Anyone Have Any Ideas?
Old Aug 9, 2009 | 09:36 AM
lilo shark's Avatar
ok, to start off, my last tranny i had that blew on me had a problem with the driver side half-shaft popping in and out a lot and leaking. i thought it was just that trans but this beta 2 one that i have has a similar problem; i don't think the half-shafts popping out but there is always tranny fluid coming out from where the shaft goes into. the tranny only has 40k on it so there's no way the tranny seal could be shit. a little help if any can.
Old Aug 10, 2009 | 08:23 AM
Regit's Avatar
Vehicle: 2000 tib
If its still happening,same axel,must be the clip ring on the axel?
Old Aug 10, 2009 | 09:27 AM
Yup.
Old Aug 10, 2009 | 01:00 PM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
get a $50 axle from rockauto
auto axle is ok
Old Aug 10, 2009 | 02:56 PM
lilo shark's Avatar
i'll give it a shot, thanks for the inputs.
Old Aug 10, 2009 | 03:00 PM
Pull the shaft out and see if it has a C Clip on it or not. If it does, see if it's worth a damn or worn to hell.
I'm assuming you didn't replace the oil seals when you swapped either?
Old Aug 10, 2009 | 04:29 PM
Role Reversal's Avatar
Vehicle: 05 Subaru WRX
Also it could be the mount on that side is gone. allowing that whole side to lean and that would also cause the half shaft to pop out. i had a similar issue.
