Changing Spark Plugs
HI
I think I have to change my spark plugs. I have bought Bosch Super 4 plugs on ebay. The seller told me that they fit in my Car. It's a Coupe RD with the G4GR engine. Today I asked in a local car store if they have these plugs for my car. But they didn't find it in the catalogue. They only found it for a Hyundai Lantra with the same Engine-Code G4GR. Will they fit in my Car. Is it difficult to change the spark plugs or just
remove cover
remove spark plug cable
turn the old plug out
the new one in
connect the spark plug cable
mount the cover
David
remove cover
the new one in
mount the cover
David
Spark plugs should fit, cause Elantra BETA and Tiburon BETA engines are the same, so they should use same plugs.
Be careful to not overtight sparkplugs in the head. Best is to tighten them with torque wrench.
Also, Check the spark plug gap to make sure it is correct before you put the new ones in.
Check out this tutorial
/\ yah i was gonna say make sure u gap them right, affects performance and such if u do it wrong. Spark plugs arent hard tho man, ull be fine...
Actually, I'll post the size when I get home.
I bought a $300 set of craftsmen tools last year and it came with 2 spark plug sockets.
Neither are the right size. I had to go buy it seperately.
5/8 inch. please make sure you use a spark plug socket and not a regular deep socket.
my 20 dollar master mechanic ratchet set from true value came with only one SP socket, and it was the right one. lifetime warranty too. wink1.gif
