1.8/2.0l Beta Combustion Chamber Volume
Old Jun 18, 2009 | 11:53 PM
Does anyone know the manufacturer's specified volume for the combustion chamber? I've measured mine (all 4 49.5 +0.5cc) with valves and spark plugs installed, and I'm wondering how much volume I put in there when I reshaped the chambers. Also, is their volume with or without the head gasket height (I measured to the bottom of the head only)? I searched here and at HA, as well as hyundaitechinfo.com with no luck.
How many ccs in the combustion chamber? Anyone? Bueller?
Old Jun 22, 2009 | 12:37 AM
Denisst99's Avatar
combustion chamber volume is only the chamber, no gasket
(only valves, and spark plus installed)
mine cc'ed at 47 cc but i did polish them a bit, and cleaned the lips where they blen in the seats
Old Jun 22, 2009 | 06:35 AM
^ Thanks for that.
hmmmm.... You wouldn't happen to have a clean stock head up there would you?
I know shavings don't pack very tightly when you sweep them in a pile, but it would be quite a surprise to find out I had "only" taken out 2.5cc from each chamber!
Old Jun 22, 2009 | 10:33 AM
Albuquerquefx's Avatar
At one point, Random (Tony) had his cc'd out when stock, and I used his figures for calculating the compression for the piston dishes and deck clearance when I did my motor eons ago. 47cc sounds 'about right', but it's been too long ago to say for sure. I was pretty positive that information made it to HA in one form or another, but quite a bit of searching has yielded nothing thus far.
Edit - I sukc at teh spelinng
Old Jun 24, 2009 | 11:07 PM
Denisst99's Avatar
i havea few stock heads, if i get enough "free" time i'll try to cc one for you
Old Jun 25, 2009 | 06:31 AM
Haha, you w/ free time that's a good one!
