Aftermarket Oil Filters Cause Engine (hla) Noise
This is intended as a point of reference for the next time somebody asks about clattering from the top end of their engine subsequent to an oil change with a crappy (read: FRAM) oil filter. Use the OEM filter or a high quality aftermarket filter (Purolator Pure One works for me) or stand by. Your engine oil pressure will be lowered by a low-quality oil filter, and the top end (valve train) will be starved for oil. The hydraulic valve lash adjusters (HLAs) will not have enough oil to them, causing a terrible rattling/knocking noise as they bounce around between the cams and valve stems.
The following text was lifted straight off of hyundaitechinfo.com a few minutes ago, and it is HMA's TSB to let all their dealership service departments know about this problem (not some urban legend or anecdote). Somebody remember to show this to DTN when he gets off his suspension.
Hyundai Technical Service Bulletin
Group: Engine Mechanical
Number: 05-20-002
Date: July, 2005
Models: ALL MODELS
Subject: USE OF AFTERMARKET ENGINE OIL FILTERS CAUSING ENGINE KNOCKING NOISE
DESCRIPTION:
Some vehicles may experience an engine knock noise with the use of an aftermarket oil filter. Aftermarket oil filters may use different materials, construction and specifications than genuine Hyundai oil filters, which may lead to pressure variations within the engine, thus contributing to an engine knocking noise.
VEHICLES AFFECTED:
All Models
REPAIR PROCEDURE:
Perform an oil change on the vehicle and replace the aftermarket oil filter with a genuine
Hyundai oil filter.
WARRANTY INFORMATION:
Normal warranty procedures apply.
This is not a warranty repair.
Number: 05-20-002
Date: July, 2005
Models: ALL MODELS
DESCRIPTION:
VEHICLES AFFECTED:
All Models
REPAIR PROCEDURE:
Hyundai oil filter.
The extra-fun part is when they change your automatic transmission oil and fail to use the SP-III Hyundai recommended fluid . . . and it destroys the transmission. owned.gif
N.E.V.E.R. get your car service at cheap lube shops. Anything a minimum wage mechanic can do, you can do for half the price. If you don't know how, ask RDTiburon.com how to do the work (just make sure to search first, then mention you're new to mechanics so you don't get razzed).
