Another Engine/tranny Swap
Old Jul 11, 2007 | 10:20 PM
baseballstud85's Avatar
Vehicle: 2011 Sonata 2.0T Limited
alright, so i finally got back from korea. now i need to get my swaps done. according to all i've read (searched) the beta 1 block will bolt up to the beta 2 tranny, right? and also, the 1.8 and 2.0 are direct swaps and the 1.8 ecu will run the 2.0 and all 1.8 sensors will still work? which injectors should i get, 1.8 or 2.0?
Old Jul 11, 2007 | 10:28 PM
ok here is what i know
beta 1 block + beta 2 tranny = good
1.8 or 2.0 beta engines = good
1.8 ecu + 2.0 engine = good ( you can reverse but i'm not sure of benifits from this)
as for the injectors i'm fairly sure they are the the same and the adjustment for fuel is at the computer. i'm sure someone else can step in and clear this up. although searching should have found all of that for you because it gets covered every other month fing02.gif
