CEL!
Old Jun 7, 2004 | 07:07 PM
Tank's Avatar
OK, so my friend and i were changing my oil and stuff and we got that all good, started the engine, everything sounded fine and stuff. Then we were thinking of a way to keep my intake from moving around due to the loss of the bolt thinger. So we figure out a way but its rubbing on the tire so we move it all back and then start it up, and it sounds weird. Went for a drive and throttle response is slower and it sounds like it sucking in air through someones ass. Any ideas on what happend? Hes coming back over in 20 minutes to look at it with me, since he knows more about cars.
Old Jun 7, 2004 | 07:12 PM
MADTIB's Avatar
Does the idle seem weird? Big loss of power? Maybe the same problem I had yesterday.Plug wire went bad,which caused a nasty miss.
Ohhhh.................Also make sure the MAF is plugged in all the way.
Old Jun 7, 2004 | 07:14 PM
Tank's Avatar
the maf is the thing on the elbow?
Old Jun 7, 2004 | 07:15 PM
MADTIB's Avatar
Yeah, it kinda sticks out of the intake pipe and has wires connected to it.
Old Jun 7, 2004 | 07:17 PM
Tank's Avatar
Yeah that looks like its all the way in
Old Jun 7, 2004 | 07:19 PM
MADTIB's Avatar
Okay, and make sure there are no obstructions with the intake.Also,make sure the air temp sensor is in place correctly.If all that looks good,I could walk you thru checking the plug wires.
Old Jun 7, 2004 | 07:25 PM
Tank's Avatar
Ok, gonna check that stuff when my friend gets here then i'll come back and see if we figured anything out.
Old Jun 7, 2004 | 07:27 PM
MADTIB's Avatar
Cool!! Let me know whats up.
Old Jun 7, 2004 | 07:38 PM
x7xstring's Avatar
Check to see if the sensor is damaged too
Old Jun 7, 2004 | 07:49 PM
MADTIB's Avatar
That's true, the MAF could be blown.Since they were play'n with the intake when the problem started.But,bad plug wires will fail suddenly with little to no warning.
Probably be best to make damn sure the MAF and everything dealing with the intake is in order,first of all.
