Beta 1 2.0l exhaust cam on the intake said
Vehicle: 1998 Hyundai Tiburon Fx
Can anybody help with this mod on engine. I have read that people put the exhaust cam on the intake side with some modification on the cam.
I have done my re search onthis but cant find nothing please help.
Here a link were they talk about it:
http://www.newtiburon.com/forums/i4-.../191830?page=1
That seems like a metric crap ton of work for something that might not work anyway. Only one of the beta cams is driven by the belt so having two for the same type might not be possible from the get go - before getting into cam profiles/timing, etc
Thanks, but it's possible to doit I'll try de mod and keep looking on the forums to guide my self
Doing something different from the 1.8 intake cam swap etc.
Vehicle: 2010 Hyundai Accent
I've also been considering doing it as well since it has higher lift and longer duration. Seems pretty straight forward but I wonder when the valves would open after the swap. Guess best bet would be to use a cam degree wheel.
Vehicle: 2003 Hyundai Tiburon i4
If you do a side by side of any cam set the intake and exhaust are identical, minus the obvious VERY minor deviations in duration and lift. The cam mod in question is common and relatively easy if you have the right machinist to get the cam timing lug put in the correct spot.
Yes, the stock valvetrain will hold up fine. It is a stock cam so nothing really is changing. To ease your mind, members have ran much higher lift cams on stock valvetrain without issues as well.
but might give it a try !
