AEM FIC wiring
Vehicle: 99/ Hyundai /accent
Understand! What's confusing me now... Is that I can connect my base tune that was sent to me... But I tried to relash the fic and I can't because the z file is no where to be found!! Could it be because I don't have the cd that comes with the fic?
There should be a z file downloadable from the aem power website forum. Can't quite remember which sub-section, but, i'm pretty sure it's there.
If it reads pressure when you aren't boosting, double check your MAP sensor power/ground as well as the signal output, and check its wiring. Be sure you are feeding the computer good data, before suspecting the computer.
