Hyundai Aftermarket
-   -   Is This Cam Better Or Is The Same? (https://www.hyundaiaftermarket.org/forum/engine-intake-exhaust-11/cam-better-same-32569/)
sharkev Oct 28, 2005 08:30 PM
1.8L
Cam Height: Intake 44.449mm
Cam Height: Exhaust 45.049
Journal OD: 28mm
Bearing oil clearance: 0-.025mm
End Play: .1-.2mm
8 degrees more duration . Intake open event is advanced by 5 degrees, intake close event is retarded by 3 degrees, for a total of 8 more degrees of open angle.
2.0L GEN I BETA 99/00 Elantra 96/01 Tiburon
Cam Height: Intake 44.049mm
Journal OD: 28mm
Bearing oil clearance 0-.025
End Play: .1-.2mm
Pin OD: 45mm
UPDATE
2001 Elantra intake cam
Intake : 44.820 mm (1.7646 in.) 2 degrees more duration than 1.8 intake cam
Engine build codes G4GD ( newer 2.0 BetaII 2001+ Elantra), the G4GF (older 2.0L) and G4GM (older 1.8L)
I found this in a page... could be this cam better ´cause the 2 degrees ? and maybe someone can explain that they tried to say with this: <u>Engine build codes G4GD ( newer 2.0 BetaII 2001+ Elantra), the G4GF (older 2.0L) and G4GM (older 1.8L) </u> in this engines came the cam?
thanks
ps. cams with 264 degree duration are good? what gain could I expect with this.
thanks again.
supercow Oct 28, 2005 09:41 PM
http://kspec.com/list.php?ac_id=80&ai_id=717
kspec sells that cam, it and the 1.8L cam are popular upgradeds. from what i remember the GT cam (the beta II cam) causes more wear though so most people use the 1.8L cam.
CyberShark Oct 29, 2005 09:41 AM
Most people go with the 1.8 cam as it is supposedly the safer of the two. There are members who've had the GT cam for a while with no problems. One of the things with the GT cam is that it as a nipple on it that may effect timing.
sharkev Oct 29, 2005 02:42 PM
ohh ok... thanks, I didnt know that the GT cam came in Beta II....
and about the 264 degree cams?
faithofadragon Oct 29, 2005 02:45 PM
those are WAY better than the stock cams
but they require ecu tuning
