Beta 2 Head Work
Old Mar 13, 2016 | 08:33 PM
2000J25SP's Avatar
Vehicle: 2000 Hyundai Elantra GLS
Default Beta 2 Head Work
A few weeks ago I noticed excessive oil consumption, about half of a quart every one hundred miles. As well as occasional black smoke coming from the exhaust. There's no visible oil leaks. So I assumed the one hundred and ninety thousand mile piston rings were starting to show their age. The compression test showed that all cylinders were between 210-215 psi. So one would assume that the rings are actually in decent condition. Now I believe the valve stem seals are worn. I figured if I were to install new valve stem seals, I would rather install them on the better flowing solid lifter Beta 2 non-cvvt cylinder head. So I acquired a 2002 Elantra head for fifty dollars.
And then I figured If I were to take the time to install another head, I may as well take a bit more time and install a decked Beta 2 head with head work.
I'm about six hours into this project and probably have another ten to go. I'll need to get an extension for the Dremel.
It will probably be a few weeks until I will be able to finish and install the head.
120WHP HERE I COME!!! Lol
Here are the before and the halfway finished exhaust ports:
Old Mar 14, 2016 | 05:54 AM
JonGTR's Avatar
Nice work. When I did it, I knife-edged the divider.
Old Apr 12, 2016 | 10:50 AM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
I would edge the divider too!
Old Apr 12, 2016 | 12:16 PM
This is awesome work. This is something I forgot to do putting in my exhaust manifold
Old Apr 12, 2016 | 04:20 PM
2000J25SP's Avatar
I never said the exhaust port was done. I said it was halfway done.
@HyundaiKitCoupe
Wouldn't be worth the time. They say 90% of gains are from the first inch after the valve seat.
