Cams???
whats this with the 2.0 XD cam??? ... i never heard of this before..
is it much better than the 1.8 GT cam?
i read it also improves the engine perkyness and sound better than the 1.8 GT substantially??
is this true??
who sells it?
is this true??
who sells it?
1.8 cam came in the 1.8 liter beta. Has higher lift and more duration than the 2.0 tib cam. The 2.0 xd/gt cam came in the 2.0 liter elantra gt motor. It has higher lift and more duration than the 1.8 cam. Go for the gt/xd cam if you have a 2.0 tiburon. I have it in my 2001. Never got a dyno, but I think it helped (waits for someone to tear into me) and my idle seemed a little lopier. Not much of a sound change. If you are comfortable with engine work, takes about half an hour. Otherwise, find someone who is. The actual lift/duration are posted somewhere, search for them.
if you have a full intake setup on your tib/elantra (CAI/BBTB/BIM) then you'll get some good benefits from the cams. Its probably the best upgrade for a tiburon sinces in only a C note and its a easy install(don't forget the 3bucks for the extra cam-journal bolts).
Nobody's dyno'ed the cams before and after, but it does give your car a kick about 3.5-4.0k rpm's, kinda like a vtec. Definetly worth it. and it keeps your warranty since its a hyundai part and you can't tell the difference just by looking at it wink
