boring a throttle body
Old Mar 25, 2002 | 12:47 PM
justin's Avatar
Default boring a throttle body
does anyone know exactly how to go about boring out a throttle body?
Old Mar 25, 2002 | 02:50 PM
You have to bore it out 100% centered, then you have to custom fabricate a new larger butterfly that is within .25mm of the bore job. You can only take the stock unit to 58mm. If it is more than .5mm offcenter, you will rupture the TB walls.
The easy way is to send it to Onpol.
