throttle body swap.
Old 10-10-2008, 11:31 PM
minorglitch215's Avatar
Vehicle: 2002 hyundai accent
Default throttle body swap.
Yup, bought it off a fellow on rdtiburon.com. pretty cheap. well it came in only a few days and i knew i was going to have to mod the holes to fit. well that is what i ended up doing. the elantra one doesnt have the hose fitment that goes to the valve cover so i threw on a little red filter. I assumed that was better than capping it off. what was nice was i didnt have to port my IM, the gasket is the exact size of the plenum hole(of course), which happened to match perfectly with the elantra TB. it definitely has a noticeable pickup in the higher rpms...
old one, new one.
first markings.
Testing the fitments.
Doesn't want me to work anymore.
Finished, yay.
The flash really brings out the crud down under.
i have a new gasket on order since the old one is cracked and well, old.
Old 10-11-2008, 01:33 AM
I've thought about doing that since my BBTB sucked.
Old 10-12-2008, 03:07 PM
omeletduefromage's Avatar
Vehicle: 02/hyundai/accent
anyone know which version of the beta tb would fit a 1.6l alpha with this easy mod?
Old 10-13-2008, 01:23 AM
QUOTE(omeletduefromage @ Oct 12 2008, 04:07 PM)
i will say easy with "crafting" experience.
it only fit because i made it fit. i centered it up and went at it. i'm sure you could do the same mod with the same TB but don't quote me.
Old 10-14-2008, 04:54 PM
well i was planning on make one hole fit w/o doing anything to it and then expand the rest till they fit and i was going to use washers if the holes got to big from dremeling.
Old 10-14-2008, 05:27 PM
It'll be harder (maybe impossible) to bore out the gasket and intake manifold throat to match the TB opening if it's offset.
Old 10-14-2008, 05:44 PM
wilburisthecoolest's Avatar
Vehicle: 1997 Elantra(Dead project) 1986 Golf(Track whore) 2000 Ranger(Daily)
QUOTE(187sks @ Oct 14 2008, 04:27 PM)
+1
Bore them all out with the TB centered.
Old 10-15-2008, 07:48 PM
ok after posting i was thinking about what i said and thought that the openings wouldn't match up like that so ill probably stick a pipe into the im and then insert it into the tb and use marker to get a rough idea where i need to cut.
Old 03-06-2009, 08:20 PM
GDAccent's Avatar
Vehicle: 98 Hyundai Accent X3
QUOTE(minorglitch215 @ Oct 10 2008, 09:31 PM)
old one, new one.
first markings.
Finished, yay.
Where did you put your battery? Last weekend I was going to put in a short Air ram filter like you have, but noticed I'd need more room.
So curious if you moved your battery to the back of the car?
Old 03-09-2009, 11:52 AM
QUOTE(omeletduefromage @ Oct 12 2008, 02:07 PM)
You should be able to make any with provisions for the ISA in the TB work. The one like above will not work because there's no ISA.
Quick Reply: throttle body swap.
