02 Sensor Bung In Flexpipe
Old Jan 17, 2007 | 02:39 PM
J3R0MY's Avatar
the 02 bung for the flexpipe shot out and now there is only a HP hindering hole
i was wondering if i should get another one put in but welded? i don't have much money right now, so if i just screw one in will it hold under high pressure driving for awhile?
and because i don't want to make multiple posts. i was wondering where i could get a TB and some silicone hoses in the future, all i have found is OBX, and Shark Racing.
please help on both matters, thanks.
Old Jan 17, 2007 | 02:41 PM
Hyundai4g63T's Avatar
Vehicle: Had 96 Elantra Wagon
No the bung will have to welded in and you would not put it in the flex section unless you want to ruin the flex and the sensor.
Old Jan 17, 2007 | 02:43 PM
J3R0MY's Avatar
the flex section? i was talking about puting a new bung in the hole myself.
and the sensor is in the header, and further down behind the catco cat.
Old Jan 17, 2007 | 02:50 PM
you need the bung welded into a piece of HARD pipe, not the actual flex. and then screw your o2 in there.
btw, you got raped on your exhaust system lol.. too much money.. lol
Old Jan 17, 2007 | 02:55 PM
Just curious... what size wrench do you need to remove O2 sensor?
Old Jan 17, 2007 | 03:07 PM
TopSpeedFX's Avatar
Vehicle: 1997/Tiburon/FX
If i remeber correctly it was an 18, but not 100% sure on that
Old Jan 17, 2007 | 03:36 PM
hamhead's Avatar
If you can't get a wrench on the sensor, then Autozone has the lend-a-tool program where you can borrow a socket for removing it. You have to pay like $15 bucks for the tools, but you can return it once your done, or keep it (I ended up keeping mine).
It is a 22mm
Old Jan 17, 2007 | 04:15 PM
I've got a o2 Sensor tool here if anyone needs it.
BTW, make separate topics there Jeromy.
TB = Seoulfulracing.com
Silicone Hoses = Seoulfulracing.com or Phantomperformance, here in our sub forums.
Searching would own.
Old Jan 18, 2007 | 08:19 PM
J3R0MY's Avatar
well i found out that pluging that hole makes the annoying buzz go away, so i dont need a glass pack anymore smile.gif
welding wasnt to bad, so im a bit happy
