Check Engine Light
Old Aug 4, 2009 | 02:37 PM
guster900's Avatar
My check engine light just won't go away. The code is PO441, which is: P0441 Evaporative emission (EVAP) system ��“ incorrect flow detected Hose connection(s), intake leak, EVAP canister purge valve
Any ideas? Where do I start? Any things come to mind that could be easily replaced?
One other thing is that it is hard to start after filling up the tank. So maybe that will help diagnose. I read in some other posts that may indicate a solenoid in the engine? What part is that, where is it located?
Old Aug 4, 2009 | 02:46 PM
fury's Avatar
If it was me, I would start by reading the following posts:
http://www.rdtiburon.com/index.php?act=Sea...ghlite=%2BP0441
Old Aug 4, 2009 | 03:04 PM
Please at least ATTEMPT a search before you post. Use the search function, put in your CEL code, and read those threads. If you have new unanswered questions, post a new thread. if you have further questions on the same line in a thread, post in there.
PS: Sorry stocker. LOL
