Alternator Bracket
Old Aug 29, 2007 | 04:51 PM
'treezy's Avatar
it's easy, go in from under the car on jack stands. feed the belt into place before you tighten everything down.
and how in the hell was it missing an alternator belt? a car will not run without one (alternator).
Old Aug 29, 2007 | 05:19 PM
dddude55's Avatar
Vehicle: 2011 Kawasaki ZX6R
woah o_O they want $460 to put a new belt on or replace the bolt? I'm confused. Do you mean the bolt that goes through the top bracket into the alternator? because if tahts the one just take it to an auto store and say I need this. Or even a hardware store. There are 2 bolts the I call the tension bolts, the ones that hold the alternator to the top bracket. Then there is the bottom bolt which webtech calls the support bolt. Its what the alternator swings on.
If you got far enough as to try and tighten it yourself you probably know what you are doing and the alternator is really easy on our cars, you just have to take out the oil filter.
A "new" alternator is $169 after the $90 core cahrge where I am. "new" means you can only buy remans these days. If you only need a bolt... don't go out for a whole new alternator.
