TachometerShift Light Install Questions
Old May 12, 2004 | 07:12 PM
javageek's Avatar
Has anyone done this on a 1999 Tib? I have a shift light I need to install and I want to know what color wire I need to hook it to. I have never been able to unplug my ECU, so please don't tell me what # wire to connect to. I already know it is number 47. laugh.gif
Old May 12, 2004 | 07:44 PM
any online directions i can look at? or does it say what type of wire to connect it to?
anyway, heres my guess. behind the gauge...wire #5 on 101-2
using this diagram...NOT whatever is printed on the back of the cluster.
check the connectors on the crash pad. what you are looking for is a white wire.
i guess. i checked another website for instructions and it said to tap into the stock tach signal that goes to the cluster, so thats my best guess.
Old May 12, 2004 | 08:05 PM
javageek's Avatar
Default Korean Body Kits
The instructions say to either connect to coil negative or with electronic ignitions to connect to the tach terminal. http://www.proformparts.com/tech/PDF/Shift...nstructions.pdf
Old May 12, 2004 | 08:39 PM
I just IM'ed you with the HP page telling you where.
Geesh...
http://www.hyundaiperformance.com/forums/t...pic.php?t=39128
Old May 12, 2004 | 09:00 PM
Old May 12, 2004 | 09:01 PM
javageek's Avatar
