen sensor (HO2S) 2, bank 1 â€â€œ low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 â€â€œ low voltage Exhaust leak,wiring short to ground, O2S, ECM
P0138 Heated oxygen sensor (HO2S) 2, bank 1 â€â€œ high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 â€â€œ high voltage Wiring short to positive, O2S, ECM
P0139 Heated oxygen sensor (HO2S) 2, bank 1 â€â€œ slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 2, bank 1 â€â€œ slow response Wiring, O2S
P0140 Heated oxygen sensor (HO2S) 2, bank 1 â€â€œ no acitivty detected Wiring, heating inoperative, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 â€â€œ no activity detected Wiring, O2S, ECM
P0141 Heated oxygen sensor (HO2S) 2, bank 1, heater control â€â€œ circuit malfunction Wiring, HO2S, ECM
P0142 Heated oxygen sensor (HO2S) 3, bank 1 â€â€œ circuit malfunction Wiring, HO2S, ECM
P0143 Heated oxygen sensor (HO2S) 3, bank 1 â€â€œ low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 3, bank 1 â€â€œ low voltage Exhaust leak,wiring short to ground, O2S, ECM
P0144 Heated oxygen sensor (HO2S) 3, bank 1 â€â€œ high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 3, bank 1 â€â€œ high voltage Wiring short to positive, O2S, ECM
P0145 Heated oxygen sensor (HO2S) 3, bank 1 â€â€œ slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 3, bank 1 â€â€œ slow response Wiring, O2S
P0146 Heated oxygen sensor (HO2S) 3, bank 1 â€â€œ no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 3, bank 1 â€â€œ no activity detected Wiring, O2S, ECM
P0147 Heated oxygen sensor (HO2S) 3, bank 1, heater control â€â€œ circuit malfunction Wiring, HO2S, ECM
P0148 Fuel delivery error Fuel pump/fuel injection pump
P0149 Fuel timing error Fuel pump/fuel injection pump
P0150 Heated oxygen sensor (HO2S) 1, bank 2 â€â€œ circuit malfunction Wiring, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 â€â€œ circuit malfunction Wiring, O2S, ECM
P0151 Heated oxygen sensor (HO2S) 1, bank 2 â€â€œ low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 â€â€œ low voltage Exhaust leak,wiring short to ground, O2S, ECM
P0152 Heated oxygen sensor (HO2S) 1, bank 2 â€â€œ high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 â€â€œ high voltage Wiring short to positive, O2S, ECM
P0153 Heated oxygen sensor (HO2S) 1, bank 2 â€â€œ slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 1, bank 2 â€â€œ slow response Wiring, O2S
P0154 Heated oxygen sensor (HO2S) 1, bank 2 â€â€œ no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 â€â€œ no activity detected Wiring, O2S, ECM
P0155 Heated oxygen sensor (HO2S) 1, bank 2, heater control â€â€œ circuit malfunction Wiring, HO2S, ECM
P0156 Heated oxygen sensor (HO2S) 2, bank 2 â€â€œ circuit malfunction Heating inoperative, wiring, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 â€â€œ circuit malfunction Wiring, O2S, ECM
P0157 Heated oxygen sensor (HO2S) 2, bank 2 â€â€œ low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 â€â€œ low voltage Exhaust leak,wiring short to ground, O2S, ECM
P0158 Heated oxygen sensor (HO2S) 2, bank 2 â€â€œ high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 â€â€œ high voltage Wiring short to positive, O2S, ECM
P0159 Heated oxygen sensor (HO2S) 2, bank 2 â€â€œ slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 2, bank 2 â€â€œ slow response Wiring, O2S
P0160 Heated oxygen sensor (HO2S) 2, bank 2 â€â€œ no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 â€â€œ no activity detected Wiring, O2S, ECM
P0161 Heated oxygen sensor (HO2S) 2, bank 2, heater control â€â€œ circuit malfunction Wiring, HO2S, ECM
P0162 Heated oxygen sensor (HO2S) 3, bank 2 â€â€œ circuit malfunction Wiring, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 â€â€œ circuit malfunction Wiring, O2S, ECM
P0163 Heated oxygen sensor (HO2S) 3, bank 2 â€â€œ low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 â€â€œ low voltage Exhaust leak, wiring short to ground, O2S, ECM
P0164 Heated oxygen sensor (HO2S) 3, bank 2 â€â€œ high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 â€â€œ high voltage Wiring short to positive, O2S, ECM
P0165 Heated oxygen sensor (HO2S) 3, bank 2 â€â€œ slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 3, bank 2 â€â€œ slow response Wiring, O2S
P0166 Heated oxygen sensor (HO2S) 3, bank 2 â€â€œ no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 â€â€œ no activity detected Wiring, O2S, ECM
P0167 Heated oxygen sensor (HO2S) 3, bank 2, heater control â€â€œ circuit malfunction Wiring, HO2S, ECM
P0168 Fuel temperature â€â€œ too high Wiring, fuel temperature sensor, mechanical fault
P0169 Incorrect fuel composition Wiring, fuel temperature sensor, mechanical fault
P0170 Fuel trim (FT), bank 1 â€â€œ malfunction Intake leak, AIR system, fuel pressure/pump, injector(s), EVAP canister purge valve, HO2S
P0171 System too lean, bank 1 Intake/exhaust leak, AIR system, MAF/VAF sensor, fuel pressure/pump, injector(s), HO2S
P0172 System too rich, bank 1 Intake blocked, EVAP canister purge valve, fuel pressure,EGR system, injector(s), HO2S
P0173 Fuel trim (FT), bank 2 â€â€œ malfunction Intake leak, AIR system, fuel pressure/pump, injector(s), EVAP canister purge valve, HO2S
P0174 System too lean, bank 2 Intake/exhaust leak, fuel pressure/pump, injector(s), AIR system, hose connection(s)
P0175 System too rich, bank 2 Intake blocked, EVAP canister purge valve, fuel pressure, EGR system, injector(s), HO2S
P0176 Fuel composition sensor â€â€œ circuit malfunction Wiring, fuel composition sensor, ECM
P0177 Fuel composition sensor â€â€œ range/performance problem Fuel composition sensor
P0178 Fuel composition sensor â€â€œ low input Wiring short to ground, fuel composition sensor, ECM
P0179 Fuel composition sensor â€â€œ high input Wiring short to positive, fuel composition sensor, ECM
P0180 Fuel temperature sensor A â€â€œ circuit malfunction Wiring, fuel temperature sensor, ECM
P0181 Fuel temperature sensor A â€â€œ range/performance problem Fuel temperature sensor
P0182 Fuel temperature sensor A â€â€œ low input Wiring short to ground, fuel temperature sensor, ECM
P0183 Fuel temperature sensor A â€â€œ high input Wiring short to positive, fuel temperature sensor, ECM
P0184 Fuel temperature sensor A â€â€œ circuit intermittent Wiring, poor connection, fuel temperature sensor, ECM
P0185 Fuel temperature sensor B â€â€œ circuit malfunction Wiring, fuel temperature sensor, ECM
P0186 Fuel temperature sensor B â€â€œ range/performance problem Fuel temperature sensor
P0187 Fuel temperature sensor B â€â€œ low input Wiring short to ground, fuel temperature sensor, ECM
P0188 Fuel temperature sensor B â€â€œ high input Wiring short to positive, fuel temperature sensor, ECM
P0189 Fuel temperature sensor B â€â€œ circuit intermittent Wiring, poor connection, fuel temperature sensor, ECM
P0190 Fuel rail pressure (FRP) sensor â€â€œ circuit malfunction Wiring, fuel rail pressure sensor, ECM
P0191 Fuel rail pressure (FRP) sensor â€â€œ range/performance problem Wiring, FRP sensor
P0192 Fuel rail pressure (FRP) sensor â€â€œ low input Wiring short to ground, FRP sensor
P0193 Fuel rail pressure (FRP) sensor â€â€œ high input Wiring short to positive, FRP sensor
P0194 Fuel rail pressure (FRP) sensor â€â€œ circuit intermittent Wiring, poor connection, FRP sensor
P0195 Engine oil temperature (EOT) sensor â€â€œ circuit malfunction Wiring, EOT sensor, ECM
P0196 Engine oil temperature (EOT) sensor â€â€œ range/performance problem EOT sensor
P0197 Engine oil temperature (EOT) sensor â€â€œ low input Wiring short to ground, EOT sensor
P0198 Engine oil temperature (EOT)) sensor â€â€œ high input Wiring short to positive, EOT sensor
P0199 Engine oil temperature (EOT) sensor â€â€œ circuit intermittent Wiring, poor connection, EOT sensor, ECM
P0200 Injector â€â€œ circuit malfunction Wiring, injector, ECM
P0201 Injector 1 â€â€œ circuit malfunction Wiring, injector, ECM
P0202 Injector 2 â€â€œ circuit malfunction Wiring, injector, ECM
P0203 Injector 3 â€â€œ circuit malfunction Wiring, injector, ECM
P0204 Injector 4 â€â€œ circuit malfunction Wiring, injector, ECM
P0205 Injector 5 â€â€œ circuit malfunction Wiring, injector, ECM
P0206 Injector 6 â€â€œ circuit malfunction Wiring, injector, ECM
P0207 Injector 7 â€â€œ circuit malfunction Wiring, injector, ECM
P0208 Injector 8 â€â€œ circuit malfunction Wiring, injector, ECM
P0209 Injector 9 â€â€œ circuit malfunction Wiring, injector, ECM
P0210 Injector 10 â€â€œ circuit malfunction Wiring, injector, ECM
P0211 Injector 11 â€â€œ circuit malfunction Wiring, injector, ECM
P0212 Injector 12 â€â€œ circuit malfunction Wiring, injector, ECM
P0213 Cold start injector 1 â€â€œ circuit malfunction Wiring, cold start injector, ECM
P0214 Cold start injector 2 â€â€œ circuit malfunction Wiring, cold start injector, ECM
P0215 Fuel shut-off solenoid â€â€œ circuit malfunction Wiring, fuel shut-off solenoid, ECM
P0216 Fuel injection timing control â€â€œ circuit malfunction Wiring, fuel injection timing control solenoid, ECM
P0217 Engine over temperature condition Wiring, cooling system, coolant thermostat, ECT sensor
P0218 Transmission over temperature condition Wiring, TFT sensor, ECM
P0219 Engine over speed condition Incorrect gear change
P0220 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B â€â€œ circuit malfunction Wiring, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B â€â€œ circuit malfunction Wiring, TP/APP switch, ECM
P0221 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B â€â€œ range/performance problem Accelerator cable adjustment, TP/APP sensor Throttle position (TP) switch B/accelerator pedal position (APP) switch B â€â€œ range/performance problem Accelerator cable adjustment, TP/APP switch
P0222 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B â€â€œ low input Wiring short to ground, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B â€â€œ low input Wiring short to ground, TP/APP switch, ECM
P0223 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B â€â€œ high input Wiring short to positive, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B â€â€œ high input Wiring short to positive, TP/APP switch, ECM
P0224 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B â€â€œ circuit intermittent Wiring, poor connection, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B â€â€œ circuit intermittent Wiring, poor connection, TP/APP switch, ECM
P0225 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C â€â€œ circuit malfunction Wiring, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C â€â€œ circuit malfunction Wiring, TP/APP switch, ECM
P0226 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C â€â€œ range/performance problem Accelerator cable adjustment, TP/APP sensor Throttle position (TP) switch C/accelerator pedal position (APP) switch C â€â€œ range/performance problem Accelerator cable adjustment, TP/APP switch
P0227 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C â€â€œ low input Wiring short to ground, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C â€â€œ low input Wiring short to ground, TP/APP switch, ECM
P0228 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C â€â€œ high input Wiring short to positive, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C â€â€œ high input Wiring short to positive, TP/APP switch, ECM
P0229 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C â€â€œ circuit intermittent Wiring, poor connection, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C â€â€œ circuit intermittent Wiring, poor connection, TP/APP switch, ECM
P0230 Fuel pump relay â€â€œ circuit malfunction Wiring, fuel pump relay, ECM
P0231 Fuel pump relay â€â€œ circuit low Wiring short to ground, fuel pump relay, ECM
P0232 Fuel pump relay â€â€œ circuit high Wiring short to positive, fuel pump relay, ECM
P0233 Fuel pump relay â€â€œ circuit intermittent Wiring, poor connection, fuel pump relay, ECM
P0234 Engine boost condition â€â€œ limit exceeded Hose connection(s), wiring, TC wastergate regulating valve, TC wastegate
P0235 Engine boost condition â€â€œ limit not reached Hose connection(s), wiring, TC wastergate regulating valve, TC wastegate, TC
P0236 Manifold absolute pressure (MAP) sensor A, TC system â€â€œ range/performance problem Intake/exhaust leak, hose connection(s), MAP sensor
P0237 Manifold absolute pressure (MAP) sensor A, TC system â€â€œ low input Wiring short to ground, MAP sensor, ECM
P0238 Manifold absolute pressure (MAP) sensor A, TC system â€â€œ high input Wiring short to positive, MAP sensor, ECM
P0239 Manifold absolute pressure (MAP) sensor B, TC system â€â€œ circuit malfunction Wiring, MAP sensor, ECM
P0240 Manifold absolute pressure (MAP) sensor B, TC system â€â€œ range/performance problem Intake/exhaust leak, hose connection(s), MAP sensor
P0241 Manifold absolute pressure (MAP) sensor B, TC system â€â€œ low input Wiring short to ground, MAP sensor, ECM
P0242 Manifold absolute pressure (MAP) sensor B, TC system â€â€œ high input Wiring short to positive, MAP sensor, ECM
P0243 Turbocharger (TC) wastegate regulating valve A â€â€œ circuit malfunction Wiring, TC wastegate regulating valve, ECM
P0244 Turbocharger (TC) wastegate regulating valve A â€â€œ range/performance problem TC wastegate regulating valve
P0245 Turbocharger (TC) wastegate regulating valve A â€â€œ circuit low Wiring short to ground, TC wastegate regulating valve, ECM
P0246 Turbocharger (TC) wastegate regulating valve A â€â€œ circuit high Wiring short to positive, TC wastegate regulating valve, ECM
P0247 Turbocharger (TC) wastegate regulating valve B â€â€œ circuit malfunction Wiring, TC wastegate regulating valve, ECM
P0248 Turbocharger (TC) wastegate regulating valve B â€â€œ range/performance problem TC wastegate regulating valve
P0249 Turbocharger (TC) wastegate regulating valve B â€â€œ circuit low Wiring short to ground, TC wastegate regulating valve, ECM
P0250 Turbocharger (TC) wastegate regulating valve B â€â€œ circuit high Wiring short to positive, TC wastegate regulating valve, ECM
P0251 Injection pump A, rotor/cam â€â€œ circuit malfunction Wiring, injection pump, ECM
P0252 Injection pump A, rotor/cam â€â€œ range/performance problem Injection pump
P0253 Injection pump A, rotor/cam â€â€œ circuit low Wiring short to ground, injection pump, ECM
P0254 Injection pump A, rotor/cam â€â€œ circuit high Wiring short to positive, injection pump, ECM
P0255 Injection pump A, rotor/cam â€â€œ circuit intermittent Wiring, poor connection, injection pump, ECM
P0256 Injection pump B, rotor/cam â€â€œ circuit malfunction Wiring, injection pump, ECM
P0257 Injection pump B, rotor/cam â€â€œ range/performance problem Injection pump
P0258 Injection pump B, rotor/cam â€â€œ circuit low Wiring short to ground, injection pump, ECM
P0259 Injection pump B, rotor/cam â€â€œ circuit high Wiring short to positive, injection pump, ECM
P0260 Injection pump B, rotor/cam â€â€œ circuit intermittent Wiring, poor connection, injection pump, ECM
P0261 Injector 1 â€â€œ circuit low Wiring short to ground, injector, ECM
P0262 Injector 1 â€â€œ circuit high Wiring short to positive, injector, ECM
P0263 Cylinder 1 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0264 Injector 2 â€â€œ circuit low Wiring short to ground, injector, ECM
P0265 Injector 2 â€â€œ circuit high Wiring short to positive, injector, ECM
P0266 Cylinder 2 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0267 Injector 3 â€â€œ circuit low Wiring short to ground, injector, ECM
P0268 Injector 3 â€â€œ circuit high Wiring short to positive, injector, ECM
P0269 Cylinder 3 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0270 Injector 4 â€â€œ circuit low Wiring short to ground, injector, ECM
P0271 Injector 4 â€â€œ circuit high Wiring short to positive, injector, ECM
P0272 Cylinder 4 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0273 Injector 5 â€â€œ circuit low Wiring short to ground, injector, ECM
P0274 Injector 5 â€â€œ circuit high Wiring short to positive, injector, ECM
P0275 Cylinder 5 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0276 Injector 6 â€â€œ circuit low Wiring short to ground, injector, ECM
P0277 Injector 6 â€â€œ circuit high Wiring short to positive, injector, ECM
P0278 Cylinder 6 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0279 Injector 7 â€â€œ circuit low Wiring short to ground, injector, ECM
P0280 Injector 7 â€â€œ circuit high Wiring short to positive, injector, ECM
P0281 Cylinder 7 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0282 Injector 8 â€â€œ circuit low Wiring short to ground, injector, ECM
P0283 Injector 8 â€â€œ circuit high Wiring short to positive, injector, ECM
P0284 Cylinder 8 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0285 Injector 9 â€â€œ circuit low Wiring short to ground, injector, ECM
P0286 Injector 9 â€â€œ circuit high Wiring short to positive, injector, ECM
P0287 Cylinder 9 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0288 Injector 10 â€â€œ circuit low Wiring short to ground, injector, ECM
P0289 Injector 10 â€â€œ circuit high Wiring short to positive, injector, ECM
P0290 Cylinder 10 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0291 Injector 11 â€â€œ circuit low Wiring short to ground, injector, ECM
P0292 Injector 11 â€â€œ circuit high Wiring short to positive, injector, ECM
P0293 Cylinder 11 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0294 Injector 12 â€â€œ circuit low Wiring short to ground, injector, ECM
P0295 Injector 12 â€â€œ circuit high Wiring short to positive, injector, ECM
P0296 Cylinder 12 â€â€œ contribution/balance fault Wiring, fuel system, ECM
P0297 Vehicle over-speed condition Wiring, VSS, mechanical fault
P0298 Engine oil temperature â€â€œ too high Wiring, EOT sensor, mechanical fault
P0299 Turbo/super charger â€â€œ low boost Mechanical fault
P0300 Random/multiple cylinder(s) â€â€œ misfire detected Spark plug(s), HT lead(s), injector(s), ignition coil(s),low compression, wiring
P0301 Cylinder 1 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0302 Cylinder 2 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0303 Cylinder 3 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0304 Cylinder 4 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0305 Cylinder 5 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0306 Cylinder 6 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0307 Cylinder 7 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0308 Cylinder 8 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0309 Cylinder 9 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0310 Cylinder 10 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0311 Cylinder 11 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0312 Cylinder 12 â€â€œ misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM
P0313 Misfire detected â€â€œ low fuel level Fuel system, mechanical fault
P0314 Single cylinder misfire â€â€œ cylinder not specified Engine mechanical fault, wiring, ignition/fuel system, injector
P0315 Crankshaft position system â€â€œ variation not learned Engine mechanical fault, wiring
P0316 Misfire dectected during startup â€â€œ first 1000 revolutions Engine mechanical fault, wiring, ignition/fuel system, injector
P0317 Rough road hardware not present Wiring, ECM
P0318 Rough road sensor signal A â€â€œ circuit malfunction Wiring, rough road sensor A, mechanical fault
P0319 Rough road sensor signal B â€â€œ circuit malfunction Wiring, rough road sensor B, mechanical fault
P0320 Crankshaft position (CKP) sensor/engine speed (RPM) sensor â€â€œ circuit malfunction WiringCKP/RPM sensor, ECM
P0321 Crankshaft position (CKP) sensor/engine speed (RPM) sensor â€â€œ range/performance problem Air gap, metal particle contamination, insecure sensor/rotor, wiring, CKP/RPM sensor
P0322 Crankshaft position (CKP) sensor/engine speed (RPM) sensor â€â€œ no signal Wiring, CKP/RPM sensor, ECM
P0323 Crankshaft position (CKP) sensor/engine speed (RPM) sensor â€â€œ circuit intermittent Wiring, poor connection, CKP/RPM sensor, ECM
P0324 Knock control system error Wiring, poor connection, KS, ECM
P0325 Knock sensor (KS) 1, bank 1 â€â€œ circuit malfunction Wiring, poor connection, KS
P0326 Knock sensor (KS) 1, bank 1 â€â€œ range/performance problem Wiring, KS incorrectly tightened, KS
P0327 Knock sensor (KS) 1, bank 1 â€â€œ low input Insecure KS, poor connection, wiring short to ground,incorrectly tightened, KS, ECM
P0328 Knock sensor (KS) 1, bank 1 â€â€œ high input Wiring short to positive, KS incorrectly tightened, KS, ECM
P0329 Knock sensor (KS) 1, bank 1 â€â€œ circuit intermittent Wiring, poor connection, KS, ECM
P0330 Knock sensor (KS) 2, bank 2 â€â€œ circuit malfunction Wiring, KS, ECM
P0331 Knock sensor (KS) 2, bank 2 â€â€œ range/performance problem Wiring, KS incorrectly tightened, KS
P0332 Knock sensor (KS) 2, bank 2 â€â€œ low input Insecure KS, poor connection, wiring short to ground,incorrectly tightened, KS, ECM
P0333 Knock sensor (KS) 2, bank 2 â€â€œ high input Wiring short to positive, KS incorrectly tightened, KS, ECM
P0334 Knock sensor (KS) 2, bank 2 â€â€œ circuit intermittent Wiring, poor connection, KS, ECM
P0335 Crankshaft position (CKP) sensor â€â€œ circuit malfunction Wiring, CKP sensor, ECM
P0336 Crankshaft position (CKP) sensor â€â€œ range/performance problem Insecure sensor/rotor, air gap, wiring, CKP sensor
P0337 Crankshaft position (CKP) sensor â€â€œ low input Wiring short to ground, CKP sensor, ECM
P0338 Crankshaft position (CKP) sensor â€â€œ high input Wiring short to positive, CKP sensor, ECM
P0339 Crankshaft position (CKP) sensorâ€â€œ circuit intermittent Wiring, poor connection, CKP sensor, ECM
P0340 Camshaft position (CMP) sensor A, bank 1 â€â€œ circuit malfunction Wiring, CMP sensor, ECM
P0341 Camshaft position (CMP) sensor A, bank 1 â€â€œ range/performance problem Insecure sensor/rotor, air gap, wiring, CMP sensor
P0342 Camshaft position (CMP) sensor A, bank 1 â€â€œ low input Wiring short to ground, CMP sensor, ECM
P0343 Camshaft position (CMP) sensor A, bank 1 â€â€œ high input Wiring short to positive, CMP sensor, ECM
P0344 Camshaft position (CMP) sensor A, bank 1â€â€œ circuit intermittent Wiring, poor connection, CMP sensor, ECM
P0345 Camshaft position (CMP) sensor A, bank 2 â€â€œ circuit malfunction Wiring, CMP sensor, ECM
P0346 Camshaft position (CMP) sensor A, bank 2 â€â€œ range/performance problem Insecure sensor/rotor, air gap, wiring, CMP sensor
P0347 Camshaft position (CMP) sensor A, bank 2 â€â€œ low input Wiring short to ground, CMP sensor, ECM
P0348 Camshaft position (CMP) sensor A, bank 2 â€â€œ high input Wiring short to positive, CMP sensor, ECM
P0349 Camshaft position (CMP) sensor A, bank 2â€â€œ circuit intermittent Wiring, poor connection, CMP sensor, ECM
P0350 Ignitiion coil, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0351 Ignitiion coil A, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0352 Ignitiion coil B, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0353 Ignitiion coil C, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0354 Ignitiion coil D, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0355 Ignitiion coil E, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0356 Ignitiion coil F, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0357 Ignitiion coil G, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0358 Ignitiion coil H, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0359 Ignitiion coil I, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0360 Ignitiion coil J, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0361 Ignitiion coil K, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0362 Ignitiion coil L, primary/secordary â€â€œ circuit malfunction Wiring, ignition coil, ECM
P0363 Misfire detected â€â€œ fueling disabled Fuel system, mechanical fault
P0365 Camshaft position (CMP) sensor B, bank 1 â€â€œ circuit malfunction Wiring, poor connection, CMP sensor, ECM
P0366 Camshaft position (CMP) sensor B, bank 1 â€â€œ range/performance problem Wiring, poor connection, CMP sensor
P0367 Camshaft position (CMP) sensor B, bank 1 â€â€œ low input Wiring short to ground, CMP sensor, ECM
P0368 Camshaft position (CMP) sensor B, bank 1 â€â€œ high input Wiring short to positive, CMP sensor, ECM
P0369 Camshaft position (CMP) sensor B, bank 1â€â€œ circuit intermittent Wiring, poor connection, ECM
P0370 Timing reference, high resolution signal A â€â€œ malfunction Wiring, CKP/RPM/CMP sensor, ECM
P0371 Timing reference, high resolution signal A â€â€œ too many pulses Wiring, CKP/RPM/CMP sensor, ECM
P0372 Timing reference, high resolution signal A â€â€œ too few pulses Wiring, CKP/RPM/CMP sensor, ECM
P0373 Timing reference, high resolution signal A â€â€œ intermittent erratic pulses Wiring, poor connection, CKP/RPM/CMP sensor, ECM
P0374 Timing reference, high resolution signal A â€â€œ no pulses Wiring, CKP/RPM/CMP sensor, ECM
P0375 Timing reference, high resolution signal B â€â€œ malfunction Wiring, CKP/RPM/CMP sensor, ECM
P0376 Timing reference, high resolution signal B â€â€œ too many pulses Wiring, CKP/RPM/CMP sensor, ECM
P0377 Timing reference, high resolution signal B â€â€œ too few pulses Wiring, CKP/RPM/CMP sensor, ECM
P0378 Timing reference, high resolution signal B â€â€œ intermittent erratic pulses Wiring, poor connection, CKP/RPM/CMP sensor, ECM
P0379 Timing reference, high resolution signal B â€â€œ no pulses Wiring, CKP/RPM/CMP sensor, ECM
P0380 Glow plugs, circuit A â€â€œ malfunction Wiring, glow plug relay, fuse, glow plugs, ECM
P0381 Glow plug warning lamp â€â€œ circuit malfunction Wiring, glow plug warning lamp, ECM
P0382 Glow plugs, circuit B â€â€œ malfunction Wiring, glow plug relay, fuse, glow plugs, ECM
P0385 Crankshaft position (CKP) sensor B â€â€œ circuit malfunction Wiring, CKP sensor, ECM
P0386 Crankshaft position (CKP) sensor B â€â€œ range/performance problem Insecure sensor/rotor, air gap, wiring, CKP sensor
P0387 Crankshaft position (CKP) sensor B â€â€œ low input Wiring short to ground, CKP sensor, ECM
P0388 Crankshaft position (CKP) sensor B â€â€œ high input Wiring short to positive, CKP sensor, ECM
P0389 Crankshaft position (CKP) sensor B â€â€œ circuit intermittent Wiring, poor connection, CKP sensor, ECM
P0390 Camshaft position (CMP) sensor B, bank 2 â€â€œ circuit malfunction Wiring, poor connection, CMP sensor, ECM
P0391 Camshaft position (CMP) sensor B, bank 2 â€â€œ circuit range/performance problem Wiring, poor connection, CMP sensor
P0392 Camshaft position (CMP) sensor B, bank 2 â€â€œ circuit low input Wiring short to ground, CMP sensor, ECM
P0393 Camshaft position (CMP) sensor B, bank 2 â€â€œ circuit high input Wiring short to positive, CMP sensor, ECM
P0394 Camshaft position (CMP) sensor B, bank 2â€â€œ circuit intermittent Wiring, poor connection, ECM
P0400 Exhaust gas recirculation (ERG) system â€â€œ flow malfunction Hose leak/blockage, basic setting not carried out (if applicable), wiring, EGR valve, EGR solenoid, ECM
P0401 Exhaust gas recirculation (ERG) system â€â€œ insufficient flow detected Hose leak/blockage, basic setting not carried out (if applicable), wiring, EGR valve, EGR solenoid, ECM
P0402 Exhaust gas recirculation (ERG) system â€â€œ excessive flow detected Hose leak/blockage, basic setting not carried out (if applicable), wiring, EGR valve, EGR solenoid, ECM
P0403 Exhaust gas recirculation (ERG) system â€â€œ circuit malfunction Wiring, EGR solenoid, ECM
P0404 Exhaust gas recirculation (ERG) system â€â€œ range/performance problem Hose leak/blockage, wiring, EGR valve/solenoid
P0405 Exhaust gas recirculation (ERG) valve position sensor A â€â€œ low input Wiring short to ground, EGR valve position sensor, ECM
P0406 Exhaust gas recirculation (ERG) valve position sensor A â€â€œ high input Wiring short to positive, EGR valve position sensor, ECM
P0407 Exhaust gas recirculation (ERG) valve position sensor B â€â€œ low input Wiring short to ground, EGR valve position sensor, ECM
P0408 Exhaust gas recirculation (ERG) valve position sensor B â€â€œ high input Wiring short to positive, EGR valve position sensor, ECM
P0409 Exhaust gas recirculation (ERG) sensor A â€â€œ circuit malfunction Wiring, poor connection, EGR sensor, ECM
P0410 Secondary air injection (AIR) system â€â€œ malfunction Wiring, AIR valve, AIR solenoid, ECM
P0411 Secondary air injection (AIR) system â€â€œ incorrect flow detected AIR pump, AIR valve, AIR hose(s)
P0412 Secondary air injection (AIR) solenoid A â€â€œ circuit malfunction Wiring, AIR solenoid, ECM
P0413 Secondary air injection (AIR) solenoid A â€â€œ open circuit Wiring open circuit, AIR solenoid, ECM
P0414 Secondary air injection (AIR) solenoid A â€â€œ short circuit Wiring short circuit, AIR solenoid, ECM
P0415 Secondary air injection (AIR) solenoid B â€â€œ circuit malfunction Wiring, AIR solenoid, ECM
P0416 Secondary air injection (AIR) solenoid B â€â€œ open circuit Wiring open circuit, AIR solenoid, ECM
P0417 Secondary air injection (AIR) solenoid B â€â€œ short circuit Wiring short circuit, AIR solenoid, ECM
P0418 Secondary air injection (AIR) pump relay A â€â€œ circuit malfunction Wiring, AIR pump relay, ECM
P0419 Secondary air injection (AIR) pump relay B â€â€œ circuit malfunction Wiring, AIR pump relay, ECM
P0420 Catalytic converter system, bank 1 â€â€œ efficiency below threshold Catalytic converter, wiring, HO2S 2
P0421 Warm up catalytic converter, bank 1 â€â€œ efficiency below threshold Catalytic converter, wiring, HO2S 2
P0422 Main catalytic converter, bank 1 â€â€œ efficiency below threshold Catalytic converter, wiring, HO2S 2
P0423 Heated catalytic converter, bank 1 â€â€œ efficiency below threshold Catalytic converter, wiring, HO2S 2
P0424 Heated catalytic converter, bank 1 â€â€œ temperature below threshold Catalytic converter, wiring, HO2S 2
P0425 Catalytic converter temperature sensor, bank 1 Wiring, poor connection, catalytic converter temperature sensor, ECM
P0426 Catalytic converter temperature sensor, bank 1 â€â€œ range/performance Wiring, poor connection, catalytic converter temperature sensor, ECM
P0427 Catalytic converter temperature sensor, bank 1 â€â€œ low input Wiring short to ground, catalytic converter temperature sensor, ECM
P0428 Catalytic converter temperature sensor, bank 1 â€â€œ high input Wiring short to positive, catalytic converter temperature sensor, ECM
P0429 Catalytic converter heater, bank 1 â€â€œ control circuit malfunction Wiring, relay, ECM
P0430 Catalytic converter system, bank 2 â€â€œ efficiency below threshold Catalytic converter, wiring, HO2S 2
P0431 Warm up catalytic converter, bank 2 â€â€œ efficiency below threshold Catalytic converter, wiring, HO2S 2
P0432 Main catalytic converter, bank 2 â€â€œ efficiency below threshold Catalytic converter, wiring, HO2S 2
P0433 Heated catalytic converter, bank 2 â€â€œ efficiency below threshold Catalytic converter, wiring, HO2S 2
P0434 Heated catalytic converter, bank 2 â€â€œ temperature below threshold Catalytic converter, wiring, HO2S 2
P0435 Catalytic converter temperature sensor, bank 2 Wiring, poor connection, catalytic converter temperature sensor, ECM
P0436 Catalytic converter temperature sensor, bank 2 â€â€œ range/performance Wiring, poor connection, catalytic converter temperature sensor, ECM
P0437 Catalytic converter temperature sensor, bank 2 â€â€œ low input Wiring short to ground, catalytic converter temperature sensor, ECM
P0438 Catalytic converter temperature sensor, bank 2 â€â€œ high input Wiring short to positive, catalytic converter temperature sensor, ECM
P0439 Catalytic converter heater, bank 2 â€â€œ control circuit malfunction Wiring, relay, ECM
P0440 Evaporative emission (EVAP) system â€â€œ malfunction Hose connection(s), intake leak, EVAP canister purge valve
P0441 Evaporative emission (EVAP) system â€â€œ incorrect flow detected Hose connection(s), intake leak, EVAP canister purge valve
P0442 Evaporative emission (EVAP) system â€â€œ small leak detected Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve
P0443 Evaporative emission (EVAP) canister purge valve â€â€œ circuit malfunction Wiring, EVAP canister purge valve, ECM
P0444 Evaporative emission (EVAP) canister purge valve â€â€œ open circuit Wiring open circuit, EVAP canister purge valve, ECM
P0445 Evaporative emission (EVAP) canister purge valve â€â€œ short circuit Wiring short circuit, EVAP canister purge valve, ECM
P0446 Evaporative emission (EVAP) system, vent control â€â€œ circuit malfunction Wiring, EVAP canister purge valve, ECM
P0447 Evaporative emission (EVAP) system, vent control â€â€œ open circuit Wiring open circuit, EVAP canister purge valve, ECM
P0448 Evaporative emission (EVAP) system, vent control â€â€œ short circuit Wiring short circuit, EVAP canister purge valve, ECM
P0449 Evaporative emission (EVAP) system, vent valve â€â€œ circuit malfunction Wiring, EVAP canister purge valve, ECM
P0450 Evaporative emission (EVAP) pressure sensor â€â€œ circuit malfunction Wiring, EVAP pressure sensor, ECM
P0451 Evaporative emission (EVAP) pressure sensor â€â€œ range/performance problem EVAP pressure sensor
P0452 Evaporative emission (EVAP) pressure sensor â€â€œ low input Wiring short to ground, EVAP pressure sensor, ECM
P0453 Evaporative emission (EVAP) pressure sensor â€â€œ high input Wiring short to positive, EVAP pressure sensor, ECM
P0454 Evaporative emission (EVAP) pressure sensor â€â€œ circuit intermittent Wiring, poor connection, EVAP pressure sensor, ECM
P0455 Evaporative emission (EVAP) system â€â€œ large leak detected Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve
P0456 Evaporative emission system â€â€œ very small leak detected Mechanical fault, hose connection(s), EVAP pressure sensor
P0457 Evaporative emission system â€â€œ leak detected (fuel cap loose/off) Mechanical fault, hose connection(s), EVAP pressure sensor
P0458 Evaporative emission system, purge control valve â€â€œ circuit low Wiring short to ground, EVAP valve
P0459 Evaporative emission system, purge control valve â€â€œ circuit high Wiring short to positive, EVAP valve
P0460 Fuel tank level sensor â€â€œ circuit malfunction Wiring, fuel tank level sensor, ECM
P0461 Fuel tank level sensor â€â€œ range/performance problem Wiring, fuel tank level sensor
P0462 Fuel tank level sensor â€â€œ low input Wiring short to ground, fuel tank level sensor, ECM
P0463 Fuel tank level sensor â€â€œ high input Wiring short to positive, fuel tank level sensor, ECM
P0464 Fuel tank level sensor â€â€œ circuit intermittent Wiring, poor connection, fuel tank level sensor, ECM
P0465 Evaporative emission (EVAP) canister purge flow sensor â€â€œ circuit malfunction Wiring, EVAP canister purge flow sensor, ECM
P0466 Evaporative emission (EVAP) canister purge flow sensor â€â€œ range/performance problem EVAP canister purge flow sensor
P0467 Evaporative emission (EVAP) canister purge flow sensor â€â€œ low input Wiring short to ground, EVAP canister purge flow sensor, ECM
P0468 Evaporative emission (EVAP) canister purge flow sensor â€â€œ high input Wiring short to positive, EVAP canister purge flow sensor, ECM
P0469 Evaporative emission (EVAP) canister purge flow sensor â€â€œ circuit intermittent Wiring, poor connection, EVAP canister purge flow sensor, ECM
P0470 Exhaust gas pressure sensor â€â€œ circuit malfunction Wiring, exhaust gas pressure sensor, ECM
P0471 Exhaust gas pressure sensor â€â€œ range/performance problem Exhaust gas pressure sensor
P0472 Exhaust gas pressure sensor â€â€œ low input Wiring short to ground, exhaust gas pressure sensor, ECM
P0473 Exhaust gas pressure sensor â€â€œ high input Wiring short to positive, exhaust gas pressure sensor, ECM
P0474 Exhaust gas pressure sensor â€â€œ circuit intermittent Wiring, poor connection, exhaust gas pressure sensor, ECM
P0475 Exhaust gas pressure control valve â€â€œ circuit malfunction Wiring, exhaust gas pressure control valve, ECM
P0476 Exhaust gas pressure control valve â€â€œ range/performance problem Exhaust gas control valve sensor
P0477 Exhaust gas pressure control valve â€â€œ low input Wiring short to ground, exhaust gas control valve sensor, ECM
P0478 Exhaust gas pressure control valve â€â€œ high input Wiring short to positive, exhaust gas control valve sensor, ECM
P0479 Exhaust gas pressure control valve â€â€œ circuit intermittent Wiring, poor connection, exhaust gas control valve sensor, ECM
P0480 Engine coolant blower motor 1 â€â€œ circuit malfunction Wiring, engine coolant blower motor, ECM
P0481 Engine coolant blower motor 2 â€â€œ circuit malfunction Wiring, engine coolant blower motor, ECM
P0482 Engine coolant blower motor 3 â€â€œ circuit malfunction Wiring, engine coolant blower motor, ECM
P0483 Engine coolant blower motor, rationality check â€â€œ malfunction Wiring, engine coolant blower motor, ECM
P0484 Engine coolant blower motor â€â€œ circuit over current Wiring, engine coolant blower motor, ECM
P0485 Engine coolant blower motor, power/earth â€â€œ circuit malfunction Wiring, engine coolant blower motor, ECM
P0486 Exhaust gas recirculation (EGR) valve poistion sensor B â€â€œ circuit malfunction Wiring, poor connection, EGR valve position sensor, ECM
P0487 Exhaust gas recirculation (EGR) system, throttle position control â€â€œ circuit malfunction Wiring, poor connection, ECM
P0488 Exhaust gas recirculation (EGR) system, throttle position control â€â€œ range/performance Wiring, poor connection, ECM
P0489 Exhaust gas recirculation (EGR) system â€â€œ circuit low Wiring short to ground, EGR valve
P0490 Exhaust gas recirculation (EGR) system â€â€œ circuit high Wiring short to posistive, EGR valve
P0491 Secondary air injection system, bank 1 â€â€œ malfunction Wiring, AIR solenoid, hose connections, mechanical fault
P0492 Secondary air injection system, bank 2 â€â€œ malfunction Wiring, AIR solenoid, hose connections, mechanical fault
P0493 Fan over-speed (clutch locked) Fan clutch, mechanical fault
P0494 Fan speed â€â€œ low Wiring, relay, fan motor, mechanical fault
P0495 Fan speed â€â€œ high Wiring, relay, fan motor, mechanical fault
P0496 Evaporative emission system â€â€œ high purge flow Wiring, EVAP valve, mechanical fault
P0497 Evaporative emission system â€â€œ low purge flow Wiring, EVAP valve, hoses blocked, mechanical fault
P0498 Evaporative emission system, vent control â€â€œ circuit low Wiring, short to gound, EVAP valve
P0499 Evaporative emission system, vent control â€â€œ circuit high Wiring, short to positive, EVAP valve
P0500 Vehicle speed sensor (VSS) â€â€œ circuit malfunction Wiring, VSS, ECM
P0501 Vehicle speed sensor (VSS) â€â€œ range/performance problem Wiring, speedometer, VSS, CAN data bus
P0502 Vehicle speed sensor (VSS) â€â€œ low input Wiring short to ground, VSS, ECM
P0503 Vehicle speed sensor (VSS) â€â€œ intermittent/erratic/high input Wiring, poor connection, other connected system, insturment panel, VSS
P0504 Brake switch â€â€œ A/B correlation Wiring, mechanical fault
P0505 Idle speed control (ISC) system â€â€œ malfunction Wiring, ISC acutator/IAC valve, throttle motor, throttle valve tight/sticking, ECM
P0506 Idle speed control (ISC) system â€â€œ rpm lower than expected Wiring, ISC acutator/IAC valve, throttle motor, throttle valve tight/sticking, ECM
P0507 Idle speed control (ISC) system â€â€œ rpm higher than expected Wiring, ISC acutator/IAC valve, throttle motor, throttle valve tight/sticking, ECM
P0508 Idle air control (IAC) system â€â€œ circuit low Wiring short to ground, IAC valve, ECM
P0509 Idle air control (IAC) system â€â€œ circuit high Wiring short to positive, IAC valve, ECM
P0510 Closed throttle position (CTP) switch â€â€œ circuit malfunction Wiring, CTP switch, ECM
P0511 Idle air control (IAC) system â€â€œ circuit malfunction Wiring, poor connection, IAC valve, ECM
P0512 Starter request circuit â€â€œ malfunction Wiring, immobilizer system, relay
P0513 Incorrect immobilizer key Immobilizer system
P0514 Battery temperature sensor â€â€œ circuit range/performance Wiring, poor connection, battery temperature sensor
P0515 Battery temperature sensor â€â€œ circuit malfunction Wiring, poor connection, battery temperature sensor
P0516 Battery temperature sensor â€â€œ circuit low Wiring, short to ground, battery temperature sensor, ECM
P0517 Battery temperature sensor â€â€œ circuit high Wiring, short to positive, battery temperature sensor, ECM
P0518 Idle air control (IAC) system â€â€œ circuit intermittent Wiring, poor connection, IAC valve, ECM
P0519 Idle air control (IAC) system â€â€œ circuit performance Wiring, poor connection, IAC valve, ECM
P0520 Engine oil pressure sensor/switch â€â€œ circuit malfunction Wiring, engine oil pressure sensor/switch, ECM
P0521 Engine oil pressure sensor/switch â€â€œ range/performance problem Engine oil pressure sensor/switch
P0522 Engine oil pressure sensor/switch â€â€œ low voltage Wiring short to ground, engine oil pressure sensor/switch, ECM
P0523 Engine oil pressure sensor/switch â€â€œ high voltage Wiring short to positive, engine oil pressure sensor/switch, ECM
P0524 Engine oil pressure too low Mechanical fault
P0525 Cruise control, servo control â€â€œ circuit range/performance Wiring, poor connection, cruise control servo
P0526 Fan speed sensor â€â€œ circuit malfunction Wiring, poor connection, fan speed sensor, ECM
P0527 Fan speed sensor â€â€œ circuit range/performance Wiring, poor connection, fan speed sensor
P0528 Fan speed sensor â€â€œ no signal Wiring, poor connection, fan speed sensor, ECM
P0529 Fan speed sensor â€â€œ circuit intermittent Wiring, poor connection, ECM
P0530 AC refrigerant pressure sensor â€â€œ circuit malfunction Wiring, AC refrigerant pressure sensor, ECM
P0531 AC refrigerant pressure sensor â€â€œ range/performance problem AC refrigerant pressure sensor
P0532 AC refrigerant pressure sensor â€â€œ low input AC refrigerant pressure too low (incorrectly charged), wiring, AC refrigerant pressure sensor, ECM
P0533 AC refrigerant pressure sensor â€â€œ high input AC refrigerant pressure too high (cooling fault/incorrectly charged), wiring, AC refrigerant pressure sensor, ECM
P0534 AC refrigerant charge loss AC leak, wiring, AC refrigerant pressure sensor
P0535 AC evaporator temperature sensor â€â€œ circuit malfunction Wiring, poor connection, A/C evaporator temperature sensor, ECM
P0536 AC evaporator temperature sensor â€â€œ range/performance problem Wiring, poor connection, A/C evaporator temperature sensor, ECM
P0537 AC evaporator temperature sensor â€â€œ circuit low Wiring, short to gound, A/C evaporator temperature sensor, ECM
P0538 AC evaporator temperature sensor â€â€œ circuit high Wiring, short to positive, A/C evaporator temperature sensor, ECM
P0539 AC evaporator temperature sensor â€â€œ circuit intermittent Wiring, poor connection, A/C evaporator temperature sensor, ECM
P0540 Intake air heater A â€â€œ circuit malmunction Wiring, relay, intake air heater
P0541 Intake air heater A â€â€œ circuit low Wiring short to ground, intake air heater
P0542 Intake air heater A â€â€œ circuit high Wiring short to positive, intake air heater
P0543 Intake air heater A â€â€œ circuit open Wiring, intake air heater
P0544 Exhaust gas recirculation temperature (EGRT) sensor, bank 1 â€â€œ circuit malfunction Wiring, EGRT sensor, ECM
P0545 Exhaust gas recirculation temperature (EGRT) sensor, bank 1 â€â€œ low input Wiring short to ground, EGRT sensor, ECM
P0546 Exhaust gas recirculation temperature (EGRT) sensor, bank 1 â€â€œ high input Wiring short to positive, EGRT sensor, ECM
P0547 Exhaust gas temperature sensor, bank 2 sensor 1 â€â€œ circuit malfunction Wiring, poor connection, exhaust gas temperature sensor, ECM
P0548 Exhaust gas temperature sensor, bank 2 sensor 1 â€â€œ circuit low Wiring short to ground, exhaust gas temperature sensor, ECM
P0549 Exhaust gas temperature sensor, bank 2 sensor 1 â€â€œ circuit high Wiring short to positive, exhaust gas temperature sensor, ECM
P0550 Power steering pressure (PSP) sensor/switch â€â€œ circuit malfunction Wiring, PSP sensor/switch, ECM
P0551 Power steering pressure (PSP) sensor/switch â€â€œ range/performance problem PAS system, PSP sensor/switch
P0552 Power steering pressure (PSP) sensor/switch â€â€œ low input Wiring short to ground, PSP sensor/switch, ECM
P0553 Power steering pressure (PSP) sensor/switch â€â€œ high input Wiring short to positive, PSP sensor/switch, ECM
P0554 Power steering pressure (PSP) sensor/switch â€â€œ circuit intermittent Wiring, poor connection, PSP sensor/switch, ECM
P0555 Brake booster pressure sensor â€â€œ circuit malfunction Wiring, poor connection, brake booster pressure sensor, ECM
P0556 Brake booster pressure sensor â€â€œ circuit range/performance Wiring, poor connection, brake booster pressure sensor, ECM
P0557 Brake booster pressure sensor â€â€œ circuit low input Wiring short to ground, brake booster pressure sensor, ECM
P0558 Brake booster pressure sensor â€â€œ circuit high input Wiring short to positive, brake booster pressure sensor, ECM
P0559 Brake booster pressure sensor â€â€œ circuit intermittent Wiring, poor connection, brake booster pressure sensor, ECM
P0560 System voltage â€â€œ malfunction Wiring, poor connection, battery, alternator
P0561 System voltage â€â€œ unstable Wiring, poor connection, battery, alternator
P0562 System voltage â€â€œ low Wiring, poor connection, battery, alternator
P0563 System voltage â€â€œ high Alternator
P0564 Cruise control system, multi-function input A â€â€œ circuit malfunction Wiring poor connection, multi-function switch, mechanical fault
P0565 Cruise control master switch, ON signal â€â€œ malfunction Wiring, cruise control master switch, ECM
P0566 Cruise control master switch, OFF signal â€â€œ malfunction Wiring, cruise control master switch, ECM
P0567 Cruise control master switch, RESUME signal â€â€œ malfunction Wiring, cruise control master switch, ECM
P0568 Cruise control master switch, SET signal â€â€œ malfunction Wiring, cruise control master switch, ECM
P0569 Cruise control master switch, COAST signal â€â€œ malfunction Wiring, cruise control master switch, ECM
P0570 Cruise control system, APP sensor signal â€â€œ malfunction Wiring, APP sensor, ECM
P0571 Cruise/brake switch A â€â€œ circuit malfunction Wiring, cruise/brake switch, ECM
P0572 Cruise/brake switch A â€â€œ circuit low Wiring short to ground, cruise/brake switch, ECM
P0573 Cruise/brake switch A â€â€œ circuit high Wiring short to positive, cruise/brake switch, ECM
P0574 Cruise control system â€â€œvehicle speed too high Mechanical fault
P0575 Cruise control system â€â€œ input circuit malfunction Wiring, poor connection, mechanical fault, ECM
P0576 Cruise control system â€â€œ input circuit low Wiring short to ground
P0577 Cruise control system â€â€œ input circuit high Wiring short to positive
P0578 Cruise control system, multi-function input A â€â€œ circuit stuck Wiring, poor connection, multi-function switch, mechanical fault
P0579 Cruise control system, multi-function input A â€â€œ circuit range/performance Wiring, poor connection, multi-function switch, mechanical fault
P0580 Cruise control system, multi-function input A â€â€œ circuit low Wiring short to ground, multi-function switch, mechanical fault
P0581 Cruise control system, multi-function input A â€â€œ circuit high Wiring short to positive, multi-function switch, mechanical fault
P0582 Cruise control system, vacuum control â€â€œ circuit open Wiring, vacuum control solenoid
P0583 Cruise control system, vacuum control â€â€œ circuit low Wiring short to ground, vacuum control solenoid
P0584 Cruise control system, vacuum control â€â€œ circuit high Wiring short to positive, vacuum control solenoid
P0585 Cruise control system, multi-function input A/B â€â€œ correlation Mechanical fault
P0586 Cruise control system, vent control â€â€œ circuit open Wiring, vent control solenoid
P0587 Cruise control system, vent control â€â€œ circuit low Wiring short to ground, vent control solenoid
P0588 Cruise control system, vent control â€â€œ circuit high Wiring short to positive, vent control solenoid
P0589 Cruise control system, multi-function input B â€â€œ circuit malfunction Wiring, poor connection, multi-function switch, mechanical fault
P0590 Cruise control system, multi-function input B â€â€œ circuit stuck Wiring, poor connection, multi-function switch, mechanical fault
P0591 Cruise control system, multi-function input B â€â€œ circuit range/performance Wiring, poor connection, multi-function switch, mechanical fault
P0592 Cruise control system, multi-function input B â€â€œ circuit low Wiring short to ground, multi-function switch, mechanical fault
P0593 Cruise control system, multi-function input B â€â€œ circuit high Wiring short to positive, multi-function switch, mechanical fault
P0594 Cruise control system, servo control â€â€œ circuit open Wiring, servo control solenoid
P0595 Cruise control system, servo control â€â€œ circuit low Wiring short to ground, servo control solenoid
P0596 Cruise control system, servo control â€â€œ circuit high Wiring short to positive, servo control solenoid
P0597 Thermostat heater control system â€â€œ circuit open Wiring, relay, thermostat heater
P0598 Thermostat heater control system â€â€œ circuit low Wiring short to ground, relay, thermostat heater
P0599 Thermostat heater control system â€â€œ circuit high Wiring short to positive, relay, thermostat heater
P0600 CAN date bus â€â€œ malfunction Wiring, connected system, ECM
P0601 Engine control module (ECM) â€â€œ memory check sum error ECM
P0602 Engine control module (ECM) â€â€œ programming error ECM
P0603 Engine control module (ECM) â€â€œ KAM error ECM
P0604 Engine control module (ECM) â€â€œ RAM error ECM
P0605 Engine control module (ECM) â€â€œ ROM error ECM
P0606 Engine control module (ECM) â€â€œ processor fault ECM
P0607 Control module â€â€œ performance Control module
P0608 Engine control module (ECM), VSS output A â€â€œ malfunction ECM
P0609 Engine control module (ECM), VSS output B â€â€œ malfunction ECM
P0610 Control module â€â€œ vehicle options error Control module
P0611 Fuel injector control module â€â€œ performance Fuel injector control module
P0612 Fuel injector control module â€â€œ relay control circuit Wiring, relay,fuel injector control module
P0613 Transmission control module (TCM) processor error TCM
P0614 Engine control module (ECM)/Transmission control module (TCM) â€â€œ mismatch ECM/TCM
P0615 Starter relay â€â€œ circuit malfunction Wiring, poor connection, starter relay, ECM
P0616 Starter relay â€â€œ circuit low Wiring short to ground, starter relay, ECM
P0617 Starter relay â€â€œ circuit high Wiring short to positive, starter relay, ECM
P0618 Alternative fuel control module â€â€œ KAM error alternative fuel control module
P0619 Alternative fuel control module â€â€œ RAM/ROM error alternative fuel control module
P0620 Alternator, control â€â€œ circuit malfunction Wiring, alternator, battery, ECM
P0621 Alternator warning lampâ€â€œ circuit malfunction Wiring, alternator warning lamp, ECM
P0622 Alternator, field control â€â€œ circuit malfunction Wiring, alternator, battery, ECM
P0623 Generator lamp control â€â€œ circuit malfunction Wiring, poor connection, bulb, ECM
P0624 Fuel cap lamp control â€â€œ circuit malfunction Wiring, poor connection, bulb, ECM
P0625 Generator field terminal â€â€œ circuit low Wiring short to ground, generator
P0626 Generator field terminal â€â€œ circuit high Wiring short to positive, generator
P0627 Fuel pump control â€â€œ circuit open Wiring, relay, fuel pump
P0628 Fuel pump control â€â€œ circuit low Wiring short to ground, relay, fuel pump
P0629 Fuel pump control â€â€œ circuit high Wiring short to positive, relay, fuel pump
P0630 VIN not programmed or mismatch â€â€œ ECM ECM
P0631 VIN not programmed or mismatch â€â€œ TCM TCM
P0632 Odometer not programmed â€â€œ ECM ECM
P0633 Immobilizer key not programmed â€â€œ ECM ECM
P0634 ECM/TCM â€â€œ internal termperature too high Mechanical fault, ECM/TCM
P0635 Power steering (PAS) control â€â€œ circuit malfunction Wiring, poor connection, PAS pressure switch, ECM
P0636 Power steering (PAS) control â€â€œ circuit low Wiring short to ground, PAS pressure switch, ECM
P0637 Power steering (PAS) control â€â€œ circuit high Wiring short to positive, PAS pressure switch, ECM
P0638 Throttle actuator control, bank 1 â€â€œ range/performance problem Basic setting not carried out (if applicable), ISC actuator/throttle
motor, APP sensor
P0639 Throttle actuator control, bank 2 â€â€œ range/performance Wiring, throttle control unit
P0640 Intake air heater control â€â€œ circuit malfunction Wiring, relay, intake air heater
P0641 Sensor reference voltage A â€â€œ circuit open Wiring short to positive
P0642 Engine control module (ECM), knock control â€â€œ defective ECM
P0643 Sensor reference voltage A â€â€œ circuit high Wiring short to positive
P0644 Driver display, serial communication â€â€œ circuit malfunction Wiring, CAN data bus, ECM
P0645 Air conditioning (AC) Wiring, AC system
P0646 A/C clutch relay control â€â€œ circuit low Wiring short to ground, A/C clutch relay
P0647 A/C clutch relay control â€â€œ circuit high Wiring short to positive, A/C clutch relay
P0648 Immobilizer lamp control â€â€œ circuit malfunction Wiring, poor connection, bulb, ECM
P0649 Cruise control lamp control â€â€œ circuit Wiring, poor connection, bulb, ECM
P0650 Malfunction indicator lamp (MIL) â€â€œ circuit malfunction Wiring, MIL, ECM
P0651 Sensor reference voltage B â€â€œ circuit open Wiring short to positive
P0652 Sensor reference voltage B â€â€œ circuit low Wiring short to ground
P0653 Sensor reference voltage B â€â€œ circuit high Wiring short to positive
P0654 Engine rpm, output â€â€œ circuit malfunction Wiring, ECM
P0655 Engine hot lamp output â€â€œ circuit malfunction Wiring, engine hot lamp, ECM
P0656 Fuel level output â€â€œ circuit malfunction Wiring, ECM
P0657 Actuator supply voltage â€â€œ circuit open Wiring
P0658 Actuator supply voltage â€â€œ circuit low Wiring short to ground, actuator
P0659 Actuator supply voltage â€â€œ circuit high Wiring short to positive, actuator
P0660 Intake manifold tuning valve, bank 1 â€â€œ circuit open Wiring, intake manifold tuning valve
P0661 Intake manifold tuning valve, bank 1 â€â€œ circuit low Wiring short to ground, intake manifold tuning valve
P0662 Intake manifold tuning valve, bank 1 â€â€œ circuit high Wiring short to positive, intake manifold tuning valve
P0663 Intake manifold tuning valve, bank 2 â€â€œ circuit open Wiring, intake manifold tuning valve
P0664 Intake manifold tuning valve, bank 2 â€â€œ circuit low Wiring short to ground, intake manifold tuning valve
P0665 Intake manifold tuning valve, bank 2 â€â€œ circuit high Wiring short to positive, intake manifold
P0666 ECM/TCM internal termperature sensor â€â€œ circuit malfunction Wiring, poor connection, internal temperature sensor, ECM/TCM
P0667 ECM/TCM internal termperature sensor â€â€œ range/performance Wiring, poor connection, internal temperature sensor, ECM/TCM
P0668 ECM/TCM internal termperature sensor â€â€œ circuit low Wiring short to ground, internal temperature sensor, ECM/TCM
P0669 ECM/TCM internal termperature sensor â€â€œ circuit high Wiring short to positive, internal temperature sensor, ECM/TCM
P0670 Glow plug module control â€â€œ circuit malfunction Wiring, poor connection, control module, glow plug, ECM
P0671 Glow plug, cylinder 1 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0672 Glow plug, cylinder 2 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0673 Glow plug, cylinder 3 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0674 Glow plug, cylinder 4 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0675 Glow plug, cylinder 5 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0676 Glow plug, cylinder 6 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0677 Glow plug, cylinder 7 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0678 Glow plug, cylinder 8 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0679 Glow plug, cylinder 9 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0680 Glow plug, cylinder 10 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0681 Glow plug, cylinder 11 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0682 Glow plug, cylinder 12 â€â€œ circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM
P0683 Glow plug control module communication to ECM â€â€œ malfunction Wiring, poor connection, control module, ECM
P0684 Glow plug control module communication to ECM â€â€œ range/performance Wiring, poor connection, control module, ECM
P0685 ECM power relay control â€â€œ circuit open Wiring, ECM relay
P0686 ECM power relay control â€â€œ circuit low Wiring short to ground, ECM relay, ECM
P0687 Engine control relay â€â€œ short to ground Wiring short to ground, engine control relay, ECM
P0688 Engine control relay â€â€œ short to positive Wiring short to positive, engine control relay, ECM
P0689 ECM power relay sense â€â€œ circuit low Wiring short to ground, ECM relay, ECM
P0690 ECM power relay sense â€â€œ circuit high Wiring short to positive, ECM relay, ECM
P0691 Engine coolant blower motor 1 â€â€œ short to ground Wiring short to ground, engine coolant blower motor, ECM
P0692 Engine coolant blower motor 1 â€â€œ short to positive Wiring short to positive, engine coolant blower motor, ECM
P0693 Engine coolant blower motor 2 â€â€œ short to ground Wiring short to ground, engine coolant blower motor, ECM
P0694 Engine coolant blower motor 2 â€â€œ short to positive Wiring short to positive, engine coolant blower motor, ECM
P0695 Fan 3 control â€â€œ circuit low Wiring short to ground, fan motor
P0696 Fan 3 control â€â€œ circuit high Wiring short to positive, fan motor
P0697 Sensor reference voltage C â€â€œ circuit open Wiring short to positive
P0698 Sensor reference voltage C â€â€œ circuit low Wiring short to ground
P0699 Sensor reference voltage C â€â€œ circuit high Wiring short to positive
P0700 Transmission control system â€â€œ malfunction Wiring, TCM
P0701 Transmission control system â€â€œ range/performance problem Wiring, TCM
P0702 Transmission control system â€â€œ electrical Wiring, TCM
P0703 Torque converter/brake switch B â€â€œ circuit malfunction Wiring, torque converter/brake switch, ECM//TCM
P0704 Clutch pedal position (CPP) switch â€â€œ circuit malfunction Wiring, CPP switch, ECM/TCM
P0705 Transmission range (TR) sensor/switch, PRNDL input â€â€œ circuit malfunction Wiring, TR sensor/switch, ECM/TCM
P0706 Transmission range (TR) sensor/switch â€â€œ range/performance problem Wiring, TR sensor/switch
P0707 Transmission range (TR) sensor/switch â€â€œ low input Wiring short to ground, TR sensor/switch, ECM/TCM
P0708 Transmission range (TR) sensor/switch â€â€œhigh input Wiring short to positive, TR sensor/switch, ECM/TCM
P0709 Transmission range (TR) sensor/switch â€â€œ circuit intermittent Wiring, poor connection, TR sensor/switch, ECM/TCM
P0710 Transmission fluid temperature (TFT) sensor â€â€œ circuit malfunction Wiring, TFT sensor, ECM, ECM/TCM
P0711 Transmission fluid temperature (TFT) sensor â€â€œ range/performance problem Wiring, TFT sensor
P0712 Transmission fluid temperature (TFT) sensor â€â€œ low input Wiring short to ground, TFT sensor, ECM, ECM/TCM
P0713 Transmission fluid temperature (TFT) sensor â€â€œ high input Wiring short to ground, TFT sensor, ECM, ECM/TCM
P0714 Transmission fluid temperature (TFT) sensor â€â€œ circuit intermittent Wiring, poor connection, TFT sensor, ECM, ECM/TCM
P0715 Turbine shaft speed (TSS) sensor â€â€œ circuit malfunction Wiring, TSS sensor, ECM/TCM
P0716 Turbine shaft speed (TSS) sensor â€â€œ range/performance problem Wiring, TSS sensor
P0717 Turbine shaft speed (TSS) sensor â€â€œ no signal Wiring, TSS sensor, ECM/TCM
P0718 Turbine shaft speed (TSS) sensor â€â€œ circuit intermittent Wiring, poor connection, TSS sensor, ECM/TCM
P0719 Torque converter/brake switch B â€â€œ circuit low Wiring short to ground, torque converter/brake switch, ECM/TCM
P0720 Output shaft speed (OSS) sensor â€â€œ circuit malfunction Wiring, OSS sensor, ECM/TCM
P0721 Output shaft speed (OSS) sensor â€â€œ range/performance problem Wiring, OSS sensor
P0722 Output shaft speed (OSS) sensor â€â€œ no signal Wiring, OSS sensor, ECM/TCM
P0723 Output shaft speed (OSS) sensor â€â€œ circuit intermittent Wiring, poor connection, OSS sensor, ECM/TCM
P0724 Torque converter/brake switch B â€â€œ circuit high Wiring short to positive, torque converter/brake switch, ECM/TCM
P0725 Engine RPM input â€â€œ circuit malfunction Wiring, CKP/RPM sensor, ECM/TCM
P0726 Engine RPM input â€â€œ range/performance problem Wiring, CKP/RPM sensor
P0727 Engine RPM input â€â€œ no signal Wiring, CKP/RPM sensor, ECM/TCM
P0728 Engine RPM input â€â€œ circuit intermittent Wiring, poor connection, CKP/RPM sensor, ECM/TCM
P0730 Incorrect gear ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault
P0731 Gear 1 â€â€œ incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault
P0732 Gear 2 â€â€œ incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault
P0733 Gear 3 â€â€œ incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault
P0734 Gear 4 â€â€œ incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault
P0735 Gear 5 â€â€œ incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault
P0736 Reverse â€â€œ incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault
P0737 TCM engine speed output â€â€œ circuit Wiring, TCM
P0738 TCM engine speed output â€â€œ circuit low Wiring, TCM
P0739 TCM engine speed output â€â€œ circuit high Wiring, TCM
P0740 Torque converter clutch (TCC) solenoid â€â€œ circuit malfunction Wiring, TCC solenoid, ECM/TCM
P0741 Torque converter clutch (TCC) solenoid â€â€œ performance or stuck off Wiring, TCC solenoid
P0742 Torque converter clutch (TCC) solenoid â€â€œ stuck on Wiring, TCC solenoid
P0743 Torque converter clutch (TCC) solenoid â€â€œ electrical Wiring, TCC solenoid, ECM/TCM
P0744 Torque converter clutch (TCC) solenoid â€â€œ circuit intermittent Wiring, poor connection, TCC solenoid, ECM/TCM
P0745 Transmission fluid pressure (TFP) solenoid â€â€œ circuit malfunction Wiring, TFP solenoid, ECM/TCM
P0746 Transmission fluid pressure (TFP) solenoid â€â€œ performance or stuck off Wiring, TFP solenoid
P0747 Transmission fluid pressure (TFP) solenoid â€â€œ stuck on Wiring, TFP solenoid
P0748 Transmission fluid pressure (TFP) solenoid â€â€œ electrical Wiring, TFP solenoid, ECM/TCM
P0749 Transmission fluid pressure (TFP) solenoid â€â€œ circuit intermittent Wiring, poor connection, TFP solenoid, ECM/TCM
P0750 Shift solenoid (SS) A â€â€œ circuit malfunction Wiring, shift solenoid, ECM/TCM
P0751 Shift solenoid (SS) A â€â€œ performance or stuck off Wiring, shift solenoid
P0752 Shift solenoid (SS) A â€â€œ stuck on Wiring, shift solenoid
P0753 Shift solenoid (SS) A â€â€œ electrical Wiring, shift solenoid, ECM/TCM
P0754 Shift solenoid (SS) A â€â€œ circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM
P0755 Shift solenoid (SS) B â€â€œ circuit malfunction Wiring, shift solenoid, ECM/TCM
P0756 Shift solenoid (SS) B â€â€œ performance or stuck off Wiring, shift solenoid
P0757 Shift solenoid (SS) B â€â€œ stuck on Wiring, shift solenoid
P0758 Shift solenoid (SS) B â€â€œ electrical Wiring, shift solenoid, ECM/TCM
P0759 Shift solenoid (SS) B â€â€œ circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM
P0760 Shift solenoid (SS) C â€â€œ circuit malfunction Wiring, shift solenoid, ECM/TCM
P0761 Shift solenoid (SS) C â€â€œ performance or stuck off Wiring, shift solenoid
P0762 Shift solenoid (SS) C â€â€œ stuck on Wiring, shift solenoid
P0763 Shift solenoid (SS) C â€â€œ electrical Wiring, shift solenoid, ECM/TCM
P0764 Shift solenoid (SS) C â€â€œ circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM
P0765 Shift solenoid (SS) D â€â€œ circuit malfunction Wiring, shift solenoid, ECM/TCM
P0766 Shift solenoid (SS) D â€â€œ performance or stuck off Wiring, shift solenoid
P0767 Shift solenoid (SS) D â€â€œ stuck on Wiring, shift solenoid
P0768 Shift solenoid (SS) D â€â€œ electrical Wiring, shift solenoid, ECM/TCM
P0769 Shift solenoid (SS) D â€â€œ circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM
P0770 Shift solenoid (SS) E â€â€œ circuit malfunction Wiring, shift solenoid, ECM/TCM
P0771 Shift solenoid (SS) E â€â€œ performance or stuck off Wiring, shift solenoid
P0772 Shift solenoid (SS) E â€â€œ stuck on Wiring, shift solenoid
P0773 Shift solenoid (SS) E â€â€œ electrical Wiring, shift solenoid, ECM/TCM
P0774 Shift solenoid (SS) E â€â€œ circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM
P0775 Pressure control solenoid B â€â€œ malfunction Pressure control solenoid
P0776 Pressure control solenoid B â€â€œ performance or stuck off Wiring, pressure control solenoid
P0777 Pressure control solenoid B â€â€œ stuck on Wiring, pressure control solenoid
P0778 Pressure control solenoid B â€â€œ electrical Wiring, pressure control solenoid
P0779 Pressure control solenoid B â€â€œ intermittent Wiring, poor connection, pressure control solenoid
P0780 Gear selection â€â€œ shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault
P0781 Gear selection, 1-2 â€â€œ shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault
P0782 Gear selection, 2-3 â€â€œ shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault
P0783 Gear selection, 3-4 â€â€œ shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault
P0784 Gear selection, 4-5 â€â€œ shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault
P0785 Shift/timing solenoid â€â€œ circuit malfunction Wiring, shift/timing solenoid, ECM/TCM
P0786 Shift/timing solenoid â€â€œ range/performance problem Wiring, shift/timing solenoid
P0787 Shift/timing solenoid â€â€œ low Wiring short to ground, shift/timing solenoid, ECM/TCM
P0788 Shift/timing solenoid â€â€œ high Wiring short to positive, shift/timing solenoid, ECM/TCM
P0789 Shift/timing solenoid â€â€œ intermittent Wiring, poor connection, shift/timing solenoid, ECM/TCM
P0790 Transmission mode selection switch â€â€œ circuit malfunction Wiring, transmission mode selection switch, ECM/TCM
P0791 Intermediate shaft speed sensor â€â€œ circuit malfunction Wiring, poor connection, intermediate shaft speed sensor, ECM/TCM
P0792 Intermediate shaft speed sensor â€â€œ range/performance problem Wiring, poor connection, intermediate shaft speed sensor, ECM/TCM
P0793 Intermediate shaft speed sensor â€â€œ no signal Wiring, poor connection,short to ground, intermediate shaft speed sensor, ECM/TCM
P0794 Intermediate shaft speed sensor â€â€œ intermittent circuit malfunction Wiring, poor connection, intermediate shaft speed sensor, ECM/TCM
P0795 Transmisssion fluid pressure (TFP) solenoid C â€â€œ circuit malfunction Wiring, poor connection, TFP solenoid, ECM/TCM
P0796 Transmisssion fluid pressure (TFP) solenoid C â€â€œ performance or stuck off Wiring, poor connection, TFP solenoid, ECM/TCM
P0797 Transmisssion fluid pressure (TFP) solenoid C â€â€œ stuck on Wiring, poor connection, TFP solenoid, ECM/TCM
P0798 Transmisssion fluid pressure (TFP) solenoid C â€â€œ electrical malfunction Wiring, poor connection, TFP solenoid, ECM/TCM
P0799 Transmisssion fluid pressure (TFP) solenoid C â€â€œ intermittent circuit malfunction Wiring, poor connection, ECM/TCM
P0800 Transfer case control system, MIL request â€â€œ malfunction Wiring, mechanical fault
P0801 Reverse inhibit circuit â€â€œ malfunction Wiring, poor connection
P0802 Transmission control system, MIL request â€â€œ circuit open Wiring, mechanical fault
P0803 1-4 Upshift (Skip shift) solenoid â€â€œ circuit malfunction Wiring, poor connection, upshift solenoid
P0804 1-4 Upshift (Skip shift) warning lamp â€â€œ circuit malfunction Wiring, poor connection
P0805 Clutch position sensor â€â€œ circuit malfunction Wiring, poor connection, clutch position sensor, ECM/TCM
P0806 Clutch position sensor â€â€œ range/performance problem Wiring, poor connection, clutch position sensor, ECM/TCM
P0807 Clutch position sensor â€â€œ low input Wiring, short to ground, clutch position sensor, ECM/TCM
P0808 Clutch position sensor â€â€œ high input Wiring, short to positive, clutch position sensor, ECM/TCM
P0809 Clutch position sensor â€â€œ intermittent circuit malfunction Wiring, poor connection, clutch position sensor, ECM/TCM
P0810 Clutch position control error Wiring, poor connection, ECM/TCM
P0811 Excessive clutch slip Wiring, poor connection, mechanical fault, ECM/TCM
P0812 Reverse gear â€â€œ input circuit malfunction Wiring, poor connection, ECM/TCM
P0813 Reverse gear â€â€œ output circuit malfunction Wiring, poor connection, ECM/TCM
P0814 Transmission range (TR) display â€â€œ circuit malfunction Wiring, poor connection, TR sensor, ECM/TCM
P0815 Upshift switch â€â€œ circuit malfunction Wiring, poor connection, upshift switch, ECM/TCM
P0816 Downshift switch â€â€œ circuit malfunction Wiring, poor connection, downshift switch, ECM/TCM
P0817 Starter disable circuit â€â€œ malfunction Wiring, poor connection, ECM/TCM
P0818 Driveline disconnect switch â€â€œ circuit malfunction Wiring, poor connection, upshift switch, ECM/TCM
P0819 Up and down shift switch to transmission range â€â€œ correlation Wiring, poor connection,TR sensor, ECM/TCM
P0820 Gear lever X-Y position sensor â€â€œ circuit malfunction Wiring, poor connection, gear lever position sensor, ECM/TCM
P0821 Gear lever X position sensor â€â€œ circuit malfunction Wiring, poor connection, gear lever position sensor, ECM/TCM
P0822 Gear lever Y position sensor â€â€œ circuit malfunction Wiring, poor connection, gear lever position sensor, ECM/TCM
P0823 Gear lever X position sensor â€â€œ circuit intermittent Wiring, poor connection, gear lever position sensor, ECM/TCM
P0824 Gear lever Y position sensor â€â€œ circuit intermittent Wiring, poor connection, gear lever position sensor, ECM/TCM
P0825 Gear lever push-pull switch â€â€œ circuit malfunction Wiring, poor connection, gear lever push-pull switch, ECM/TCM
P0826 Up and down switch â€â€œ input circuit Wiring, Up/down switch
P0827 Up and down switch â€â€œ input circuit low Wiring short to ground, Up/down switch
P0828 Up and down switch â€â€œ input circuit high Wiring short to positive, Up/down switch
P0829 5-6 Shift Mechanical fault
P0830 Clutch pedal position (CPP) switch A â€â€œ circuit malfunction Wiring, poor connection, CPP switch, ECM/TCM
P0831 Clutch pedal position (CPP) switch A â€â€œ low input Wiring, short to ground, CPP switch, ECM/TCM
P0832 Clutch pedal position (CPP) switch A â€â€œ high input Wiring, short to positive, CPP switch, ECM/TCM
P0833 Clutch pedal position (CPP) switch B â€â€œ circuit malfunction Wiring, poor connection, CPP switch, ECM/TCM
P0834 Clutch pedal position (CPP) switch B â€â€œ low input Wiring, short to ground, CPP switch, ECM/TCM
P0835 Clutch pedal position (CPP) switch B â€â€œ high input Wiring, short to positive, CPP switch, ECM/TCM
P0836 Four wheel drive switch â€â€œ circuit malfunction Wiring, poor connection, four wheel drive switch, ECM/TCM
P0837 Four wheel drive switch â€â€œ range/performance problem Wiring, poor connection, four wheel drive switch, ECM/TCM
P0838 Four wheel drive switch â€â€œ low input Wiring, short to ground, four wheel drive switch, ECM/TCM
P0839 Four wheel drive switch â€â€œ high input Wiring, short to positive, four wheel drive switch, ECM/TCM
P0840 Transmission fluid pressure (TFP) sensor A â€â€œ circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A â€â€œ circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM
P0841 Transmission fluid pressure (TFP) sensor A â€â€œ range/performance problem Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A â€â€œ range/performance problem Wiring, poor connection, TFP switch, ECM/TCM
P0842 Transmission fluid pressure (TFP) sensor A â€â€œ low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A â€â€œ low input Wiring, short to ground, TFP switch, ECM/TCM
P0843 Transmission fluid pressure (TFP) sensor A â€â€œ high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A â€â€œ high input Wiring, short to positive, TFP switch, ECM/TCM
P0844 Transmission fluid pressure (TFP) sensor A â€â€œ intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A â€â€œ intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM
P0845 Transmission fluid pressure (TFP) sensor B â€â€œ circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B â€â€œ circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM
P0846 Transmission fluid pressure (TFP) sensor B â€â€œ range/performance problem Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B â€â€œ range/performance problem Wiring, poor connection, TFP switch, ECM/TCM
P0847 Transmission fluid pressure (TFP) sensor B â€â€œ low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B â€â€œ low input Wiring, short to ground, TFP switch, ECM/TCM
P0848 Transmission fluid pressure (TFP) sensor B â€â€œ high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B â€â€œ high input Wiring, short to positive, TFP switch, ECM/TCM
P0849 Transmission fluid pressure (TFP) sensor B â€â€œ intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B â€â€œ intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM
P0850 Park/neutral position (PNP) switch â€â€œ input circuit malfunction Wiring, PNP switch, ECM/TCM
P0851 Park/neutral position (PNP) switch â€â€œ input circuit low Wiring, short to ground, PNP switch, ECM/TCM
P0852 Park/neutral position (PNP) switch â€â€œ input circuit high Wiring, short to positive, PNP switch, ECM/TCM
P0853 Drive switch â€â€œ input circuit malfunction Wiring, drive switch, ECM/TCM
P0854 Drive switch â€â€œ input circuit low Wiring, short to ground, drive switch, ECM/TCM
P0855 Drive switch â€â€œ input circuit high Wiring, short to positive, drive switch, ECM/TCM
P0856 Traction control input signal â€â€œ malfunction Wiring, poor connection, ECM/TCM
P0857 Traction control input signal â€â€œ range/performance problem Wiring, poor connection, ECM/TCM
P0858 Traction control input signal â€â€œ low Wiring, short to ground, ECM/TCM
P0859 Traction control input signal â€â€œ high Wiring, short to positive, ECM/TCM
P0860 Gear shift module communication circuit â€â€œ malfunction Wiring, poor connection, gear shift module, ECM/TCM
P0861 Gear shift module communication circuit â€â€œ low input Wiring, short to ground, gear shift module, ECM/TCM
P0862 Gear shift module communication circuit â€â€œ low input Wiring, short to positive, gear shift module, ECM/TCM
P0863 Transmission control module (TCM) communication circuit â€â€œ malfunction Wiring, poor connection, TCM
P0864 Transmission control module (TCM) communication circuit â€â€œ range/performance problem Wiring, poor connection, TCM
P0865 Transmission control module (TCM) communication circuit â€â€œ low input Wiring, short to ground, TCM
P0866 Transmission control module (TCM) communication circuit â€â€œ high input Wiring, short to positive, TCM
P0867 Transmission fluid pressure (TFP) sensor Wiring, poor connection, TFP switch, ECM/TCM
P0868 Transmission fluid pressure (TFP) sensor â€â€œ low Wiring, short to ground, TFP switch, ECM/TCM
P0869 Transmission fluid pressure (TFP) sensor â€â€œ high Wiring, short to positive, TFP switch, ECM/TCM
P0870 Transmission fluid pressure (TFP) sensor C â€â€œ circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C â€â€œ circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM
P0871 Transmission fluid pressure (TFP) sensor C â€â€œ range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C â€â€œ range/performance Wiring, poor connection, TFP switch, ECM/TCM
P0872 Transmission fluid pressure (TFP) sensor C â€â€œ low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C â€â€œ low input Wiring, short to ground, TFP switch, ECM/TCM
P0873 Transmission fluid pressure (TFP) sensor C â€â€œ high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C â€â€œ high input Wiring, short to positive, TFP switch, ECM/TCM
P0874 Transmission fluid pressure (TFP) sensor C â€â€œ intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C â€â€œ intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM
P0875 Transmission fluid pressure (TFP) sensor D â€â€œ circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D â€â€œ circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM
P0876 Transmission fluid pressure (TFP) sensor D â€â€œ range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D â€â€œ range/performance Wiring, poor connection, TFP switch, ECM/TCM
P0877 Transmission fluid pressure (TFP) sensor D â€â€œ low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D â€â€œ low input Wiring, short to ground, TFP switch, ECM/TCM
P0878 Transmission fluid pressure (TFP) sensor D â€â€œ high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D â€â€œ high input Wiring, short to positive, TFP switch, ECM/TCM
P0879 Transmission fluid pressure (TFP) sensor D â€â€œ intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D â€â€œ intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM
P0880 Transmission control module (TCM) â€â€œ power input signal malfunction Wiring, poor connection, TCM
P0881 Transmission control module (TCM) â€â€œ power input signal range/performance Wiring, poor connection, TCM
P0882 Transmission control module (TCM) â€â€œ power input signal low Wiring, short to ground, TCM
P0883 Transmission control module (TCM) â€â€œ power input signal high Wiring, short to positive, TCM
P0884 Transmission control module (TCM) â€â€œ power input signal intermittent malfunction Wiring, poor connection, TCM
P0885 Transmission control module (TCM) power relay â€â€œ control circuit open Wiring, poor connection, TCM power relay, TCM
P0886 Transmission control module (TCM) power relay â€â€œ control circuit low Wiring, short to ground, TCM power relay, TCM
P0887 Transmission control module (TCM) power relay â€â€œ control circuit high Wiring, short to positive, TCM power relay, TCM
P0888 Transmission control module (TCM) power relay â€â€œ sense circuit malfunction Wiring, poor connection, TCM power relay, TCM
P0889 Transmission control module (TCM) power relay â€â€œ sense circuit range/performance Wiring, poor connection, TCM power relay, TCM
P0890 Transmission control module (TCM) power relay â€â€œ sense circuit low Wiring, short to ground, TCM power relay, TCM
P0891 Transmission control module (TCM) power relay â€â€œ sense circuit high Wiring, short to positive, TCM power relay, TCM
P0892 Transmission control module (TCM) power relay â€â€œ sense circuit intermittent malfunction Wiring, poor connection, TCM power relay, TCM
P0893 Multiple gears engaged Mechanical fault
P0894 Transmission component slipping Mechanical fault
P0895 Shift time too short Mechanical fault
P0896 Shift time too long Mechanical fault
P0897 Transmission fluid deteriorated Mechanical fault
P0898 Transmission control system â€â€œ MIL request â€â€œ circuit low Wiring, poor connection, short to ground
P0899 Transmission control system â€â€œ MIL request â€â€œ circuit high Wiring, poor connection, short to positive
P0900 Clutch actuator â€â€œ circuit open Wiring, clutch actuator, ECM/TCM
P0901 Clutch actuator â€â€œ circuit range/performance Wiring, poor connection, clutch actuator, ECM/TCM
P0902 Clutch actuator â€â€œ circuit low Wiring, short to ground, clutch actuator, ECM/TCM
P0903 Clutch actuator â€â€œ circuit high Wiring, short to positive, clutch actuator, ECM/TCM
P0904 Transmission gate select position circuit â€â€œ malfunction Wiring, poor connection, ECM/TCM
P0905 Transmission gate select position circuit â€â€œ range/performance Wiring, poor connection, ECM/TCM
P0906 Transmission gate select position circuit â€â€œ low Wiring, short to ground, ECM/TCM
P0907 Transmission gate select position circuit â€â€œ high Wiring, short to positive, ECM/TCM
P0908 Transmission gate select position circuit â€â€œ intermittent circuit malfunction Wiring, poor connection, ECM/TCM
P0909 Transmission gate select control error Mechanical fault
P0910 Transmission gate select actuator â€â€œ circuit open Wiring, transmission gate select actuator, ECM/TCM
P0911 Transmission gate select actuator â€â€œ circuit range/performance Wiring, poor connection, transmission gate select actuator, ECM/TCM
P0912 Transmission gate select actuator â€â€œ circuit low Wiring, short to ground, transmission gate select actuator, ECM/TCM
P0913 Transmission gate select actuator â€â€œ circuit high Wiring, short to positive, transmission gate select actuator, ECM/TCM
P0914 Gear shift position circuit â€â€œ malfunction Wiring, poor connection, ECM/TCM
P0915 Gear shift position circuit â€â€œ range/performance Wiring, poor connection, ECM/TCM
P0916 Gear shift position circuit â€â€œ low Wiring, short to ground, ECM/TCM
P0917 Gear shift position circuit â€â€œ high Wiring, short to positive, ECM/TCM
P0918 Gear shift position circuit â€â€œ intermittent malfunction Wiring, poor connection, ECM/TCM
P0919 Gear shift position control â€â€œ error Wiring, poor connection, ECM/TCM
P0820 Gear shift forward actuator â€â€œ circuit open Wiring, gear shift forward actuator, ECM/TCM
P0821 Gear shift forward actuator â€â€œ circuit range/performance Wiring, poor connection, gear shift forward actuator, ECM/TCM
P0822 Gear shift forward actuator â€â€œ circuit low Wiring, short to ground, gear shift forward actuator, ECM/TCM
P0823 Gear shift forward actuator â€â€œ circuit high Wiring, short to positive, gear shift forward actuator, ECM/TCM
P0824 Gear shift reverse actuator â€â€œ circuit open Wiring, gear shift reverse actuator, ECM/TCM
P0825 Gear shift reverse actuator â€â€œ circuit range/performance Wiring, poor connection, gear shift reverse actuator, ECM/TCM
P0826 Gear shift reverse actuator â€â€œ circuit low Wiring, short to ground, gear shift reverse actuator, ECM/TCM
P0927 Gear shift reverse actuator â€â€œ circuit high Wiring, short to positive, gear shift reverse actuator, ECM/TCM
P0928 Gear shift lock solenoid â€â€œ circuit open Wiring, gear shift lock solenoid, ECM/TCM
P0929 Gear shift lock solenoid â€â€œ circuit range/performance Wiring, gear shift lock solenoid, ECM/TCM
P0930 Gear shift lock solenoid â€â€œ circuit low Wiring, short to ground, gear shift lock solenoid, ECM/TCM
P0931 Gear shift lock solenoid â€â€œ circuit high Wiring, short to positive, gear shift lock solenoid, ECM/TCM
P0932 Hydraulic pressure sensor â€â€œ circuit malfunction Wiring, poor connection, hydraulic pressure sensor, ECM/TCM
P0933 Hydraulic pressure sensor â€â€œ range/performance Wiring, hydraulic pressure sensor, ECM/TCM
P0934 Hydraulic pressure sensor â€â€œ circuit low input Wiring, short to ground, hydraulic pressure sensor, ECM/TCM
P0935 Hydraulic pressure sensor â€â€œ circuit high input Wiring, short to positive, hydraulic pressure sensor, ECM/TCM
P0936 Hydraulic pressure sensor â€â€œ circuit intermittent Wiring, poor connection, hydraulic pressure sensor, ECM/TCM
P0937 Hydraulic oil temperature sensor â€â€œ circuit malfunction Wiring, poor connection, hydraulic oil temperature sensor, ECM/TCM
P0938 Hydraulic oil temperature sensor â€â€œ range/performance Wiring, hydraulic oil temperature sensor, ECM/TCM
P0939 Hydraulic oil temperature sensor â€â€œ circuit low input Wiring, short to ground, hydraulic oil temperature sensor, ECM/TCM
P0940 Hydraulic oil temperature sensor â€â€œ circuit high input Wiring, short to positive, hydraulic oil temperature sensor, ECM/TCM
P0941 Hydraulic oil temperature sensor â€â€œ circuit intermittent Wiring, poor connection, hydraulic oil temperature sensor, ECM/TCM
P0942 Hydraulic pressure unit Mechanical fault
P0943 Hydraulic pressure unit â€â€œ cycling period too short Mechanical fault
P0944 Hydraulic pressure unit â€â€œ loss of pressure Mechanical fault
P0945 Hydraulic pump relay â€â€œ circuit open Wiring, hydraulic pump relay, ECM/TCM
P0946 Hydraulic pump relay â€â€œ circuit range/performance Wiring, hydraulic pump relay, ECM/TCM
P0947 Hydraulic pump relay â€â€œ circuit low Wiring, short to ground, hydraulic pump relay, ECM/TCM
P0948 Hydraulic pump relay â€â€œ circuit high Wiring, short to positive, hydraulic pump relay, ECM/TCM
P0949 ASM â€â€œ adaptive learning not done ECM/TCM
P0850 ASM control circuit Wiring, poor connection, ECM/TCM
P0851 ASM control circuit â€â€œ range/performance Wiring, poor connection, ECM/TCM
P0852 ASM control circuit â€â€œ low Wiring, poor connection, short to ground, ECM/TCM
P0853 ASM control circuit â€â€œ high Wiring, poor connection, short to positive, ECM/TCM
P0854 ASM â€â€œ intermittent circuit malfunction Wiring, poor connection, ECM/TCM
P0855 ASM mode circuit â€â€œ malfunction Wiring, poor connection, ECM/TCM
P0856 ASM mode circuit â€â€œ range/performance Wiring, poor connection, ECM/TCM
P0957 ASM mode circuit â€â€œ low Wiring, poor connection, short to ground, ECM/TCM
P0958 ASM mode circuit â€â€œ high Wiring, poor connection, short to positive, ECM/TCM
P0959 ASM mode circuit â€â€œ intermittent circuit malfunction Wiring, poor connection, ECM/TCM
P0960 Pressure control (PC) solenoid A â€â€œ control circuit open Wiring, poor connection, pressure control solenoid, ECM/TCM
P0961 Pressure control (PC) solenoid A â€â€œ control circuit range/performance Wiring, poor connection, pressure control solenoid, ECM/TCM
P0962 Pressure control (PC) solenoid A â€â€œ control circuit low Wiring, short to ground, pressure control solenoid, ECM/TCM
P0963 Pressure control (PC) solenoid A â€â€œ control circuit high Wiring, short to positive, pressure control solenoid, ECM/TCM
P0964 Pressure control (PC) solenoid B â€â€œ control circuit open Wiring, poor connection, pressure control solenoid, ECM/TCM
P0965 Pressure control (PC) solenoid B â€â€œ control circuit range/performance Wiring, poor connection, pressure control solenoid, ECM/TCM
P0966 Pressure control (PC) solenoid B â€â€œ control circuit low Wiring, short to ground, pressure control solenoid, ECM/TCM
P0967 Pressure control (PC) solenoid B â€â€œ control circuit high Wiring, short to positive, pressure control solenoid, ECM/TCM
P0968 Pressure control (PC) solenoid C â€â€œ control circuit open Wiring, poor connection, pressure control solenoid, ECM/TCM
P0969 Pressure control (PC) solenoid C â€â€œ control circuit range/performance Wiring, poor connection, pressure control solenoid, ECM/TCM
P0970 Pressure control (PC) solenoid C â€â€œ control circuit low Wiring, short to ground, pressure control solenoid, ECM/TCM
P0971 Pressure control (PC) solenoid C â€â€œ control circuit high Wiring, short to positive, pressure control solenoid, ECM/TCM
P0972 Shift solenoid (SS) A â€â€œ control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM
P0973 Shift solenoid (SS) A â€â€œ control circuit low Wiring, short to ground, shift solenoid, ECM/TCM
P0974 Shift solenoid (SS) A â€â€œ control circuit high Wiring, short to positive, shift solenoid, ECM/TCM
P0975 Shift solenoid (SS) B â€â€œ control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM
P0976 Shift solenoid (SS) B â€â€œ control circuit low Wiring, short to ground, shift solenoid, ECM/TCM
P0977 Shift solenoid (SS) B â€â€œ control circuit high Wiring, short to positive, shift solenoid, ECM/TCM
P0978 Shift solenoid (SS) C â€â€œ control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM
P0979 Shift solenoid (SS) C â€â€œ control circuit low Wiring, short to ground, shift solenoid, ECM/TCM
P0980 Shift solenoid (SS) C â€â€œ control circuit high Wiring, short to positive, shift solenoid, ECM/TCM
P0981 Shift solenoid (SS) D â€â€œ control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM
P0982 Shift solenoid (SS) D â€â€œ control circuit low Wiring, short to ground, shift solenoid, ECM/TCM
P0983 Shift solenoid (SS) D â€â€œ control circuit high Wiring, short to positive, shift solenoid, ECM/TCM
P0984 Shift solenoid (SS) E â€â€œ control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM
P0985 Shift solenoid (SS) E â€â€œ control circuit low Wiring, short to ground, shift solenoid, ECM/TCM
P0986 Shift solenoid (SS) E â€â€œ control circuit high Wiring, short to positive, shift solenoid, ECM/TCM
P0987 Transmission fluid pressure (TFP) sensor E â€â€œ circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E â€â€œ circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM
P0988 Transmission fluid pressure (TFP) sensor E â€â€œ circuit range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E â€â€œ circuit range/performance Wiring, poor connection, TFP switch, ECM/TCM
P0989 Transmission fluid pressure (TFP) sensor E â€â€œ circuit low Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E â€â€œ circuit low Wiring, short to ground, TFP switch, ECM/TCM
P0990 Transmission fluid pressure (TFP) sensor E â€â€œ circuit high Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E â€â€œ circuit high Wiring, short to positive, TFP switch, ECM/TCM
P0991 Transmission fluid pressure (TFP) sensor E â€â€œ circuit intermittent Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E â€â€œ circuit intermittent Wiring, poor connection, TFP switch, ECM/TCM
P0992 Transmission fluid pressure (TFP) sensor F â€â€œ circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F â€â€œ circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM
P0993 Transmission fluid pressure (TFP) sensor F â€â€œ circuit range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F â€â€œ circuit range/performance Wiring, poor connection, TFP switch, ECM/TCM
P0994 Transmission fluid pressure (TFP) sensor F â€â€œ circuit low Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F â€â€œ circuit low Wiring, short to ground, TFP switch, ECM/TCM
P0995 Transmission fluid pressure (TFP) sensor F â€â€œ circuit high Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F â€â€œ circuit high Wiring, short to positive, TFP switch, ECM/TCM
P0996 Transmission fluid pressure (TFP) sensor F â€â€œ circuit intermittent Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F â€â€œ circuit intermittent Wiring, poor connection, TFP switch, ECM/TCM
P0997 Shift solenoid (SS) F â€â€œ control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM
P0998 Shift solenoid (SS) F â€â€œ control circuit low Wiring, short to ground, shift solenoid, ECM/TCM
P0999 Shift solenoid (SS) F â€â€œ control circuit high Wiring, short to positive, shift solenoid, ECM/TCM
Hyundai Specific CEL's
P1100 Map Sensor - Malfunction
P1101 Map Sensor - Abnormal
P1102 Map Sensor - Low Input
P1103 Map Sensor - High Input
P1104 Air Flow
P1105 Air Flow - Abnormal
P1106 Air Flow - Low Input
P1107 Air Flow - High Input
P1108 Fuel Pump
P1109 Fuel Pump - Abnormal
P1110 Fuel Pump - Stuck On
P1110 ETS System - Malfunction
P1111 Fuel Pump - Electrical
P1112 Manifold Differential Pressure Sensor
P1112 VGT Actuator - Malfunction
P1113 Manifold Differential Pressure Sensor - Abnormal
P1114 Manifold Differential Pressure Sensor - Low
P1115 Coolant Temperature Input - Abnormal
P1116 Boost Pressure Sensor - Malfunction
P1118 ETS Motor - Malfunction
P1119 Inlet Metering Valve Control
P1120 Electric Governor - Malfunction
P1120 Inlet Metering Valve Malfunction
P1121 APS PWM Output Circuit Malfunction
P1121 Throttle Position Input - Abnormal
P1122 Boost Pressure Control Valve
P1123 Fuel System Rich - Idle
P1123 Timer Position Sensor - Malfunction
P1124 Fuel System Lean - Idle
P1125 Fuel Press Sensor1
P1126 Fuel Press Sensor2
P1127 Fuel System Rich - Part Load
P1127 Control Sleeve Position Sensor
P1128 Fuel System Lean - Part Load
P1130 Start Solenoid- Malfunction
P1131 Injection Quantity Adjust
P1134 O2s Transition Time(B1/S1)
P1135 Injection Timing Servo
P1140 Inlet Air Temperature Sensor Malfunction
P1141 Slow Duty Solenoid- Malfunction
P1145 Main Duty Solenoid- Malfunction
P1146 Idle Co Potentiometer
P1147 Accelerator Position Sensor (ETS) Circuit
P1150 Barometric Pressure Sensor Malfunction
P1151 Accelerator Position Sensor (EMS) Circuit
P1152 Accelerator Position Circuit-Low Input
P1153 Accelerator Position Circuit-High Input
P1154 O2s Transition Time(B2/S1)
P1155 Limp Home Valve- Malfunction
P1159 Variable Induction System
P1162 High Pressure Pump & Fuel Line
P1166 O2s (B1) Control Adaptation
P1166 Limit O2s Lambda Control (B1)
P1167 O2s (B2) Control Adaptation
P1167 Limit O2s Lambda Control (B2)
P1168 O2s (B1/S2) Heater Power
P1169 O2s (B2/S2) Heater Power
P1170 ECM (Barometric Pressure Sensor)
P1171 ETS Valve Stuck - Open
P1172 ETS Improper Motor Current
P1173 ETS Target Following Malfunction
P1174 ETS Valve Stuck - Close #1
P1175 ETS Valve Stuck - Close #2
P1176 ETS Motor Open/Short #1
P1177 ETS Motor Open/Short #2
P1178 ETS Motor Power - Open
P1179 ETS Position F/B-Mismatch
P1180 O2 S1 Heater Circuit- Malfunction
P1180 Fuel Pressure Regulator - Malfunction
P1181 Fuel Pressure Monitoring
P1182 O2 S2 Heater Circuit - Malfunction
P1182 Fuel Pressure Regulator - Short
P1183 Fuel Pressure Regulator - Open
P1184 O2s No Activity (B1/S2)
P1184 Fuel Pressure Regulator - Power
P1185 Fuel Position - Excessive
P1186 Fuel Pressure - Too Low
P1187 Regulator Valve - Stuck
P1188 Fuel Pressure - Leakage
P1189 Governor Deviation
P1190 Intake Throttle Actuator
P1191 ETS Limp Home Valve On
P1192 Limp home - Target Follow Malfunction
P1193 ETS Limp Home - Low Rpm
P1194 Limp Home - TPS2 Position Malfunction
P1195 Limp Home - Target Follow Delay
P1196 ETS Limp Home - Close Stuck
P1300 Spark Timing Adjust Signal
P1300 Injector Specific Data Fault
P1300 Synchronization Error-CKP/CMP
P1301 TDC Sensor - Abnormal
P1302 TDC Sensor - Low Input
P1303 TDC Sensor - High Input
P1304 Phase Sensor
P1305 Phase Sensor - Abnormal
P1306 Phase Sensor - Low Input
P1307 Phase Sensor - High Input
P1307 Accelerator Sensor - Range/Performance
P1308 Ignition Coil.1
P1308 Accelerator Sensor - Low
P1308 Accelerator Sensor Circuit - Low
P1309 Ignition Coil.1 - Abnormal
P1309 Accelerator Sensor - High
P1309 Accelerator Sensor Circuit - High
P1310 Ignition Coil.1 - Low Output
P1310 Injection Control Circuit Fault
P1311 Ignition Coil.1 - High Output
P1312 Ignition Coil.2
P1313 Ignition Coil.2 - Abnormal
P1314 Ignition Coil.2 - Low Output
P1315 Ignition Coil.2 - High Output
P1316 Ignition Coil.3
P1317 Ignition Coil.3 - Abnormal
P1318 Ignition Coil.3 - Low Output
P1319 Ignition Coil.3 - High Output
P1320 Ignition Coil.4
P1321 Ignition Coil.4 - Abnormal
P1321 Glow Indicator Lamp - Short
P1322 Ignition Coil.4 - Low Output
P1322 Glow Indicator Lamp - Open
P1323 Ignition Coil.4 - High Output
P1324 Glow Relay - Malfunction
P1325 Glow Relay - Abnormal
P1325 Glow Relay
P1326 Glow Relay - Stuck On
P1326 Glow Relay - Short
P1327 Glow Relay - Electrical
P1327 Glow Relay - Open
P1330 Spark Timing Adjust Signal
P1331 #1 MF Signal Line Short
P1332 #2 MF Signal Line Short
P1333 #3 MF Signal Line Short
P1334 #4 MF Signal Line Short
P1335 #5 MF Signal Line Short
P1336 #6 MF Signal Line Short
P1337 #7 MF Signal Line Short
P1338 #8 MF Signal Line Short
P1340 IFS 2 Open
P1341 #1 Ion Line Open
P1342 #2 Ion Line Open
P1343 #3 Ion Line Open
P1344 #4 Ion Line Open
P1345 #5 Ion Line Open
P1346 #6 Ion Line Open
P1347 #7 Ion Line Open
P1348 #8 Ion Line Open
P1351 #1 MF Signal Line Open
P1352 #2 MF Signal Line Open
P1353 #3 MF Signal Line Open
P1354 #4 MF Signal Line Open
P1355 #5 MF Signal Line Open
P1356 #6 MF Signal Line Open
P1357 #7 MF Signal Line Open
P1358 #8 MF Signal Line Open
P1372 Segment Time Incorrect
P1400 Manifold Differential Pressure Sensor
P1401 DMTL Performance
P1402 DMTL Motor Circuit
P1403 DMTL Valve Circuit
P1404 DMTL Heater Circuit
P1405 EGR Temperature Incorrect
P1415 2nd Air Injection Insufficient (B1)
P1416 Secondary Air Injection
P1418 2nd Air Injection Insufficient (B2)
P1419 2nd Air Injection Valve
P1440 EVAP System-Vent Circuit
P1440 Canister Valve Open/Short
P1443 EVAP System - Tank Cap Missing
P1458 A/C Switch Malfunction
P1500 A/Con Switch
P1500 Vehicle Speed Signal Malfunction
P1500 Vehicle Speed Input - Abnormal
P1501 Brake Switch
P1502 Wheel Speed Sensor Circuit Malfunction
P1503 Accelerator Switch
P1503 Auto Cruise Control Switch
P1504 Inhibitor Switch
P1504 Auto Cruise Cancel
P1505 Kick-Down Servo Switch
P1505 Idle Speed Actuator (Open) - Open
P1506 MPS
P1506 Idle Speed Actuator (Open) - Short
P1507 MPS - Abnormal
P1507 Idle Speed Actuator (Close) - Open
P1508 MPS - Low
P1508 Idle Speed Actuator (Close) - Short
P1509 MPS - High
P1510 Idle Speed Actuator (Open) - Short
P1510 ISC Circuit Open/Short
P1511 ISC Open/Short Coil2
P1511 ISC Circuit Open/Short
P1512 WTS - Low
P1513 Idle Speed Actuator (Open) - Open
P1514 Oil Temperature Sensor
P1515 Oil Temperature Sensor - Abnormal
P1515 ISA Coil1 Command Sig. Malfunction
P1516 Oil Temperature Sensor - Low
P1516 ISA Coil2 Command Sig. Malfunction
P1517 Oil Temperature Sensor - High
P1520 Generator Front Terminal Malfunction
P1521 Power Steering Switch Circuit
P1522 Battery
P1522 Sensor Supply 1 Volt - Low
P1523 Sensor Supply 1 Volt - High
P1524 Sensor Supply 2 Volt - Low
P1525 5v Source Voltage
P1525 Sensor Supply 2 Volt - High
P1526 Sensor Supply Voltage1 - Malfunction
P1527 Sensor Supply Voltage2 - Malfunction
P1529 TCM Mil On Request Signal
P1529 Check TCM
P1530 Maximum Vehicle Speed Limiting
P1543 Brake Switch Signal Fault
P1545 A/C Comp. Switch Open/Short
P1552 Idle Speed Act.(Close) - Short
P1553 Idle Speed Act.(Close) - Open
P1555 Idle Co-Potentiometer Open/Short
P1567 Fuel Pressure Valve Current - Low
P1568 Fuel Pressure Valve Current - Hi
P1569 Current-Pressure Control Valve
P1569 Press Control Valve - Current
P1586 MT/AT Encoding Sig. Error
P1600 Serial Communication - Malfunction (With4A/T)
P1601 ECM ‘L’ Line
P1602 ECU-TCU Communication Line #1 Malfunction
P1603 ECU-TCU Communication Line #2 Malfunction
P1603 ECM-TCSCM Communication Line
P1603 TCU Error
P1603 CAN Communication Bus Off
P1604 TPS Communication Malfunction
P1604 No ID From ECU
P1605 Rough Road Sensor Malfunction
P1605 Acceleration Sensor - Malfunction
P1606 Rough Road Sensor Not Ration
P1606 Acceleration Sensor - Abnormal
P1607 Vacuum Sol. Valve Stuck On
P1607 ECM-ETS Communication Line - Malfunction
P1608 Vacuum Solenoid Valve Electrical
P1608 ECU Fault
P1608 ETS-ECM Communication Line - Malfunction
P1609 Immobilizer Communication - Malfunction
P1610 Immobilizer - Smartra Error
P1610 Sensor Reference Voltage Fault
P1611 Mil Request Signal Low
P1611 Immobilizer - Transponder Malfunction
P1612 Ventilation Solenoid Valve Elec.
P1612 Immobilizer - Smartra Malfunction
P1613 ECM-Failure
P1613 Immobilizer Communication Error
P1613 Mil Request Line - High
P1613 ECM-Malfunction
P1613 ECM (Voltage Regulator) - Malfunction
P1614 Mil Request Signal High
P1614 ECU Software Fault
P1614 ETS ECU - Malfunction
P1615 ETS - ECM Malfunction
P1616 Main Relay Malfunction
P1619 Main Relay
P1620 A/C Relay Malfunction
P1620 A/C Comp. Relay - Short
P1621 Fuel Cut Valve - Malfunction
P1621 A/C Comp. Relay - Open
P1622 A/C Control Circuit Failure
P1622 A/C Relay - Malfunction
P1622 A/C Comp. Relay - Malfunction
P1623 Mil Open/Short
P1623 Engine Check Lamp - Malfunction
P1623 Radiator Cooling Fan - Malfunction
P1624 Mil-On Request From TCM
P1624 Cooling Fan Relay (Low) Cir
P1624 Radiator Cooling Fan - Malfunction
P1624 Cooling Fan Relay - Low
P1625 A/C Condenser Fan - Malfunction
P1625 Cooling Fan Relay (High) Circuit
P1625 Cooling Fan Relay - High
P1626 Immobilizer Indicator Malfunction
P1627 A/C Condenser Fan
P1628 Condenser Fan Circuit - Low
P1629 Glow Indicator Lamp - Malfunction
P1629 Condenser Fan Circuit - High
P1630 CAN-Bus-Off
P1630 Intercooler Fan - Malfunction
P1631 Serial Communication Error - Password
P1631 CAN-Time Out ECU
P1632 TCS System Malfunction
P1632 CAN Bus Off
P1633 Immobilizer Status Lamp
P1634 Cruise Control Lamp - Malfunction
P1634 Auxiliary Heat Relay - Short/Open
P1635 Water Heater Relay - Malfunction
P1636 Voltage Regulator For Inject.
P1638 ECM (Microcontroller) - Malfunction
P1639 ECM (Monitoring ADC) - Malfunction
P1640 VI Motor Open/Short Coil1
P1640 Main Relay Malfunction
P1641 VI Motor Open/Short Coil2
P1642 Non Immobilizer ECU Equipped
P1645 Booster Voltage - Operate Injector
P1646 Booster Voltage - Too High
P1647 Threshold 1 Voltage - Malfunction
P1647 Booster Voltage -Too Low
P1652 Ignition Switch - Malfunction
P1653 After-Run Check Error
P1660 Cruise Control Switch - Malfunction
P1665 Power Stage Group A Malfunction.
P1670 Power Stage Group B Malfunction
P1670 Injector Classification
P1672 Fan Relay Malfunction - Low Speed
P1673 Fan Relay Malfunction - High Speed
P1674 A/C Fan Relay Malfunction
P1690 Immobilizer Smartra Error
P1690 W/Heater Relay Fault
P1691 Immobilizer Antenna Error
P1692 Immobilizer - Indicator Lamp Error
P1693 Mil Request Line - Malfunction
P1693 Immobilizer Transponder
P1694 Immobilizer ECU Signal Error
P1695 Immobilizer EEPROM Error
P1696 Immobilizer - Key Mismatched
P1697 Invalid Tester Request
P1698 Key ID. Not Valid
P1700 A/T Gear Shift Malfunction
P1701 TPS
P1702 TPS - Abnormal
P1702 TPS - Malfunction Adjustment
P1703 TPS - Low Input
P1703 TPS - Open/Short (Ground)
P1704 TPS - High Input
P1704 TPS - Short
P1704 TPS - Short
P1706 Inhibitor Switch
P1707 Brake Switch
P1707 Auto Cruise Brake Switch
P1708 Accelerator Switch
P1709 Kick-Down Servo Switch
P1709 K/D Servo Switch - Open/Short
P1710 Oil Temperature Sensor
P1711 Oil Temperature Sensor Abnormal
P1712 Oil Temperature Sensor Low Input
P1713 Oil Temperature Sensor High Input
P1714 Idle Switch
P1715 A/C on Switch
P1716 Steering Sensor
P1717 Steering Sensor Abnormal
P1717 Steer 1 Input Signal
P1718 Steering Sensor Low Input
P1718 Steer 2 Input Signal
P1719 Steering Sensor High Input
P1719 Steer N Input Signal
P1721 Control Relay
P1722 Control Relay - Abnormal
P1723 Control Relay - Stuck On
P1723 A/T Relay - Open/Short (Ground)
P1724 Control Relay - Electrical
P1725 TOD Control Module Error
P1726 TPS Input - Loss Of Signal
P1727 TPS Input - Out Of Range
P1728 EMC-Open/Short To Battery
P1729 EMC-Short To Ground
P1730 Front Speed Sensor - Low Input
P1731 Front Speed Sensor - High
P1732 Rear Speed Sensor - Low Input
P1733 Rear Speed Sensor - High Input
P1734 Speed Sensor Reference - Low
P1735 Speed Sensor Reference - High
P1736 Shift Motor - Open
P1737 ECV Stick
P1737 Shift Motor - Short To Ground
P1738 Shift System Time Out
P1739 General Position Encoder Fault
P1740 Position1 - Short To Ground
P1741 Position2 - Short To Ground
P1742 Position3 - Short To Ground
P1743 Position4 - Short To Ground
P1744 Lock Up Clutch System
P1744 Anomalous Vibration Occurrence
P1745 TCM ‘K’ Line
P1746 TCM ‘L’ Line
P1747 TCU-ECU Communication Line #1 Malfunction
P1748 TCU-ECU Communication Line2 Malfunction
P1749 Serial Communication Link
P1749 Serial Communication Link-Open/Short
P1750 TPS Communication Malfunction
P1750 Front Left Speed Sensor
P1751 Not Defined DTC
P1751 Front Right Speed Sensor
P1752 Lamp ‘P’
P1752 Rear Left Speed Sensor
P1753 Lamp ‘R’
P1753 Rear Right Speed Sensor
P1754 Lamp ‘N’
P1755 Lamp ‘D’
P1756 Lamp ‘3’
P1757 Lamp ‘2’
P1758 Lamp ‘L’
P1759 Control Module - Check Sum
P1760 Control Module - Programming
P1761 Control Module - KAM
P1762 Control Module - RAM
P1763 Control Module - ROM
P1764 Can Controller - Malfunction
P1764 ECU-ITM CAN Communication Line
P1765 Torque Reduction Request
P1765 TCS-ITM CAN Communication Line
P1766 Torque Reduction Execution
P1771 Shifting Position
P1772 Selection Position
P1773 Gearbox Input Speed Sensor
P1774 CRC Sensor
P1775 TCM-Malfunction
P1776 Power Control Module- Malfunction
P1777 PCM Output - Malfunction
P1778 Electro Valve Output - Malfunction
P1779 Stator Inhibit Relay - Malfunction
P1780 Push-Pull Sensor
P1780 Torque Reduction Required Signal
P1781 Actuator
P1782 Actuator Position Sensor
P1786 Engine Rpm Output Circuit Malfunction
P1791 TPS Input Circuit - Malfunction
P1795 Ground Return Circuit - Malfunction
P1795 Transfer High/Low Switch - Malfunction
P1800 Immobilizer Antenna Error
P1801 Immobilizer Transponder Error
P1802 Immobilizer Antenna Error
P1803 Immobilizer ECU Signal Error
P1805 Immobilizer EEPROM Error
P1805 EEPROM Error/VIN Mismatch
P2096 Post Fuel Trim Too Lean-B1
P2097 Post Fuel Trim Too Rich-B1
P2120 Accelerator Position Circuit - Malfunction
P2122 Accelerator Position Circuit - Low Input
P2123 Accelerator Position Circuit - High Input
P2125 Accelerator Position Circuit - Malfunction
P2127 Accelerator Position Circuit - Low Input
P2128 Accelerator Position Circuit - High Input
P2187 Fuel System Too Lean At Idle
P2188 Fuel Sys Too Rich At Idle
P2191 Fuel Sys Too Lean At P-load
P2192 Fuel Sys Too Rich At P-load
P2195 L.O2s Signal Stuck - Lean (B1/S1)
P2196 L.O2s Signal Stuck - Rich (B1/S1)
P2231 O2s Signal & Heater - Short (B1/S1)
P2237 L.O2s Pump. Circuit - Open (B1/S1)
P2238 L.O2s Pump. Circuit - Low (B1/S1)
P2239 L.O2s Pump. Circuit - High (B1/S1)
P2243 L.O2s Reference Circuit (+) Open - (B1/S1)
P2251 L.O2s Reference Circuit (-) Open - (B1/S1)
P2297 L.O2s Out Of Range (B1/S1)
P2414 L.O2s Exhaust Sample (B1/S1)
P2626 L.O2s Pump Trim - Open (B1/S1)
majik Sep 19, 2007 09:16 AM
eek.gif Where did you find this?
*sticky*
Rixshark Sep 19, 2007 09:21 AM
Here's where I found it.
ElantraXD Board
A friend on HP.com built me a code reader, then told me to search the XD forum for the codes and what they mean...I didn't see this anywhere on here....so I figured I'd help out...... fing02.gif
DTN Sep 19, 2007 09:21 AM
You were talking about doing it at NOPI. Sweet, Good Work RixShark.
