they bolt to the same place but they wont hook up. the beta2 sensors are completely diffrent and will not be compatable AT ALL !!!!!!!!!!
oil temp sensor looks the same but i still changed it. i'm going to do a post on EVERY diffrence with pics here this weekend. so hold on and i'll come thru for you on any other diffrences |
Is there any difference in the gear box as I want to do a beta1-2 swap including box but just want to know if the drive shafts ect are the same.
tons of people have swapped to a beta II transmission.. its a DIRECT swap, just need to grind down the rear roll stop bracket.
gearing is a TAD longer in the beta II, but thats it. i had a beta II trans in my tib. |
beta2 tranny is WAYYY better for trips and also 3rd/4th pulls way longer. 4th gear is like 120mph after swap
The beta2 in the elantra has longer gearing. The one in the GK does not. It has a shorter FGR making the gears closer together.
<u>Few important things to add;</u>
G4GF (beta1 2.0L) MAF comp ratio 10.3:1 hydraulic lifters G4GC (beta2) MAP comp ratio 10:1 mechanical sim based valves G4GC (beta2) MAF CVVT on the intake side comp ratio 10:1 Careful, because there is actually 3 different beta 2 heads. The main thing to look for is MAP or MAF. |
^^ u forgot the G4GC beta2 without cvvt MAF based
I read that beta 2 tranny is a direct swap. Does that mean that I can use a beta2 clutch in my beta1 (stock tranny)?
| All times are GMT -6. The time now is 05:57 AM. |
