I was throwing a CEL for the bank one 02 sensor which was putting my car in serious limp mode. I replaced the o2 sensor with a new one and reset the ECU, the car ran fine for about 15 minutes and then the CEL came on again. Trouble code says that the sensor failed becuase of the inner core temperature. Any suggestions? I don't really want to replace it again without knowing what is wrong, thats sixty bucks down the drain.
what's exactly is the CEL code?
The code is:
P0135 02 sensor heater Circuit Malfunction (bank 1 sensor 1) and P0131 02 sensor Circuit Low Volts (bank 1 sensor 1) The guy who read my CEL said that there might be a wire grounding out somewhere...any suggestions? Does the 02 sensor heater activate to heat the 02 sensor after the car is shut off in order to burn off the carbon that has been deposited on the sensor and to clean the sensor? |
just for questions sake which sensor did you replace? the one in the cat or the downstream one...
The one that screws in the exhaust manifold...i hope thats bank one.
You had me scared there for a second...haha
| All times are GMT -6. The time now is 06:09 AM. |
