1.8l Flywheel...
Anyone got the info on the 1.8L flywheel? I'm starting to piece together a clutch setup, and have been told that it actually makes a decent lightweight flywheel for us, and has no chance of warping at all. Considering the cost, I'd love to put one of these in (OEM FTW!).
I want to compare it to the VHR Flywheel and the Fidanza. If it's not that much heavier, and decently lighter than the 2.0L one, I'll do it for sure.
I'm going to do some more searching, but I didn't find any answers.
Can you get a weight on it for me please?
According to Mad John, you can get quite a bit machined off of them too if you want.
I weighed my stock one and its around 15lbs.
I was also mistaken on the flywheel I bought. It wasn't 11lbs. It was 9.5lbs.
I bought the XTD chromoly flywheel off ebay. Their auction says its 10lbs, but when I weighed it I got ~9.5. Reason I went with this instead of the fidanza is because I needed it a bit heavier for my application tongue.gif
I suggest just buying a XTD flywheel, great quality, great price, and hell of a lot less weight even if you remove 2-3 lbs from a stock 1.8. Also, I believe the 2.0 is a 35mm pilot and the 1.8 a 41 pilot. How are you going to fill 6mm? An arbor? lol
i'm planning on doing a new flywheel-clutch set up for spring, but don't know what to go with. what's your plan on yours', dont want to intrude if you don't wanna tell. i was planning on using a eclipse clutch disc but still thinking about it.
